I am getting an error E3 which I turn on the C180 model copier....can't find anything referring to that error in the manual
Sorry it took so long. Your copier probably is similar to a Toshiba E series. The error code is paper jammed in the bypass section.
Use this link as a lookup to the error codes
Use 4501 under Toshiba to find the error codes.
The C180 was made by Panasonic and is no way comparable to Toshiba. The E3 code should flash with another code (01, 03, 11,... etc) This other code is required to diagnose problem and is a service issue. If it is an E3 10 or E3 11 there is a corona wire dirty or broken, these are the most common E3 codes. I'm not sure about other codes, you may have more luck looking for info on the Panasonic 7718 just remember to refence both parts of the code
Can you send me a picture of this copier. Pitney Bowes at the time never made their own copiers. They just put their name on someone elses. If you send me a pic I can tell which one it is.
E-mail to [email protected]
