Question about Jenn-Air JGS8850BDS Stainless steel Gas Kitchen Range
Problem with getting burner to light.
The front right burner on my gas Jenn-air will not light. It will light with a match but the ignitor will not light it. At the same time that I try to turn on the RF burner, the LR ignitor starts to spark. I have purchased a new ignitor for the RF burner and it does not correct the problem. I know the replacment ignitor is good as it works on the RR burner. Why does the LR ignitor spark when I try to turn on the RF burner and is it related to my problem? Help.
  • Anonymous Mar 16, 2014
    replace burner ignitor on jenn-air 3610
All my ignitors spark when I turn one of them on. I'v been told it is normal. I had a problem before and the tech that replace the ignitor said the issues is with alignment. Try to rotate the burner a bit left or right and see if it fixes it.
Posted on Dec 22, 2008
The right side back burner will not light. There is gas, I can smell it but the spark will not start. BUT, the spark will initiate and light the front right burner. What is going on? Its the same...
Can have below issue.
(1) Electric current is not reaching the ignitor. (wire is broken or have a leak)
OR
(2) Having problem with ignitor. (need to replace the ignitor)
Feb 03, 2011 | Jenn-Air 30 in. CVG4280 Gas Cooktop
The electronic ignitor on front right burner no longer works.
All ignitors should fire regardless of which burner is turned on. See if the right front will light up if you turn on another burner or look for a spark. If not, the ignitor is probably fouled and needs a good cleaning. If the right front burner will spark or ignite when a different burner is turned on, it is the right front control switch - not an easy fix. When cleaning the cook top, if you remove the knobs, any liquid that gets into the switches will short them out. Found that out the hard way.
Dec 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
I have a jenn-air sealed gas cooktop jcg8430 only 1 burner lights
you have a problem with the ht leads or spark electrodes
Aug 18, 2009 | Jenn-Air Cooktops
Jenn-Air JGC8536 Gas Cooktop ignitor replacement
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
Dec 12, 2008 | Jenn-Air JGC8536 Gas Cooktop
I have a 4 yr. old Maytag stove model #PGR5715BDQ, the burners all work fine as well as the broiler. The bake ignitor glows red and after a while gas can be smelled but burner will not light. A match will...
I have a Jenn-air stove model # JGS8750BDS in the oven when I call for bake the ignitor come on and glow then the gas come on but the burner want light but I smell the gas what is the problem
Aug 26, 2008 | Kitchen Ranges
When I try to light my jenn air gas cook top it clicks but will not light. But it will light with a match
Your electronic ignitor is bad. You can buy a replacement ignitor where you bought your grill. Just about any hardware store will have a replacement ignitor. They are real easy to replace. There is 1 wire to the back of the ignitor. There is a retaining nut on the switch. Remove the switch and replace with new switch. Plug wire into ignitor, Turn gas on and test ignitor.
Happy Grilling
Please rate this solution
Jul 31, 2008 | Jenn-Air Kitchen Ranges
Jenn-air CVGX2423
Is it clicking? No...bad switch. Yes...check ignitor gap on that burner. The gap or the wiring is bad if it doesn't work.
Jun 08, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn Air Pro Style gas range - ignitors on 2 burners (same side) click but don't light
I had a problem in which only one burner refused to light with the electronic ignition, even though the same ignitor (they are shared) would light the rear burner on the same side, and the problem burner would light with a match. On inspection, the spark occurs at a central point and there is a tube which apparently leads gas from each burner to the ignitor. There are two groupings of 3 holes each on the sloping part of each burner, facing toward the ignitor. After lighting both burners (the front one with a match), I saw that the lower group of 3 holes had tiny flames on the burner that worked properly, but not on the other. I carefully cleaned each of these holes with a small pin, and the problem appears to be solved.
Apr 27, 2008 | Jenn-Air Kitchen Ranges
Wrong ignitor starts when burner is turned on.
Sounds like you have a bad ignitor on that burner.
Sep 25, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
High performance burner slow to light
Replace that ignitor on that burner only. Not drawing enough amps to spark properly.
Nov 26, 2006 | Jenn-Air JGC8536 Gas Cooktop
Jenn-Air JGS8850BDS Stainless steel Gas Kitchen Range Logo
392 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
