Question about Jet AFS-2000 Air Purifier
Won't start HAd an outlet burn out. I guess it caused some problem with my AFS-2000. Now it won't start up. My manual shows a reset on the front control panel, but my unit has an 8 amp (fuse?). There doesn't seem to be any type of access to it. Do I have to take the control panel apart to get to this?
  • 1 more comment
  • tm_tillman Sep 12, 2008
    Thank you for your efforts, let me clarify a few basic details;
    The outlet has been replaced,
    the circuit checks out strong, now,
    the breaker is good. The units power cord shows no sign of heat distress.
    Pressing the external fused reset doesn't help.
    We pulled off the 'power-in' face plate and removed the reset. It doesn't appear to allow access (to replace a fuse?).
    We have a second unit, so can see how a working unit responds.
    thanx I'll check it out.
    Master:
  • 726 Answers
The fuse is a little glass one behind the control panel very difficult to get to.
Posted on Sep 12, 2008
    Genius:
  • 1,239 Answers
HI
I THINK THE Magnetic fluid (ferrofluid) fills a small annular gap between a rotating shaft and a stationary magnetic pole piece. The gap is part of a high-energy magnetic circuit which includes the shaft and pole piece. The very large magnetic flux in the gap exerts a force on the fluid, holding it in place against pressure difference from atmosphere to vacuum, yielding a dynamic rotary seal in which there is no solid friction. Therefore, very long operating lifetimes are achieved.
Because the magnetic fluid has very low vapor pressure, it remains permanently in place for the entire lifetime of the seal, and does not contaminate the system. Some applications have special requirements (high temperature, highly reactive gases) which can be satisfied by selection of the optimum fluid from our family of fluid materials.
    President:
  • 1,450 Answers
Is plug not damaged? you will have to take cover off to access fuse
  • TripleTauto
    TripleTauto Sep 12, 2008
    If you have a voltmeter you can check the voltage of the power cord coming in to machine and go from there it is either gonna be a bad switch,cord or power supply. will have to trace out voltage.I am not an expert on this machine just trying to help.
  • TripleTauto
    oh yeah be sure to check that magnet fluid!!!!! hee hee
  • 958 Answers
Are you still plugging the unit to the burnt outlet?
could you check the power where you sae plugging the unit. it may just be out of power. it could be the same circuit as the one one which burned.. tnx drcool
Posted on Aug 26, 2008
  • francis rivero Sep 03, 2008
    please check the circuit breakers where you are plugging it?..it could have tripped off.
    tnx, drcool
  • 19,396 Answers
Check the fuse inside the unit, it is located where power cables hook up.
  • Ginko
    Ginko Aug 26, 2008
    Start testing the unit on a different power outlet, check that the power cord has not melt, and that the plug is fine.
    If you are in UK, or you are using a fused power cord, check also the fuse inside the power plug.
    If cord and plug are ok check inside the unit, you will find the fuse located where power cables hook up.
    If fuse is ok, then power cable must be replaced.
    If fuse has blown, but unit does not start after cable replacement, then power supply inside air purifier must be replaced, in this case verify your guaranty terms and call number listed on your user manual.
Remote will turn the air filter on but will not turn it off. Have two in my shop with the same problem
I had similar issues and by replacing the 2200 micro (Mu) Farad, 10 Volt capacitor on the PCB, all of my issues ceased.
Below is a link with information supplied by "fixya" that explains the procedure/details.
Hopefully this will solve your current issues.
Good luck,
Mike
http://potlash.org/feast/2010/11/20/repairing-a-jet-afs-1000b/
PS Linda Haus of "Rockler" Technical Support was kind enough to supply me with this link.
Jun 02, 2014 | Jet AFS-1000B Air Purifier
Bionaire BAP1300 -- Working fine for 2 Days then, Red Light
Try to do a hard reset by unplugging the device from the power outlet and wait for sometime to reconnect.
