Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Ice not being produced
My ice dispenser is not producing ice, but water is coming out still. The red light on the on/off switch is blinking and nothing seems to be broken.
    Sergeant:
  • 409 Answers
check to see there is any frost building up, either on the water line or the inside of the door.
if there is no ice build-up, you may have to have the water valve (inside the icemaker) replaced.
Posted on Sep 17, 2008
Red light on the control panel is lite, and will not dispense ice or water.
Hello Theresa, thank you for your post!
Based off the information you have provided the light on your control panel is red and it is not dispensing water or ice. The red light means the filter is 100% used up and needs to be changed out. When the filter is dirty it will not allow water or ice to dispense or produce. You would need to purchase water filter WF3CB as a proper replacement filter. You can visit your manufacturer's website for assistance with purchasing that replacement filter. I hope this is helpful information for you. -Matt
Dec 30, 2015 | Frigidaire FFHS2322MB Black 22.6 Cu Ft...
The ice maker does not produce any ice. The power light blinks and the water dispenser in the door works, but no ice...
You have a bad connection on the ice maker switch. try replacing it. Question? is the water in the dispenser cold?.
Apr 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Kitchenaid kscs25fjss01 (2002) front panel not working
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Apr 02, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not working, light blinking
I contacted Sears repair service and had the Ice maker and control panel replaced.
Jan 09, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Nov 07, 2007 | Whirlpool ED2FHEXN Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
276 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
