Question about Amana Refrigerators
We purchased two type 19TFA refrigerators in June 2008 from one of your dealers in Gainesville, Florida. (Serial Number EW1804473), Within 5 weeks the fan motor in the freezer went out and the refrigerator defrosted. 8/26/08 this happened again and the dealer sent a serviceman over who took out the old motor and installed a new one. Something must be wrong with the motors being used--one came in the unit and the replacement was taken from another new Amana. What is the problem here? WE would like the problem fixed as would the dealer who is going to get tired of paying a technician to come to my houe to put in a new motor every 5-6 weeks. Franklin Ritch. email rfrpa@bellsouth .net
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Amana Refrigerator SCD22JL
Good trouble shooting TD, the evap fan runs through the defrost T-stat. Change it out and you should be set. Catriver.
Posted on Aug 15, 2007
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
  • 958 Answers
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
Posted on Jun 25, 2008
  • 531 Answers
SOURCE: Amana refrigerator too warm, freezer too cold
the damper control is not working let me tell you what to do the air that comes from the freezer block if you can get to the damper you will see it have a get rool a piece of paper between the body of damper and the get flap and have it open if the refrigerator side start cooling is the damper control i am sure about that is the damper control
Posted on Apr 01, 2009
  • 2118 Answers
SOURCE: both the freezer and refrigerator will not stay
you must have a defrost problem,open the freezer door,do you hear the fan blowing,if not change evap fan motor,remove second from bottom bin and touch the back wall if you feel ice or snow there you have a defrost problem check the t-stat and heater,not sure but if you read the tech sheet i think you can click the light switches to put into defrost,also if plugs are on t-stat,unplug them and bypass the t-stat by pluging the wire to the heater,if heater comes on then you have bad t-stat if not read out heater with meter,also ge has been having alot of problems with the mother board ,if you defrosted it and it happened again in a 2 week period i dout it's the board
Posted on Nov 02, 2009
Which ipad has this serial #,Is this for ipad 1,2,or3? DN6FXJPYDKPH
Serial Number: DN6FXJPYDKPH
Model:- iPad 2 (WiFi)
Codename:- No codename assigned.
Build Country:- We don't know where this unit was built.
Build Year:- This unit was built in the first half of 2011.
Build Week- Week 26 (June)
Production Nr.:- This unit was number 2038 to be built that week.Serial Number: DN6FXJPYDKPH
http://www.appleserialnumberinfo.com/Desktop/index.php
Jun 16, 2015 | Apple iPad (16 GB) WiFi Tablet PC
Serial number look up
On the bottom of the Xbox 360, you will be able to see the Xbox 360 manufacturing date and the Xbox 360 serial number. The manufacturing date is in the following format:
2008-11-03 this is how you read it
YYYY-MM-DD
(Year-Month-Day) which is the date according to ISO 8601.
This would
The serial number looks like this:
6144526 84302
the serial number is formatted (LNNNNNN YWWFF)
  • L the number of the production line within the factory,
  • NNNNNN the number of the Xbox within this week.
  • Y the last digit of the production year,
  • WW the number of the week of the production year
  • FF is the code of the factory (02: Mexico, 03: Hungary, 05: China, 06: Taiwan),
So taking the serial number 6144526 14302 this would give us
  • Line 6 of the factory
  • This would be 144526 off the production line
  • 2008 production year
  • Week 43 of the year
Aug 08, 2014 | Microsoft Xbox 360 Console
MY TV is LG 42 PG 60D , serial number :803KCBD35285
Sound like ur Tuner board have intermitint problems,it work awhile,than the old problems occur again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.Because this problems come and goes.
Apr 30, 2010 | LG 42LC2D 42 in. LCD HDTV
A few keys are sticking on my Olivetti. They click up, hardly hit, and then dont return to their proper place. I'd appreciate it if someone could offer some advise...or name a place in Gainesville Florida...
Needs a good cleaning and lubrication. I charge $ 75.00 to make it clean as new. You can try to simply lubbicate it yourself. Just drop 1 drop of oil into each typebar guide. Hit each key a few times.
My number is 727-773-8973 in Largo, Florida
Dec 21, 2009 | Olivetti Lettera 35 L Typewriter
Whirlpool washer age please-Type 3 cp 2302342. LSN 2000LW1
The manufacture date of Whirlpool appliances is determined by the SERIAL number. The following link explains:
http://www.fixya.com/support/r2880489-determining_age_whirlpool_appliance
The first two sets of NUMBERS represents the WEEK it was manufactured, while the second DIGIT represents the YEAR. So...based on the serial number you have provided, that would make the manufacture date of your washer June of 2003. Let me know if you have questions. I hope this helps you.
