Question about Refrigerators
FRIDGE FREEZER WILL NOT RELEASE ICE CUBES
HI I HAVE A DAEWOO FRS-U20DAI SIDE BY SIDE REFRIGERATOR THE HAS AN ICE CUBE DISAPENSER. THE PROBLEM IS THAT WHEN THE TRAY TURNS IT WILL NOT RELEASE THE ICE CUBES SO THE TRAY KEEPS FILLING WITH MORE WATER UNTIL IN THE END WHEN ITS FULL I END UP WITH WATER ALL OVER THE FLOOR.
IS THERE SOMETHING TO PUT IN THE CUBE TRAY TO STOP THEM STICKING
VOTIT
  • 2071 Answers
SOURCE: Ice Cube Tray Sticks
53282922_1db7fdbcf7_m.jpgHeavy Frost on the Coils
This is good! This indicates a defrosting system failure which is a simple control problem. It also means that the sealed system (compressor, evaporator coil, and all associated tubing) is fine as wine in summertime. Defrost system problems are easy fixes that anyone with a pulse can do with maybe just a little help from their friends. The problem will either be the defrost timer (or Adaptive Defrost Control board, if so equipped), the defrost thermostat, or the defrost heater. To locate these parts in your fridge, check out these cool, interactive parts diagrams.
Posted on Jul 24, 2008
rickzilla
  • 706 Answers
SOURCE: ice cube tray not releasing cubes
The ice maker system is pretty simple.. A motor rotates with a gear reduction system and as it rotates... a switch is tripped when the motor reaches a certain point on its rotation... that switch lets water in for a prescribed period of time ( normally that is adjustable) and then as the motor rotates some more.. the ice tray has had adequate time for that ice to freeze and is positioned for it to be released,..at that time.. a small heating element is energized to release those ice cubes and the cubes fall from the tray into the bucket.. Chances are your heater is not working, unplugged or defective.. I would start by thawing everything out and getting the system free of any and all ice.. If after you've cleaned it all up.. and it still fails to release ice..you could be over-filling your tray and that freezes .. which in turn causes the system to fail too..You may need to adjust the fill level by throttle back on the water or if your system has a fill level control.. adjust that.. but first things first.. get the system back to a known good state.. ( meaning free from all ice ) so that you can monitor its performance,. Hope that helps...
Posted on Aug 16, 2008
ginko
  • 19396 Answers
SOURCE: Ice Maker will not release the frozen ice cubes from tray
The icemaker use an avaporator system with an heatinc coil and a fan to release cubes.
In your case either the heating coil or the fan in the icemaker must be replaced.
parts can be purchased from partselect.com.
Posted on May 31, 2009
aasc
  • 1606 Answers
SOURCE: Maytag ice maker will not release cubes
Sounds like it has a " seeping " water valve . Only thing to do is replace the water inlet valve . There is a certain amount of water to go into icemaker at fill . A seeping valve will let water continually drip into icemaker , making large cubes which icemaker cannot dump . A larger amount of seeping , will overfill the icemaker , and drip into the freezer and floor .
Posted on Aug 12, 2009
SOURCE: ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Posted on Feb 24, 2010
Ice maker problem daewoo frs-2031 IAL
I wouldn't buy a Daewoo fridge with Donald Trump's money!
Jun 27, 2016 | Daewoo Freezers
Hi i have installed my american fridge freezer DAEWOO FRAQ19DCB but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to t
The inlet water supply solenoid valve has two coils and valves. The icemaker valve is not functioning either electrically or mechanically. Best bet is to replace the complete assembly.
Jan 25, 2015 | Daewoo Refrigerators
Why can't I select cubed ice on my ge monogram fridge, all of the other buttons work fine.
the reason for this problem is a jam of ice inside the ice bin that will not let the knives that crush the cubes,and cant release to let cubes go by uncrushed,remove the ice bin,put the remaining cubes in a bucket,or toss,then check the ice auger in the bin and if theres a build-up of ice melt it with hot water,then thoroughly dry it,then replace this unit into the freezer,but do not use it until its cold again from melting the ice jam,then resume the ice making cycle
Nov 24, 2012 | GE Monogram ZISS420NRSS 42" Built-In...
Daewoo frs-u20dai service manual
my Daewoo side by side fridge freezer FRS-U2ODAI keeps leeking water from underneath and it says on screen DEODORIZER and FUZZY can u help
Apr 03, 2012 | Refrigerators
Fridge not cold enough and freezer not producing ice cubes
how does any tradesman(person) know how much its gonna cost before they even look at it.....
i would suggest you call a small,family run,electrical shop.
they have a reputation to uphold......
Jul 21, 2010 | Daewoo Refrigerators
The ice-maker in my Daewoo Fridge Freezer (FRS-U20DAI) is not working. The ice tray does not empty.
is there ice in ice maker but it wont empty?
the ice maker has built in heater underneath. thats how the ice detaches itself from the ice maker and the fingers rotate them out.. if you have ice in the ice maker then replace ice maker
hope this was helpful
Mar 27, 2010 | Freezers
Ice cube maker on daewoo american fridge freezer
Jul 19, 2009 | Daewoo Refrigerators
How to make ice cubes ?
Just fill pure water in the ice tray and allow it to cool for an hour your ice cubes will be ready. DO NOT OPEN IN THE MIDDLE TO SEE THE ICE FORMATION!
Jul 06, 2009 | Refrigerators
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
