Question about Maytag Washing Machines
Water temperature can't get cold water wash...used to hear change in sound when selecting cold, now the same as warm water. Also changes to hot cycle...started as sporadic but is now continously warm on cold cycle. Is this something a DIYer can fix?
  • 5,911 Answers
It sounds like your water inlet valve (also known as a Mixing Valve on some washers) HOT solenoid is sticking open. When you select either a hot or cold wash cycle, separate solenoids open or close to allow only cold water to enter the washer on the cold wash cycles and hot water to enter on the hot cycles. If the hot solenoid stays open, you will have hot water mixing with your cold water during the cold cycles. The result is warm water. I would recommend you replace the water inlet valve. This is a job the average DIYer can do. Please post back with your model number and I can assist you with locating a part number and/or give you specifics on how to access the valve to replace it.
Posted on Aug 26, 2008
I have a front loader LG inverter direct drive
The water temp switch only determines weather THE MACHINE WILL USE cold or hot water. The real culprit sounds like the inlet water valve? change hoses from hot and cold and see if there are any significant changes in temperature. Another culprit may be ur motor control board, on front loads more of an issue.
Oct 03, 2014 | Washing Machines
Fills cold and warm but not hot
This is a common problem with hot water lines to washing machines. The hose connecting the washing machine to the hot water supply has a small screen in the inlet of the hose. These are used to keep grit, etc from getting into the washing machine and causing bigger problems.
Here's what to do:
Pull the washing machine away from the wall a little so you can access the shut-off's. Turn off the hot and the cold water valves.
Take the hot water hose off the valve and check the screen in the rubber washer of the inlet hose. Replacement screen/washers are available at local hardware stores for a couple bucks.
You can clean the old ones, just be careful not to damage the rubber washer because that's what keeps your hose from leaking when you reinstall it on your faucet.
While you're at it, clean the cold water screen as well.
REcheck your fill on a hot cycle... you've most likely solved your issue!
May 09, 2010 | Washing Machines
Cold Water extremely slow to fill. Had same problem with hot water some time ago and I have turned hot water off at tap and always choose cold water. Now I have turned hot water tap back on and use warm...
sounds like both valves r faulty .try cleaning inlet hose filters and if that doest work must b valves. buy and change cold first to save u money,if u dont use warm often.please reply 4 more help.p/s turn off power b4 working on unit dont want any acciedents.
Apr 08, 2010 | Fisher and Paykel (IWL12)
My smartdrive 058 the water temperature lights up on hot, when I set to warm cold it beeps and does nothing until I press it. Why?
this is what we call a user fault : you may also hear a series of beeps as well usaly idicates hot water is not detected this may occur when warm or hot is selected solution make sure hot water is avalible to machine
Jan 24, 2010 | Fisher and Paykel Fisher & Paykel Washer
Water changes from hot to cold. Valves checked out
Bad thermistor or bad board. Or its just a energy super saver and it will not let you use all that hot water. Did it work before or its been like this since new? New energy star models will only let it just get warm for hot wash, saving energy. warm wash is like 70 deg water.
Nov 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
When I wash dark clothes, I get lint on them or white spots
The lint is from some other garment in the same wash.
Do the white spots wipe off or are they "bleach stains"?
Assuming they wipe off, then your detergent is not dissolving all the way. Make sure the water is hot enough. Even cold water needs to be a minimum temperature and during the cold months the water can get too cold. Try warm or mix hot and cold by changing back-and-forth on the control for the wash temperature. Also, try putting the detergent in first or buying a higher grade of detergent (i.e. Tide). Best of luck.
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 22, 2009 | Washing Machines
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine doesnt heat the water
Most washing machines do not heat water, they merely let the hot water into the wash tub that comes from your house hot water heater.... when selecting warm, hot and cold water will be mixed together to get warm or when selecting cold.. only the cold water is allowed into the wash tub.. Please provide brand and model number of machine so I can tailor a reply toward your specific washer...
Sep 21, 2008 | Washing Machines
Open Questions:
Washing Machines Logo
288 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
