Question about Hitachi DZ-GX20A DVD Camcorder
How long can I record using a DVD-RAM disc?
What is the maximum recording time using a DVD-RAM disc?
    Master:
  • 473 Answers
• Extra Fine mode (3-9Mbps record speed): Approx. 20 min. minimum per side. • Fine mode (6Mbps record speed): Approx. 30 min. per side (1 hour total). • Standard mode (3Mbps record speed): Approx. 1 hr. per side (2 hours total).
Posted on Sep 05, 2005
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
How to record dvd in ordinary format?
I will presume it plays back fine on your dvd recorder.
In this case, you need to "finalize disc" for it to be playable on other dvd players.
Also, possibly, If you are using a dvd-ram disc, you must make sure that the dvd-player you are trying to use even supports dvd-ram. Most will NOT.
Also, Make sure you are not recording in VR mode. Only some very new dvd-players will support VR mode discs.
Jun 01, 2009 | Pioneer DVR-550HS HDD Recorder
Failure to accept DvD Ram discs in a Panasonic DMR-E55 Recorder
Possibilities are that the laser lens needs cleaning (use a proprietary cleaning disc) or that - as long as you are sure you have original manufacturers' discs and not fakes - the discs are scratched or dirty.
Feb 20, 2009 | Panasonic DMR-E55 DVD Recorder
What is +vr and how do I remove it
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewriteable disc.
If the user would like to record on the same disc again in later time, on VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Blu-ray Disc and HD DVD also support VR mode-like features.
Accordingly when DVD recorders became a viable option the features offered by <Video Mode> were minimal - the linear structure did not allow post recording editting or non-linear playback. Thus the DVD Forum devised Video Recording (VR) mode.
Unlike DVD-Video this uses a much simplier file structure that allows non-linear modification to the recorded data. This means features such as partial erase, editting, playlists, simulataneous record/playback, mixing of different media types (JPEG, MPEG1/2/4, MP3, WMA, WMV etc) and, in future models, dual record are all possible."
That basically summerises the differences: video is a linear recording that should end up DVD-Video compatible, VR is a digital recording mode that allows HDD-like functionality on disc.
Do you need to always be able play your recorded DVD-RW discs on other DVD Players? If yes you have to use Video Mode, although some players will play VR mode discs, and you can test this easily by giving it a go.
The main differences are:
DVD Video mode on DVD-RW
Plus points: Provides good compatibility (70% plus). That’s the only plus, plain and simple.
Negative Points: Only simple linear editing possible, really just hiding a title. You can reuse space only when you delete the last title or completely reformat but lose everything in the process. No defect management. Requires finalisation to play in other DVD Players. No possibility of time-slip, i.e. recording and playing back at the same time.
DVD VR mode (Video Recording)
Plus points: Better use of recording rates by having intermediate resolutions. Defect management so reliable. Time-slip on 2 speed media if supported by the recorder, allowing record and playback at the same time. Non-linear editing. Any space freed is reused automatically (think hard-drive or Mini-Disc) and added to the remaining time.
Negative Points: Not very compatible with existing DVD Players, plain and simple.
Of course if you have a hard-drive based recorder then all the negatives are wiped out, as you use VR mode on the hard-drive which gives you all the pluses of VR mode, then record to DVD-RW in Video Mode to give you the compatibility to play the disc elsewhere.
- A recording on DVD-RAM will always use VR mode
- A recording on DVD-R will always use Video mode
- A recording on DVD-RW can be either Video or VR depending which is set before the recording is made.
- A recording to DVD+RW or DVD+R will always use Video mode
- Many HDD/DVDR combi recorders will record to the HDD in VR mode and allow you to dub (digitally) to DVD-R in Video mode.
Here is your manual:
http://www.p4c.philips.com/files/d/dvdr3545v_37/dvdr3545v_37_dfu_aen.pdf
Jan 10, 2009 | Philips DVDR3545V/37
Can not read disc
I mainly use my DVR to record TV shows on DVD-RAM discs (Panasonic brand or Maxell). I've had no problems with the DVD-RAM discs. However, today when I put a DVD-R disc in the recorder, I got an "Incompatible Disc" error message. I tried a second disc from the same set, and got the same message. I tried out some of the DVD-Rs that I recorded last year and I could read them. Tried a DVD-RAM. That was OK. So, I tried another DVD-R disc. That one is OK. I don't know if the problem is that these DVD-Rs are getting a little old (2 years??) or if the recorder is developing its own problems reading discs.
Dec 03, 2008 | Panasonic Diga DMR-EH75V DVD...
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
What are the approximate recording times of the filming
Extra Fine (available on DVD-RAM discs) -- 20-60 minutes/side Fine (available on DVD-R and DVD-RAM discs) -- 30 minutes/side Standard (available on DVD-R and DVD-RAM discs) -- 60 minutes/side
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
When should I use a DVD-R / DVD-RAM / DVD-RW?
Write Once – After finalizing, a DVD-R disc can be played back in approx. 95% of home DVD players and PC DVD drives Capacity – 30-60 minutes (depending on the selected filming mode) of high quality motion video can be stored on a single of a disc. Re-writeable – DVD-RAM allows for recording and re-recording of movies and still photos up to 100,000 times per disc. DVD-RAM is like a removable hard drive. Compatibility for video playback of DVD-RAM in standard home DVD players is fairly low. DVD-RW cannot store true .jpeg digital still photo’s like DVD-RAM, however it is re-writable and has 80% compatibility with home DVD players.
Hitachi DZ-GX20A DVD Camcorder Logo
73 people viewed this question
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
