Question about GE Advantium SCA2001BSS Microwave Oven
No power Hi. I have a SCA2000BCC 02 from April 2000. It has been working fine. Used it to heat something for dinner last night, and all was well. After I took the veggies out, I shut the door and now there is no power. I checked the breakers and the plug, and that all seems to be fine. What do I check next?
  • dhaag Sep 18, 2008
    I cooked a pizza and after checking it at the signaled time, I closed the door to restart it and all power was lost. I tried the breaker and even tried a different outlet(dryer outlet is the same) and there's no power to the appliance.
  • GE Master
  • 9,098 Answers
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Sep 01, 2008
Mistral
What is the make and model number
Oct 29, 2017 | Microwave Ovens
Microwive not heatin
Ufortunately the magnetron is the most likely problem, "heats food" and is the heart of the microwave oven. If the device is five years old or more cheaper to replace the item.
Mar 04, 2012 | Sharp Microwave Ovens
It was working fine last night now it is making loud noise and not heating...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 05, 2010 | Sharp R-930AK Convection/Microwave Oven
My Advantium over is approximately 9 years old. I heated up broccoli last night for dinner and then it just went out. There is completely no light on showing the time and I checked the breaker switch. Do...
check the wall socket to make sure you have electricity to the plug. Secondly then check to see of the appliance "fuse" has blown, simple repair. If not, you have a costly serious issue.
Oct 07, 2010 | GE Advantium 120 Convection/Microwave Oven
Have ge sensor microwave model Je1660w
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
62y
Apr 22, 2010 | GE JE1540 Microwave Oven
ALL FEATURES WORK FINE; HOWEVER, LAST NIGHT THE IT STOPPED HEATING THANKS, DAN
first if no power check the internal ceramic safety fuse, then check the H.V. diode for front to back resistance(hi one way-low in the opposite direction),then check your H.V. capacitor for being open(if its shorted it will blow the internal fuse), starts with some resistance on up to no resistance(carefully discharge the cap before doing any of these checks),these are your most likely suspect components if you have some power,but no cooking
Feb 23, 2010 | Maytag MMV4205 Microwave Oven
THE MICROWAVE WAS OFF WHEN WE GOT UP..WAS FINE LAST NIGHT, NOW NO POWER, LIGHT...NOTHING
first check the power to the outlet.
plug something else (that works) into that outlet to see if it has power.
Jan 24, 2010 | Whirlpool MH3184XP Microwave Oven
Sanyo microwave EMS667W, diff high power ratings
A couple of things: If the dinner is in an aluminum pan, DON'T put it in your oven. Typically, high power units need about 3-5 minutes to heat a dinner so you should have heated it through. The power default is usually full power. Usually, there is a minutes button that should give you incremental minutes for programming.
Try using a standard nonmetallic cup (beaker) and fill it with water. Heat for 2 minutes. The water should be boiling hot. If not, your oven is not doing it right.
Mar 10, 2008 | Microwave Ovens
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Open Questions:
See all GE Advantium SCA2001BSS Microwave Oven Questions
GE Advantium SCA2001BSS Microwave Oven Logo
158 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
