Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitachi 50ux53k My Hitachi Ultravision does not turn on, I was told there is corrosion on the chassis. Is there a specific part on the circuit board that can be replaced or is there a circuit board number that I should be looking for.
  • 927 Answers
Good Day, egipson;
When the CRT's Coolant (fluid) get onto PCB's, one can clean the boards with acetone. BUT YOU MUST MAKE SURE ALL POWER IS REMOVED FROM TV. SAFETY FIRST.
Good Luck, big IRISH. PS after cleaning [place heavy plastic over effected areas.
Posted on Sep 01, 2008
I have a Hitachi Ultravision TV Model #50ux53k v7h002332. The remote is working and also changed the Batteries. The Tv is not reacting to the remote like it should. It randomly will not turn on or off and...
if you have to hold the remote very close it is likely a bad remote receiver in the front control panel; the only other reason would be a dirty lens there or at the top of the remote.
Let me know if all manual front buttons work normal.
Apr 28, 2011 | Hitachi Televison & Video
Hitachi 60" Ultravision TV - bad green tube that is leaking
If this has only started to leak recently, get an estimate from a local servicer for a coolant replacement for that tube. The coolant is corrosive and needs to be cleanedup ASAP from any circuit board that it has touched before there is damage. This is NOT a DIY repair. Expect a repair cost in the $300 range for parts and labor. If the set had a good picture prior to this, it may be worth the repair. This is your call. Do not delay however, as any delay will increase the likelyhood that there will be more damage that needs repair.
Dec 09, 2009 | Hitachi Televison & Video
Hitachi 50UX53K Ultravision will not stay on
The set is going into shut down mode for avariety of reasons. Some of the more common problems are vertical o/p ic bad connection or failure, poor solder connection usually in the power or hv section or possibly comb filter circuit breakdown causing 12V line to short. This set incorporate 7 or more shut down circuits and any one of them could be triggering - more trouble shooting is required
Sep 18, 2009 | Hitachi 50UX52B/53K 50" Rear Projection...
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
May 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
Probably a 'cold or detatched' solder joint on a component on that perticular circuit board you are 'wedging' with a plastic rod.
Apr 16, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Dec 20, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Shuts down after power up 50ux53k bought new 1998
Refer to owners manual will tell you what blinking light means. But at the front not at the back.
Dec 16, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
the best thing 2 do is buy a new one and get guarnteed with it again
if u try 2 fix it it not 50% working
if u got guarnteed then take it back (or phone them to come)
Nov 07, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
you have lookse connection on the video convergance amp ic
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
Nov 04, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 43UWX10B 43" Rear Projection Television Logo
166 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