Jun 09, 2008 | Bionaire BAP1300 Air Purifier
Problem with Jet AFS-1000B Air Purifier Afs-1000b
Mine had this same problem, it was a 1000 uf capacitor on the circuit board. It is replaced and working fine
Nov 04, 2013 | Jet AFS-1000B Air Purifier
Red light reset
you mus read your owner manual for reset the light. Normally you must disconnect the power cord from outlet, by 45 seconds, and connect again. or download the i.manual from www.manualslib.com
God bless you
Oct 08, 2013 | Oreck XL Professional Air Purifier
I "won" a Rainmate from
No, not that I'm aware of. But, the problem itself, may be in the electrical receptacle. A loose wire, a bad connection or interior damage could all cause the circuit breaker to trip. Or it may simply be the case, of line that air purifier is plugged into, is simply overloaded, because of other electrical appliances are on the same circuit of tripped the circuit breaker. Most air purifiers have their on circuit breaker or fuse built-in to the unit. And that, will usually trip before the circuit breaker in the breaker panel of your home.
Here's how you test that theory: Plug the unit into another outlet, that is on an entirely different circuit than the original one and turn it ON. If this trips a different circuit breaker, then you know it's an internal problem with the unit. If it doesn't trip the circuit breaker, the problem is with the original receptacle or the line that feeds that receptacle and it's circuit breaker.
Hope this helped you to troubleshoot and solve the problem.
Jun 13, 2011 | Rainbow Rainmate Air Purifier
All of the lights on the control panel are flashing simutanously and constant. The air cleaner is not working. I just had it tuned up about a month or so ago. Whats happening
Here's something that has worked in the past. Turn the Master ON/OFF switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes before plugging it back in. Once it's plugged back in turn the Master ON/OFF Switch to ON and set the controls as you normally do.I f everything now functions as it should, the unit reset itself.
If that doesn't solve the problem contact the Oreck Service Dept that did the tuneup for you.
Apr 04, 2011 | Oreck XL® Tower Air Purifier
I was doing cleaning and maintance on my fresh air unit, I noticed the red wire was no longer connected to clip that powers ac to ozone plate. I trimmed red wire till burned part was gone got good wire...
Congratulations! You did better than many dealers!
Hopefully, the answer to your problem is far easier than replacing the clip!
On the right side of the front panel, among the manual controls, there is a tiny little "reset" button. While the machine is running, press that button.
Then, turn the machine completely off for a few minutes, and then power it up again. Hopefully, that will take care of the message.
If not, inspect the plate. Are there any defects or lint particles? Check the placement of the plate. Is it inserted in the tracks, both top and bottom? Are the metal contact fingers pressing firmly on the metal screen portion of the plate?
If this still doesn't take care of the message, there is something wrong with the wiring, plate, or contacts, or the computer is malfunctioning! Call Vollara (new name for EcoQuest) customer service 800-989-2299 and ask for repairs. Someone there may also have suggestions, before you go to the trouble of sending in the machine. Use #16618 if you need a referral number.
Jan 13, 2011 | Ecoquest Fresh Air Air Purifier
Pure Ion will not turn on. We took out the filters to clean them. Wall outlet works for other items. Have tried other outlets.
It sounds like the main board is not getting power. The power supplies have capacitors inside that do overheat and burn out. You can test power coming from power supply leading to main board with a voltmeter. You can try to unplug for 8 hours, in meantime while unplugged, press and hold power button for 5 seconds, then wait 1/2 hour and plug back in to see if unit has reset itself
Oct 13, 2009 | Brookstone Pure-Ion UV Air Purifier
Filter Queen Defender red light will not blink
no with the red lite on it mean that you need to change your filter its a safety feature so you dont burn out your motor and also so you dont blow unpurified air through out your home
Oct 13, 2007 | Filter Queen Defender Air Purifier
Red Light on front of Filter Queen Defender
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
Mar 06, 2007 | Filter Queen Defender Air Purifier
Jet AFS-2000 Air Purifier Logo
150 people viewed this question
Top Jet Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Jet Air Purifier Expert? Answer questions, earn points and help others
