Question about Casio Cassiopeia EM-500 Pocket PC
Broken screen I had the misfortune of finding that my casio em-500 screen had cracked. The device itself still turns on, however, the screen wont respond to the stylus. Is this an easy fix? Any help would be great! thx! ~Regis
    Master:
  • 551 Answers
Replacement of the digitizer, if the lcd is still intact. If that is damaged as well...sell it for parts, or get parts from another. The EM500 and E125 share the same lcd/digitizer.
Posted on Sep 05, 2005
I am missing my USB cable for the Cassiopeia Em-500. Where can I get one?
There is a casio supply store in NY that might have it. there number is 1-800-345-0537. Their name is American Perfit.
Hope this helps!!!
Sep 20, 2009 | Casio Cassiopeia EM-500 Pocket PC
Overclocking em-500
1) Back up your device since we will be removing both batteries from your PocketPC. 2)Remove all 5 screws (4 in the back and one underneath the rubbery grip sticker on the side). NOTE: Be very careful with the sticker on the side. I just pried it up with my finger nail to get it started, but the adhesive part split off from the rubbery grip. I then had to pry up the adhesive part from the side of my EM-500. I got them back together in the end, so no harm done - just something to look out for.
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
Casio em-500 deleting mail programs!!!
I believe they are in unit's ROM, which is non-reprogrammable. Hence, you won't be able to delete anything from there. On the positive side, they don't occupy your main memory, so there's really no harm in letting them dwell in your PDA. :)
Casio EM 500 + Nokia 7650
well there is a solution but im not too sure, but it is to get a cable that conects to ur phone and ur pda..that should work it not....there may be something wrong
EM-500 memory question (new user)
You can use any brand whatsoever. If you are concerned about compatibility - a genuine problem with some manufacturers - you might consider buying from a retail outlet & test it out on the device itself. Casio uses either Toshiba or Hitachi cards so that would be your best bet.
MMC/SD Cards
In most cases they are interchangeable except for the security feature which you don't need for storage on your EM-500. SD cards are faster in read write department as also they cost more due to security featurtes built in. In Casio cameras Casio recommends SD cards but I have been using MMC cards very successfully.
EM-500 Conection Problem
Upgrade Activesync and the PC's USB driver. Then you should be OK once you upgrade Activesync to V3.6 and then get the latest USB driver for your system. Good luck
128meg MMC for Casio Em-500
Did you put your mp3 files in the my documents folder on the mmc? because if you place it anywhere else other than my documents the won't play (thanks microsoft). Also, the mp3 files might need conversion in order to actually play. It happend to me also, the files on the mmc would play on my siemens sl45 phone but on the em-500 not, until i use the sl45 connected to my computer to transfer files to the mmc than play with em-500.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
EM-500 sync problem
There have been issues with the cradle PCB on the EM-500. Casio has redesigned the same added an IC & a few additional componentes. I had similar problems & simply could not connect through the USB port. Worked flawlessly with the accessory serial cable (direct connection - no cradle ). This also was on an XP system. See if you can wangle out a free replacement/fix for yout cradle from Casio.
EM500 replace touchscreen
They are in fact very easy to replace if you: 1. Are very careful not to damage the other parts 2. Can find a replacement Understand that the screen is actually two different components, first there is the digitizer which is the part that senses your touching the stylus part. It is a clear glass plate that sits in front of the color lcd unit (the other part). If only the glass is broken, then replacing the digitizer is a cinch. If I remember correctly, the digitizer on the EM-500 is the same as the digitizer as on an E-125. You'll have to check to be sure though. Anyway, it is not too hard, just needs steady, careful hands...and it helps to have a little experience taking these things apart...
Casio Cassiopeia EM-500 Pocket PC Logo
94 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Computer Links
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
