Question about Microsoft Xbox 360 Console
Xbox 360 Hi we are having a problem with a XBOX 360 The problem is as follows: When powered up, disc tray automatically ejects. When you place a disc (CD, DVD......) etc. The disc ejects automatically, without reading the disc! No matter what is tried, ie: switching off, restarting, changing disc, removing disc, the tray automatically ejects. The only time it wont eject: placing disc in tray, closing draw, and phisically holding tray / draw in place. Please could someone help. Many thanks in advance. Upmarket Productions
I have a problem like that, jus as the tray is about 3 inches from closing slam it shut on the right hand side (where it says xbox 360 on the tray), its a bit cavemanish but it works for me lol
Posted on Apr 04, 2009
    Problem Solver:
  • 10 Answers
You need to send it off to get repaired
Posted on Aug 26, 2008
Xbox 360 door tray off track and will not close
First, do not attempt to try to fix it right away. Unplug every cable and adapter, so you only have the xbox 360 console. Then, if a video game disc is still in there, take it out. Next, try to determine what your disc tray is stuck on, and try to remove it carefully. If these steps do not work, look at these articles. Manually eject your Xbox 360 console disc tray Xbox Disc Drive Solution.
Oct 11, 2014 | Microsoft Xbox 360 Console
Tip
Xbox 360 - Stuck or sticking tray fix!
If your Xbox 360 DVD drive won’t eject it can be a very simple fix.
The Samsung drive is almost always a very simple fix, if you have another drive, it may be more difficult.
To identify your drive, follow this guide:
• Remove the faceplate by firmly grasping the opening for the USB ports and pulling.
• Underneath the DVD tray there should be a small hole.
• Look at the wires in the hole to identify which drive type you have.
Red and Black Wires = Samsung Drive
Yellow Wires = LiteOn Drive
White Wires = BenQ Drive
No Wires = Hitachi Drive
SAMSUNG:
It is very common for a Samsung drive to not eject. It’s a very simple fix for this!
1. Power on your Xbox 360
2. Press the eject button
3. When the Xbox 360 “tries” to eject, just simply push in on the tray cover.
That should make it eject!
If it does not, please follow the guide for the other drives below:
This requires you to disassemble your Xbox 360. IF you don’t know how, look it up on google, there are plenty of guides.
Then follow these steps:
1. Remove your Xbox 360 DVD drive from the Xbox 360
2. Turn over and remove the four screws securing the drive (6 screws if it’s a Hitachi)
3. Remove the top cover of the DVD drive.
4. Put the drive back in the Xbox 360, connect the wires, and power on your Xbox 360.
5. Once the 360 powers on, eject the drive. Most of the time it should eject normally. If it doesn’t you may have to force it.
6. Unplug the Xbox 360. If you turn it off with the power button the tray will close first, we need it open.
7. Near the front of the drive, you should now be able to see and access a small rubber band that was hidden by the tray.
8. Remove the band, lubricate and replace.
9. Replace the top cover and hook up and test.
10. If that doesn’t work, you may need a new rubber band. If you can get one of the right size, replace and test.
on May 13, 2010 | Video Game Consoles & Games
Tip
If your Xbox 360 Disc tray won't eject
SAMSUNG:
on Feb 02, 2010 | Video Game Consoles & Games
Tray stuck open
The gears on the Xbox 360 have become misaligned. Here is how you fix it. If the tray is out all the way disconnect the power.
Step 1:
Locate the tab on the left side of the tray.
Step 2:
Lift the tab with a pen or equal and pull the tray out.
Step 3: power on the Xbox 360 and hit the eject button. When you here the eject "ding" pull the power. Now the drive is in eject mode and the cogs are aligned to take the tray.
Step 4
Gently place the tray back in and slight nudge to engage gears.
Step 5
POwer on xbox 360 and give another nudge to help the tray realign.
Step 6
Open and close the tray a couple times. To assure sucess.
Aug 20, 2014 | Microsoft Xbox Video Game Consoles & Games
Disc draw will not open
Manually eject the disc tray
  1. Disconnect the power cord and any other cables connected to the console.
  2. Uncoil a paper clip.
  3. Position the console horizontally, as you would position a DVD player.
  4. Find the yellow sticker behind the vents on the left side of the console.
  5. Insert the straight end of the paper clip into the eject hole which is located just above the yellow sticker (as shown in the picture below).
  6. The disc tray should pop out slightly. Pull the tray out the rest of the way with your fingers.
Note If a disc is in the tray, make sure that it is not sticky and does not have a label that might prevent the tray from opening again in the future.
If you cannot get the disc tray to open, please see the following article: 906936 The disc drive of your Xbox 360 console does not open
uparrow.gifBack to the top Original Xbox 360 console: How to manually eject the disc trayFirst you need to remove your console's faceplate. Here's how:
  1. Unplug the power and A/V cables from the back of your console.
  2. Position your console horizontally, as you would position a DVD player.
  3. While holding your console firmly, push the faceplate away from the console with your thumbs.
    Note You will need to use some force to remove the faceplate.
  1. Uncoil a paper clip.
  2. If your console has holes below the right side of the disc drive, insert the straight end of the paper clip into the hole as shown in the picture below.
    If your console does not have the holes pictured below, skip to step 5.
  3. Push the paper clip until you feel some resistance (approximately 1" or 2.5 cm into the hole).
  4. If you're successful, the disc tray will pop out slightly. Pull the tray out the rest of the way with your fingers and skip to step 9. If the disc tray does not open, try the next step.
