Question about Dryers
Dryer problem I just moved into a rented home and my landlord recently moved the dryer to clean. It now makes loud banging noises and smells a bit like burning rubber after I immediately turned it off. My landlord thinks that it's "off balance" and that it works fine. I'm nervous to use it. Is this something that I can fix, or do I need a service appointment? Thanks!! Suzann
  • ses08 Aug 27, 2008
    Thank you!!
    Sergeant:
  • 351 Answers
You need a service call on it the smell could be a buid up of lint on the element.
Posted on Aug 27, 2008
Loud banding noise in my LG Tromm DLE7177
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Feb 11, 2013 | LG Tromm Electric Dryer
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
DRYER DRUM SPINS BUT LOUD BANGING NOISE AND ELECRICAL BURNING SMELL. UNIT ABOUT 15 YRS OLD
drum rollers/glides may be the idler arm, if is located next to the motor:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 23, 2011 | Kenmore 63942 Dryer
When Dryer is on it makes loud banging noises almost like the cylinder is hitting the sides. It also seems to be excessively hot even set on low heat, and has an almost burning smell inside after running.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 15, 2010 | Asko T700 Electric Commercial Dryer
Our dryer has started making a loud thumping sound and smells like rubber burning?
It sounds like you your dryer may have a bad Blower Wheel, which is causing the banging noise that you are hearing (especially if the banging noise continues for a few sections after you turn your dryer off).
Hope this is helpful.
Jan 16, 2010 | Microsoft Windows XP Home Edition
DRYER IS MAKING A CONSISTENT BANGING NOISE WHEN RUNNING. DRUM IS TURNING AND DRYER DOES DRY OK.
There are several things that can cause a dryer to be noisy. There are a lot of moving parts in a dryer that can cause noises to occur when they get worn. Several parts support the drum, and may make noise or vibrations when worn out. Many times a dryer will squeak just a little bit as it first starts. This should go away in just a few seconds. Make sure nothing is loose inside the drum. Remove the lint trap and look below the lint trap holder for any loose items that may have slipped through the cracks. The blower wheel is always moving and lint is constantly going by it. If it’s noisy, it may have gotten clogged with lint, or it may be worn and need to be replaced. Clean out the area around the blower. If it’s still noisy, replace it.
Many dryers use a center spindle to support the clothes drum. This spindle may be a ball-and-socket support, or it may be a shaft inside a sleeve. When these component bearings get worn out, they may make a squealing or rubbing sound. Replace this bearing when it gets worn out. Many dryers also use plastic glides in the front end of the clothes drum. When these glides are worn out, you may hear a lot of noise. If the glides are worn, replace them as a set.
Some dryers use rollers to support the clothes drum. If these rollers or wheels are worn out, they can be extremely noisy. You ought to replace the whole set at the same time. A belt that has been damaged or frayed may make a thumping or slapping sound as the drum turns.
The gas valve solenoid will make a buzz type of sound as it opens. The valve itself will give a little click as it starts the heat cycle, when ignition begins, and when the burner is turning off. The burner flame itself makes kind of a low-pitched roaring wind sound.
Thanks for using Fixya.
May 28, 2009 | Frigidaire Dryers
Recently moved, light inside dryer works. does not turn nor heat
Don't be playing around with electricity, folks. If you use anything but original equipment and something goes wrong, it's all your fault and responsibility. You are renting, have the landlord approve and maybe he can recommend a proper solution.
Mar 24, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
Dryers Logo
135 people viewed this question
Top Dryers Experts
