Question about Hitachi DZ-GX20A DVD Camcorder
What DVD media types does it use?
What type of DVD disc does it use?
    Master:
  • 473 Answers
8 cm. (3 in.) DVD-RAM (conforming to DVD-RAM Book 2.1) with cartridge and DVD-R discs (conforming to DVD-R for General Book 2.0) with caddy.
Posted on Sep 05, 2005
How to erase a dvd dics
dvd are read only.
dvd-r; dvd+r and dvd-rw are the re-writeable discs. mostly once only.
DVD Media Formats Explained
There are many different types of writable and rewritable DVD media on the market today. These formats include:
There are also "General Purpose" and "Authoring" discs. DO NOT confuse the "Authoring" media with the term for content development (making / editing what eventually goes on the DVD). The most common type of DVDR is the General Purpose type - if you do not know that you have an actual authoring recorder drive then you most likely have the general purpose type.
DVD-R is a write-once recordable format which allows excellent compatibility with both standalone DVD-video players and DVD-ROM drives. There are two main types of 4.7GB DVD-R discs: DVD-R for General Use and DVD-R for Authoring. Most consumer drives use the former cheaper General Use discs, while many higher end professional drives use Authoring discs. The correct media type appropriate for the drive must be used when burning. However, once burned, the discs should be able to be read in either drive type. (General Use DVD-Rs are designed to prevent backup of encrypted commercial DVDs).
DVD-RW uses rewritable discs which are rated at more than 1000 rewrites in ideal situations. Unfortunately, DVD-RW does not enjoy the same excellent compatibility with DVD-ROM drives and standalone DVD-Video players that DVD-R enjoys. Another drawback is that unlike DVD-RAM, one must generally erase a DVD-RW disc before reuse.
Most DVD-RW drives should also be able to record to DVD-R. However, the reverse is not true. Many older and some current DVD-R drives are not capable of writing to DVD-RW discs (but may be able to read burned DVD-RW discs). Some drives can also record to CD-R and CD-RW.
Currently DVD-RW and DVD-R are most popular in the multimedia market as well as the general consumer market. For instance the Apple SuperDrive, found in higher end Mac computers used in multimedia creation, is simply a DVD-R/DVD-RW (and CD-R/CD-RW) capable drive.
DVD+RW, like DVD-RW, is a rewritable 4.7GB DVD format. DVD+RW, however, in some ways offers some technical advantages, which for example include: lossless linking (which in turn more readily allows editing of a disc's contents after an initial write while maintaining integrity of the remaining data), currently slightly faster recording speeds, and optional future Mount Rainier drag-and-drop file access support (also known as DVD+MRW). However, DVD+RW does not have the very high compatibility with standalone DVD-video players and DVD-ROM drives that the DVD-R format enjoys. The level of compatibility of DVD+RW is said to be similar to that of DVD-RW. Also, DVD+RW does not currently have the same level of market acceptance as DVD-R.
DVD+R is a format that only was introduced to the public very recently (early 2002). DVD+R is a write-once 4.7GB format which promises to dramatically increase the compatibility with standalone DVD-Video players and DVD-ROM drives. Whether that claim is fulfilled remains to be seen, but initial reports have been very positive. It must be noted, however, that 1st generation DVD+RW drives do not support DVD+R burning, and it is likely that most cannot be upgraded to do so either. If one wishes to have DVD+R burning functionality, one must purchase a newer drive specifically designed to do so. DVD+R discs currently are somewhat more expensive than DVD-R discs, but prices will likely drop with time. Burners that write to these discs is the HPDVD100i and the DVD-Writer DVD200i drive
Thanks to www.AnandTech.com for this helpful information AnandTech Home
Mar 07, 2016 | Televison & Video
Recording/burning to disc
I searched your system and it shows a CD/DVD/RW.
So you can burn CD, DVD+R RW and DVD-R RW
So the most common DVD media would be the DVD+ media.
CD media would be all CD media. (info) RW: Re-Writable
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Apr 07, 2014 | Computers & Internet
Won't burn DVD data discs, error code 0x207
Have you looked at this from ACER: http://acer--uk.custhelp.com/app/answers/detail/a_id/3410/~/error-code-0x207-shows-during-recovery-dvd-creation I'm sure you already know it seems to be a common problem. Every post seems to point to Media type , can't use RW disk, +or-, seems kink of finicky which seems odd. Only use DVD+R or DVD-R.
Apr 02, 2013 | Acer Aspire 53362524 Intel Celeron 900 2....
What do + and _ signs mean on blank dvds
- RecordNow! can record only to the same disc type
it records from. For example, you can record a
DVD only to a DVD+R or DVD+RW disc, and you
can record a CD only to a CD-R or a CD-RW disc.
you were using DVD-R, so it won't work.
hope this helps
Jun 18, 2012 | Verbatim Blank DVDR Discs/DVD R Media -...
Ref. Toshiba VCR, model RDXV59DTKB2 I copy ,using the dubbing function, of VHS to DVD. The disc then works in this and most other VCR's but will not playback in my PC nor my portable DVD player....
Check if your DVD drive in your computor is the same type as your recorder. IE A DVD + or DVD -.
Some types of drive will not play the others. You might need to upgade your drive in your computer to one that will play nearly all formats.
Jan 01, 2011 | Toshiba Televison & Video
Roxio dvd disk type doesn't match project type
Check the following parameters
- Type of disk--> it must be a DVD RW disk (Read and write), if the media is only DVD R, you can't burn it
- Your DVD driver--> Check if it accepts DVD RW(-) or DVD RW(+) or both. With this information, check if the media matches the driver capability
- Roxio settings--> In the Main Menu select--> Disc--> Disk information--> confirm that the right driver is selected (drive D or E or the letter your computer uses for the DVD driver)
Nov 07, 2008 | Roxio Easy Media Creator 7
DVD+/- Gateway issue DVD won't burn DVDs but plays them
I had the same problem. I finally got a knowledgeable tech at Gateway who knew that a patch had to be downloaded. I'm sorry but I don't have the link anymore but you might be able to find it in there white papers now that you know that it exists
May 16, 2008 | Computers & Internet
Dvd recorder funai
I have fixed mine with the same problem , all it needed was the lens cleaned , i used a laser lens cleaning disc from maplin for 6.99 and voila good as new.
May 09, 2008 | Funai PY90DG DVD Recorder
Dvd playback
Some DVD players cannot play certain types of disks mainly -R discs. Check compatability in the DVD player's manual. Try using +R discs for peace of mind...
Aug 30, 2007 | Memorex (32025618) 25 Pack 16x DVD+R...
For still photos, which types of media can I use?
DVD-RAM 1,998 on a dual sided disc (999 per side) – This number will decrease if movies are recorded on the same disc.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Hitachi DZ-GX20A DVD Camcorder Logo
50 people viewed this question
Top Hitachi Video Cameras Experts
Damen Wong
Damen Wong
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
