Question about Maytag PAV2300 Top Load Washer
WASHER WONT START
Maytag LAT2500AAE:
Washer worked fine on last load.
On next load would not do anything.
Power to washer is fine.
Does not start filling tub.
If I put it on spin it will not work either.
It is acting like no power is getting to machine.
There doesn't appear to be a main fuse visable.
  • 2 more comments
  • JMIV Aug 26, 2008
    Power to machine is fine.
    I removed door switch I have continuity between motor and machine contacts on the door switch on the contacts neut and line I have no continuity.
    Am I correct in thinking I should have it there?
  • JMIV Aug 26, 2008
    Also there is no fuse in the control panel
  • JMIV Aug 26, 2008
    Tub turns fine
    Pulley turns fine underneath
  • JMIV Aug 26, 2008
    No fuse that I can find electric goes directly to timer
  • 958 Answers
Hi JMIV,
since you can test continuity and there is no continuity at the plug when you tested it, try to open the upper console where the switches are mounted, you may find the electrical diagram of your unit and be able to trace why there is no continuity between the terminals of the plug.
make sure that when you test the plug, you have set it as if it is running normally,
close the lid, pull the knob if it is a mechanical timer then test the continuity,
from your diagram, i hope you can trace your wires.
i hope i was able to help you,
tnx 4 using fixya,
drcool
Posted on Aug 26, 2008
    Top Expert:
  • Maytag Master
  • 78,267 Answers
It could be that if a fuse or fusiable link has blown that a short circuit has occcured either in the washer motor or the control circuit board, bypass the board if possiable and power up the motor, then you will have but 2 issues left the control timer switch and the main circuit board.
  • Maytag Master
  • 19,396 Answers
The fuse is usually mounted on the control board when power connection comes to the board.
    Master:
  • 848 Answers
Try this start with the tub and basket, make sure there is not anything caught in between preventing it from spinning. Also check whether the belt is properly placed . Next would be heavy duty stuff like the thrust bearing and brake. The brake may not be releasing. You can check this by turning the pulley counter clockwise slowly and seeing if the transmission spins. If not the thrust bearing and brake may be bad........
    Brigadier General:
  • 3,614 Answers
Could be the control panel is faulty, you need to replace the control.
  • 1 more comment
  • micromaster
    micromaster Aug 26, 2008
    yes it could be there..if you check it has no continuity.
  • micromaster
  • micromaster
    let me know here again...
  • 89 Answers
Try to fill the washer with water manually then run the spinner, if it still does not work then you need to ask a technician to service physically the device because there might be parts needed to be replaced already.
    Genius:
  • 3,422 Answers
HI,
f your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
  • Priya darshan Aug 26, 2008
    You can have a look at the diagram for your model.Just click on the below link and once you see the diagram just scroll your mouse over the diagram to get detailed on every part and where it is located.
    http://www.repairclinic.com/0100_21.asp
Frigidaire Affinity Front-loading washer wont do anything
Check the wall socket with another electric gadget. Check your washer plug fuse. Finally open up the rear (after taking the washer power cord off the wall of course!) and disconnect and reconnect all wires and connectors one by one. Possible it could just be a loose connection somewhere. Sometimes happens due to vibration.
Click so pl if helped.
Apr 05, 2013 | Frigidaire ATF6000ES Front Load Washer
Maytag top loader not working
check water supplys okay and lid closed properly to activate lid switch....
Jul 01, 2012 | Washing Machines
My washer is not responding to anything
MAKE SURE MAGNET IS MAKING CONTACT LID TO FRAME
Jun 30, 2012 | Maytag Centennial MTW5800TW Top Load...
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
I have a Maytag LAT2500AAE top load washer. The
check the balance ring on the tub just below the tub cover and tub cover gasket which can be done from the top of the machine by removing the top cover,while doing this pull and push tub from side to side and see if it moves easier in certain directions, if it does you may have a tub spring broken on the tub leading to an un balance condition cause the springs stabilize the tub like a shock absorber on an auto, if this is it then you need to access the lower unit area by removing the front cover of the unit there are screws at the toe kick panel to remove this panel
Dec 08, 2009 | Kenmore 24032\24036 Top Load Washer
How do I change the washer belt on a Maytag Washer #LAT2500AAE
I figured out that the belt went on the bottom of the dryer. It was actually very easy to fix once I realized where the belt went. I made the mistake of opening the front cover of the washer first, which is why I did not see where to put the belt. Apparently, if the washer is not level (since I had too much for a load and it caused the washer to pull out from the wall), the belt shook itself loose.
Dec 03, 2008 | Maytag PAV2300 Top Load Washer
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer: will not start
plug a light into the washer outlet to check for elec current at this point before anything else.
Aug 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
MAV6200AWW WASHER DEAD.
its not a fuse its a mains capacitor/filter it is located next to your motor if this is faulty machine wont work it will either be a plastic cyclinder/a metal 1 about 4inches long with writing and numbers on it
Nov 08, 2006 | Maytag Atlantis MAV6000 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
217 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
