2005 Aston Martin DB9 Logo
Posted on Aug 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WON'T GO INTO GEAR
I have a 2005 DBP that when i press the D button it just sits for a few moments & then the N button flashes with a sign on the dash that reads gearbox malfunction & something like parklock.
It has 17000 miles on it, is it still under warranty & what could the problem be ?
Anonymous
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on Jul 31, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
22321
Points
35
Don't west ur time go to the local dealer maybe its a clutch problem or the gear oil level or the gear cool oil..
its will be expensive if its not under the warranty
ROBERT GARCIA
Level 3:
  • Aston Martin Master 926 Answers
  • Posted on Apr 25, 2009
ROBERT GARCIA
Aston Martin Master
Level 3:
Answers
926
Questions
Helped
440597
Points
2747
Please check for your warranty i think that you have it
Light flashing O/D OFF
book vehicle in to be diagnosed and checked
possible faulty O/D sensor or switch
Kia sorento wipers won't stop
I had the wipers won't shut off, or turned on by themselves on my 2005 Kia Sorento. It about drove me nuts. I came across my solution by pressing every button I could find, eventually finding out what the mystery button to the right of the hazard button on the dash was for. (It's to defrost the front wipers by the way) You can investigate further if you'd like but it's not necessary if this works for you.
I simply pressed the button on, waited a moment and turned it back off. It stopped the wipers. They came back on about three more times over next few days and I repeated the process each time. It's been about three weeks since the last time I did it and I haven't had any more problems. This sound crazy or quirky I know and I don't pretend to understand it, but it's working for me. It beats the heck out of paying over $300 dollars plus labour for a new wiper switch . I priced them. Good luck.
KIA CERATO 2005 CAR AUDIO CODE
Your radio is in theft lockout, you need the security code that came with the owners paperwork new.
How To Reset Schedule A Maintenance in Mercedes 2005 E320
Switch on ignition. Cycle left steering wheel buttons till mileage and trip are displayed. Press reset button ( left corner of instrument cluster ) for 3 seconds until reset message appears, release and press again within a few seconds and confirmation will appear on dash. switch off ignition.
MY TOW/HAUL BUTTON ON MY GEAR SHIFT WILL WORK FOR
The lever "pivot" has broken the wire leading up to the switch. Replace switch (I believe you must purchase the entire lever)
8helpful
HOW DO I SET THE CLOCK IN THE BMW Z4?
between the tachometer and the speedometer on your dash, you have two buttons
"S/R" on the left and one with a clock on the right.
press the "clock" button for a few seconds until the hours (or --:-- if never set) appears
on the "screen" under the speed meter and the column sign flashes.
press the S/R button to increase the hours until appropriate.
press the clock button again to pass to the minutes.
press the S/R button to increase the minutes until appropriate.
press the clock button to confirm the time.
at that point you are all set, and the clock on the radio should be ok too.
Every time you jump start the car, you will have to reset the clock though.
1helpful
What is the "POWER" button for?
hi the pwer button on the gear shift basically lets the car rev higher between gear changes for overtaking etc
Top Aston Martin Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
john h
Are you an Aston Martin Expert? Answer questions, earn points and help others
