Question about Kitchen Ranges
Jenn-air range model S136C
Connections for a switch for the oven blower/oven light.there are four colored wires- double brown, double blue,double white,single blue.please provide a diagram for these four connections to the switch.
  • jikesallan Aug 26, 2008
    I have received a new switch for my JENN-AIR model S136C range.The switch is located at the top front of the range and controls both the blower and the oven light.My problem is not knowing which terminals the four wires into the switch connect to.There are four sets of wires as follows:
    double brown wires
    double blue wires
    double white wires
    single blue wire
    Any help in solving this problem would be appreciated.
    Thanks
    Jikes
    Master:
  • 521 Answers
Go to the site
www.repairclinic.com
it has all the parts mentioned in detail with proper diagrams.just enter the proper model number and part number.
also check this link for more extra help
www.applianceaid.com
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Aug 26, 2008
  • 157 Answers
Call an electrician ... i think you dont wanna play around with wires and cause and either short circuit the oven (which will cost you hundreds to replace) or cause a fire.
Cheers
Jigsaw
Fixya Team
Please remember to rate this solution
    Top Expert:
  • Kitchen Ranges Master
  • 77,499 Answers
Contact these folks they can help, there are no wiring diagrams available on the web
http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=`Bjennair&gclid=CLzdg_f3q5UCFSJIagodl1M3jg
    Master:
  • 848 Answers
Just go through the manual it will have digrams of how to give connection .........
Jenn-Air dual fuel double oven range - oven wont work.
You can make the repair yourself. What is the model number?
Nov 07, 2012 | Jenn-Air Kitchen Ranges
What des error cde F1 mean on a Jenn-Air D156 drp-in range
JENN-AIR
'Newer Style' Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
JENN AIR
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
Mar 22, 2010 | Food Processors
Jenn Air Cooktop wiring issue.
Thank you for your enqiry!!
Mar 21, 2009 | Cooktops
Fan/stove light switch broke needs replacing
The original fan switch for the SEG196 (circa 1995) is a four terminal switch- two for the fan and two for the light . Note that the switch spade lugs for the red and blue wires (which when connected activate the fan) are larger than those for the white and brown wires (which when connected activate the oven light). This design presumably prevented miswiring of the switch at original assembly. Since the four terminal switch is nearly impossible to find (it was discontinued several years ago), an inexpensive fix is to replace the four wire switch with a two wire SPST toggle switch. However, this means that either the fan function or the light function can be preserved- not both. I elected to keep the fan function, and simply wired the red & blue wires to the two terminals of a heavy duty replacement SPST toggle switch. Be sure to fully insulate the remaining (in this case) white and brown wires with electrical tape or wire nuts before tucking them below the new switch. Total cost: $6.00 for switch. NOTE: TURN OFF POWER TO RANGE AT ELECTRICAL PANEL BEFORE ATTEMPTING REPAIR! beec3807-1ba5-40e7-a010-7e26d5fca5c0.jpg
Feb 18, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
WIRE CONNECTIONS
may i know the exact model # of your unit, and the part # of your switch control.
let me know, thanks.
micro
Aug 26, 2008 | Kitchen Ranges
Switch connections
I have a Jenn-air, and the switch for blower and light is on top, front. the switch has 4 connections on the bottom, and viewed from the bottom, the white wire goes at 12 o'clock, the red and brown wires are in the top left corner (paired with the white one) and the black wire is at 6 o'clock, and the blue (double wires) goes in the lower right corner (paired with the black one). If you have a continuity tester, the switch is a dpdt, and white is connected to red-brown (double wires) OR black is connected to blue-blue( double wire).
Hope this helps.
Panel light is out
There is a capacitor on the clock board labelled C3. It will probably have brown burns on it or "syrup" leaking around the base. You can buy a box of 10 of these for 75 cents at Radio Shack (make sure you match the label on the old capacitor, I think it's 58mf and 35V but I could be wrong) and a pencil soldering iron for $10. It's held on with 2 little wires. Before taking it off note capacitor orientation (where the blue +++ stripe is), the replacement has to go on the same way. Common problem and easy fix.
Feb 09, 2008 | Jenn-Air JJW8530C Expressions Collection...
Kitchen Ranges Logo
126 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
