Question about Toshiba Satellite A25-S207 Notebook
Memory upgrade My Toshiba A2-S207 has its orginal memory config, with two slots occupied by 256Mb PC-2100 modules. What is the best option for memory upgrade ? Can I just add one 1Gb module to one slot ? Can the system really support 2 x 1Gb modules as claimed by some vendors ?
    Genius:
  • 2,028 Answers
It looks like the A25 will only hold 1g of PC2100, which is really plenty, unless you're a serious gamer or into graphic arts and need an extreme high definition video. Here's a link to the memory configurator that I use in order to find the proper memory, max held, and the chipset. You might double check to be sure I looked up the right machine. If it is the right machine, I suggest two 512mb chips. Sometimes you can't run one 1g chip because the slots are designed to only hold a certain amount, and if they will hold the 1g chip, sometime the machine doesn't run properly. It wants to use both slots accordingly, running only one creates conflicts. This should help in boosting your RAM.
Posted on Aug 26, 2008
Toshiba satellite A100 slot 2 doesn´t work. A
Is memory matched (DDR2 667)
Have you put original mem in slot 2
Download / install CPU-Z with both modules in and run program to see if it shows.
If all above is correct may be damaged mobo.
This is for your laptop from vendors site.
Memory5
• Configured with 512MB DDR2 SDRAM (1 slot occupied and 1 available)
• 512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB or 1024MB PC4200 DDR2 533MHz SDRAM.
Mar 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
I can't locate were you install the memory modules
You can purchase 1GB ram sticks for them...need to shop around.
Access the ram slots by switching laptop off / remove battery / depress on / off switch several X to de-enrgise system. Turn laptop upside down and remove one of the small panels...be carefull you do not lose screws. Very carefully unclip ram stick / lift up and out.
Mar 12, 2010 | Toshiba Satellite A20-S207 Notebook
I was upgrading the memory to 4gig and was told to do a BIOS update from Toshiba. After the update I noticed it was running slow. Soon, it wouldn't start, you could only get to the "repair" screen, but it...
Hi, here is the specs of ur laptop memory, there is a possibility that the memory that u purchase is not compatible with ur laptop specs.. I hope this will help u..
Memory
Configured with 1024MB PC5300 DDR2 SDRAM (both memory slots may be occupied). Maximum capacity 4096MB,
Memory Upgrade
Part Number Description
PA3512U-1M1G Toshiba 1GB DDR2-667 Memory Module
PA3513U-1M2G Toshiba 2GB DDR2-667 Memory Module
Aug 13, 2009 | Toshiba Satellite A215-S7422 Notebook
How to replace memory fro 512 to 4gig
Here's are the tips to replace you memory from 512 to 4GIG.
  • Configured with 512MB DDR2 SDRAM (both Memory slots may be occupied)
  • 256MB(min)4096MB(max), 2 memory slots using 256MB, 512MB, 1024BM or 2048MB PC4200 533Mhz or PC5300 667Mhz DDR2 SDRAM, dual-channel support requires two memory modules of same capacity and clockspeed.
Hope this might help you.
Aug 07, 2009 | Toshiba Satellite M105-S3041Notebook
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
Memory Upgrade problem
You have the correct memory, however, did you replace memory in both available slots with same capacity/clockspeed sticks? The below is from the Spec sheet for your computer.
512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB, 1024MB or 2048MB PC4200 DDR2 533MHz SDRAM,
dualchannel support requires two memory modules of same capacity and clockspeed
Mar 22, 2009 | Toshiba Satellite P105-S6227 Notebook
Memory upgrade
The M45-S169 only has one available memory slot.
(I'm confused about your post that states "M45-S265" in the head line).
  • Configured with 512MB DDR SDRAM (both memory slots may be occupied)
  • 512MB(min)/2048MB (max), 256MB on-board memory with 1 available memory slot for 256MB, 512MB, or 1024MB PC2700 DDR 333MHz SDRAM 2.5V SODIMM memory modules
You can find the complete specifications here.
Jan 05, 2009 | Toshiba Satellite M45-S265 Notebook
Ram upgrade
Its support "DDR SDRAM"
Max Supported Ram is "1GB"/"1024 MB".
Ram Speed: 266 Mhz..
Good luck...
regards,
Dec 04, 2008 | Toshiba Satellite A65-S1068 Notebook
Memory
It has two memory modules. the other one is under the keyboard and is actually pretty easy to get to. the plastic piece with the power button in it pops off when you put the screen all the way back. then just unscrew the 3 screws you see under there and your keyboard flips up. presto there is your other memory chip.
Jan 31, 2008 | Toshiba Satellite M105-S3004 Notebook
Toshiba Satellite A25-S207 Notebook Logo
122 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