Oct 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
AMANARefridgerator AFD2535FES Refrigerator not cooling
If is still under warranty you should have open it, if they know about this u can loose the warranty. It is better for them to check it, if any thing they will replace.
Aug 03, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
I have a GE side by side refrigerator that keeps blowing the defrost heater element. MODEL # TFT22JWDA WW SERIAL # TZ264141 I bought it from a GE dealer about 5-6 years ago. It ran fine for 3 years,...
In my GE side-by-side there is a defrost temp sensor located near the top of the evaporator coil. I think the control board uses that temp sensor to know when it should be done defrosting.
On the schematic of my fridge (link below), the defrost thermistor is part number 240 in the diagram (not part number 241, which is a different temp sensor located adjacent to the one you want)
http://www.partselect.com/ModelFrames.aspx?ModelID=361233&ModelNum=GSS20IEMDWW&mfgModelNum=&ManufactureID=2&Selected=00113321i06&Position=2&mfg=GE&Type=&Mark=2
I don't know why the defrost element would fail immediately other than incorrect supply voltage or just a bad defrost element.
Jul 28, 2009 | Refrigerators
Age of Kenmore side by side refrigerator
Brand: Kenmore
Type: side by side refrigerator
Country: USA
Model: 106.58123700
Serial: HRW2754229 This product appears to have been manufactured the week of June 30, 2008
for anything like that next time on any other appliance check out this link by clicking it directly
http://www.appliance411.com/service/date-code.php
Apr 01, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
After replacing the flat bet and v belt on my Hoover model U6433-900; serial No. 12300043057, purchased June 23, 2004, the brush roller still does not turn when I release the foot lever to vaccuum.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=725351
Generic problem for all Vacuums
Posted by mahammons on Jun 30, 2008
After replacing the flat bet and v belt on my Hoover model U6433-900; serial No. 12300043057, purchased June 23, 2004, the brush roller still does not turn when I release the foot lever to vacuum.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can think of if that the brushroll may have to be rebuilt and new bearings need to be installed on each end. If unrebuildable, then you need to purchase a new one but most are rebuildable. The other thing is to check the motor pulley to see if that spins freely as well. If you have a problem or other questions please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Vacuums
Open Questions:
Mullion heater connection for Amana 84" Integrated bottom mount refer model B136CAR3 mfg P1318402W. I need to hook up the mullion heater that is under the freezer, component P/N 12401301. But I cannot find the mullion heater connection point. According to the specs it's installed in the foam and not wired from the factory and is for service purposes. The reason for this is that the water from the defrost cycle re-freezes and clogs the drain hole. Eventually the ice gets almost an inch thick and it's SOLID. The freezer drawer cannot open, so I have to thaw it all out and pry it open. I've done this dozens of times over the years! The service tech never figured it out. But with help of my boat-refer-expert brother we found the solution at the high level. Devil is in the details. According to the instructions: make a slit and peel back the white vinyl harness sleeve that goes to the water valve, pull out two wires (black and white) that aren't connected to anything (yet). Then "locate the mullion heater leads at the left side of the cabinet and connect to the back and white leads". Then Wrap vinyl sleeve with electrical tape to seal the slit. OOOOOKAY.... I found the unconnected leads in the harness that goes to the ice maker water valve. They have male bullet style plugs and clips (a little corroded) but I cannot find anywhere to connect them... Is left side of the cabinet as viewed from the front or back? The main harness is on the left rear area. And if I make the slit long enough (which is very difficult, then the wires could make it back there. If I only could find where the mullion heater's connectors come out. Of course the wiring diagram only shows the mullion wiring as optional and not connected to anything. I really do not want to lay this 500lb (at least) beast on it's side. It already fell on me and my daughter, but a countertop and pallets save us. This refer has been nothing but a pain to deal with ever since I bought in 2001. I don't want to get rid of it, since it has custom wood panels that go with our kitchen, and I fell on hard times (due to illness) and cannot afford a new one. It fixed many things on it already. Such as the problem where the relays weren't soldered properly onto the main logic board, which fixed the non-defrosting problem and the freezer fan not working. But now the drain hole plugs with ice. So I read that many freezers have a 5W to 20W heater that runs all the time to keep the hole from freezing. Especially if water gets in the insulation under the floor of the freezer. Anyway, can anyone tell me how to find the connections to the mullion heater? Is it in the outside-rear channel up back of the refer? it's pop-riveted on. Thanks! Scott
May 12, 2017 | Amana Refrigerators
Refrigerators Logo
178 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
