Question about JVC GR-D250 Mini DV Digital Camcorder
01 error code - unit in safeguard mode
Hello - my JVC GR-D250 has just started to come on with error code 01 Unit in Safeguard mode. I have removed and reattached battery, but it has made no difference. Grateful if you could help.
Thanks.
David
  • rosie78 Sep 08, 2008
    Same error as above any help appreciated
  • dadon469 Sep 10, 2008
    mines also its on safeguard mode what can it be
I solved the problem! Open the video cassette door. Look closely at the gear mechanism and see if there is any small debris in the gears. If not, using a magnifying glass and a paper clip(must stretch it out and use the tip) gently move each gear(gently). I had my unit ON. Once I moved the gear it became unstuck and ejected Mini DV cassette. I then re-inserted the cassette and it worked. The dreaded SAFEGAURD MODE message was gone and it is as good as new.
Be Blessed
dennis@privatemtglending.com
Posted on Sep 27, 2008
I have a GR-D850U in safeguard mode
I have a GR-D850U model JVC and its giving a message Unit in safeguard mode. How can I have this fixed ?
Jan 14, 2010 | JVC GR-D850 Mini DV Camcorder
Unit in safeguard mode remove and replace battery 01
SURE ITS NEED SERVICE YOU CAN TAKE TO ANY AUTHERISED SERVICE CENTRE.
BEFORE THAT MAKE SURE THE CASSETTE IS NOT STUCKING INSIDE THE MECHANISUM. THERE SHOULD BE AN ERROR CODE ON THE DISPLY UNIT START WITH E-01 TO E-06
Sep 18, 2009 | JVC GR-D250 Mini DV Digital Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
SAFEGUARD MODE ERROR CODE E06
Why not do what the manual says ? They're printed to assist you.
Jul 14, 2017 | JVC GR-D201U Mini DV Digital Camcorder
JVC GR D250 MINI DV DIGITAL
the fucken tape is stuck and i have no ******* clow how to take it off once you take it off the problem is solved
Jul 25, 2008 | JVC GR-D250 Mini DV Digital Camcorder
JVC GR-D250 Mini DV Digital... Problem
There is any error code displying on the lcd screen?
Feb 28, 2008 | JVC GR-D250 Mini DV Digital Camcorder
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
Jvc GR-D250
There is any error code showing on the lcd screen?
Oct 25, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Cant record, cant open the cassette
The error E01 refers to loading motor problem. The camera will have to be taken to a JVC agent for repair.
Sep 19, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Open Questions:
Audio drop out and/or static sound Thanks to anyone who has taken a look at my issue with audio cutting out. JVC has always been a brand I have confidence in, and I believe I picked this camera up when those recording to an internal hard drive were out of my range. Last summer, I received a fantastic deal on some JVC Evarios, so GR-D250 duo would be used only as back-up, BUT, I have a ton of old Mini DV tapes -- never recorded over anything. I would find the heads needing cleaning solution highly unlikely. The first 250 recorded the bulk of those 150 or Mini DV's and worked like a champ. Because of legal depositions for lawyers and like, who may not want for me to call time-out in a deposition to switch tapes and the fact that eventually my first was going to give out, having a back-up and eventually multiple seemed like the thing to do. Having a couple of friends film some sports events I could my mix radio play-by-play I could with dual camera angles was cool. This same-year model second buy had sat in storage; The original tape the who sold it to me with 10 minutes of footage came with it. I could tell the battery was so much stronger after a full charge than my old one, but this newer D250 has maybe had 1/10 the recording time as my original. Whether listening to the camera speakers, piping the sound from the rear A/V jack or importing via firewire, it's the same. The video may not be perfect and may "spark" or "flicker" in unison with the audio that drops out,but not always. At times, the video seems just fine but the audio drop-out is akin to a loop and I could probably time it, which was what I termed as cyclical. Could one of my friends have dropped it or tipped over a tripod and not told me? Sure, but I would think they would have told me. One night, follow some high school hoops I was importing, excited at the prospects of some two camera angles mixing. Thought I may have had a bad tape, but ruled that out right away through trying multiple tapes in bother cameras. Apologies for my loquacious follow-up; I suppose if worse comes to worse, I could check eBay for a secondhand model. I've "misplaced" my original, but it will turn up; it's simply a matter of desiring to import all that footage, since 2008, with superior editing software and skill than what I possessed when doing so initially. Thanks so much!
Apr 13, 2014 | JVC GR-D250 Mini DV Digital Camcorder
See all JVC GR-D250 Mini DV Digital Camcorder Questions
JVC GR-D250 Mini DV Digital Camcorder Logo
727 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