  5. Find the two holes below the left side of the disc drive, and insert the paper clip into the first hole on the left.
  6. Push the paper clip until you feel some resistance (approximately 1" or 2.5 cm into the hole).
    Note Make sure you are pushing the gear mechanism and not the metal plate.
  7. If you're successful, the disc tray will pop out slightly. Pull the tray out the rest of the way with your fingers and skip to step 9.
  8. If the disc drive is still stuck closed, insert the paper clip into the adjacent hole (to the right) and push again. If you're successful, the disc tray will pop out slightly.
  9. Now plug the power cord into the back of the console. Press the eject button to open and close disc drive. If the disc drive works properly, reattach the console faceplate.
If you cannot get the disc drive to open, please see the following article: 906936 The disc drive of your Xbox 360 console does not open
uparrow.gifBack to the top Xbox SupportPlease visit the following website for information about how to contact Xbox Support: support.xbox.com/pages/contact-us.aspx
Apr 09, 2011 | Microsoft Xbox 360 Console
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
XBOX 360 cd rom is not reading discs
1. Make sure you REMOVE any discs from your XBOX' tray. 3. Turn on the console again, either by using the controller or the POWER button (NOT the EJECT button) and WAIT for the initial XBOX setup. ... This fixes the OPEN TRAY error 100 % of the time on my XBOX 360. XBOX 360 cd rom is not reading discs Google Search
Jan 13, 2018 | Microsoft Xbox 360 Console
Hi,the door for putting disc in wont open.every time i push the button there is noise comn from machine like its trying to open but it cant?
This happens to me every now and then.
Here is how you can get around it:
Sometimes, you cannot open the disc tray on your Xbox 360 console by pressing the eject button. Any of the following things may cause this problem:
  • There is a hardware failure that affects the console, the disk drive, or the eject button.
  • A disc is lodged in the mechanism.
  • The clear protective plastic strip that is applied to the front of the tray to protect it during shipping is preventing the disc tray from opening.
To manually eject the disc from the disc tray, follow these steps:
  1. Unplug the power cord from your Xbox console. For more information about how to disconnect the power supply, click the following article number to view the article in the Microsoft Knowledge Base: 906205 (http://support.microsoft.com/kb/906205/ ) How to connect and disconnect your Xbox 360 power supply
  2. Position your Xbox 360 console horizontally, as you would position a VCR or a stereo component.
  3. Remove the faceplate from your Xbox console. For more information about how to remove the console faceplate, click the following article number to view the article in the Microsoft Knowledge Base: 907331 (http://support.microsoft.com/kb/907331/ ) How to attach or remove the faceplate on your Xbox 360 console
  4. Depending on the kind of disk drive that you have in your Xbox 360 console, you can use one of the following methods. Note In each case, make sure that you align the tool (a paper clip or stiff wire) to pass through another notch behind the hole on the console casing. Collapse this imageExpand this image906935.jpg
    • Method A: Insert a straightened paper clip or other small, stiff wire into the first hole from the left side of the disc tray. To release the disc tray, push the paper clip into the hole to press the manual eject mechanism. The manual eject mechanism is a white lever that is visible behind the console casing. The hole is located about 1.5 inches (approximately 4 centimeters) from the left edge of the disc tray.
    • Method B: Insert a straightened paper clip or other small, stiff wire into the second hole from the left side of the disc tray. Push the paper clip repeatedly into the hole to turn a gear to release the disc tray. The hole is located about 1.5 inches (approximately 4 centimeters) from the left edge of the disc tray.
    • Method C: Insert a straightened paper clip or other small, stiff wire into the hole that is directly under the "X3" logo on the Xbox 360 label on the disc tray to release the disc tray. The hole is located about 1 inch from the right edge of the disc tray.
  5. After you release the disc tray, the tray pops out slightly. You can pull the tray out the rest of the way to remove the disc. Note If you use method A or Method C in step 4, you may have to firmly press the disc eject mechanism to eject the disc tray.
  6. If you determine that a hardware failure has occurred that affects your Xbox console, contact Xbox Customer Support or submit a repair request for your Xbox 360 console.
(Information taken from: http://support.microsoft.com/kb/906935)
Hope it helped.
Nov 16, 2009 | Microsoft Xbox Console
Starting
xbox 360?
you open the disc tray by pressing the eject button directly above the tray, insert the disc and then close the disc in the same manner. if the game does not automatically start up then you will be required to go to the row that says My Xbox and the very first tab should say the game you have entered. you play it by pressing A
Jan 27, 2009 | Microsoft Xbox 360 Console
Xbox360
Depending on the type of disc drive that you have in your Xbox 360 console, use one of the following methods:
Method A: Insert a straightened paper clip or another small, stiff wire into the first hole from the left side of the disc tray. To release the disc tray, push the paperclip into the hole to press the manual eject mechanism. The manual eject mechanism is a white lever that is visible behind the console casing. The hole is located about one-and-a-half inches (approximately four centimeters) from the left edge of the disc tray.
Method B: Insert a straightened paper clip or another small, stiff wire into the second hole from the left side of the disc tray. Push the paperclip repeatedly into the hole to turn a gear to release the disc tray. The hole is located about one-and-a-half inches (approximately four centimeters) from the left edge of the disc tray.
Method C: Insert a straightened paper clip or another small, stiff wire into the into the hole that is directly under the "X3" in the Xbox 360 label on the disc tray to release the disc tray. The hole is located about one inch from the right edge of the disc tray.
In each case, make sure that you line up the paperclip or stiff wire to pass through another notch behind the hole on the console casing.
Oct 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
300 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
