Question about Brother IntelliFAX 4100 Laser Fax
Black strip On outgoing faxes, there is a 2" black strip down the right side of the paper. We have cleaned the machine and changed the toner and the problem still exists. Please let me know what else the issue could be. We are located in Clinton Township, MI if a tech is needed. Thank you.
  • JGCISNE Aug 28, 2008
    BLACK STRIP PROBLEM ON THE EDGE OF ALL INCOMING FAXES ONLY
    Genius:
  • 2,120 Answers
Lift up the operation panel and look for wite-out on the scanner glass.
Posted on Sep 01, 2008
Black streak down right side of outgoing received fax
clean the scanner, it may have white out or some other obstruction blocking it
Jun 02, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
How do i change the fuser unit on my canon l295 fax/printer
Remove upper cover(4screw), than remove axis with few small rollers, than remove from right side toner crg holder ( black plastic peace on right machine metal side ), unscrew 2 screw on black cover, remove it, unscrew two screws on metal cover ( beneath black plastic cover that you removed )
May 10, 2010 | Canon L220 Plain Paper Laser Fax
Black vertical Stripe
Move the blue slider on the drum cartridge side to side 10 times.
Jan 30, 2009 | Brother IntelliFAX 5750e Laser Fax
Black line
Probaby an LED segment is burned out in the scanner assembly.
Dec 22, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
2" BLACK LINE
1- itis on the Scanning unit open and look for a thin strip of glass, clean
2-the scanning unit is bad
Assuming it's only on Outgoing Fxs and not incoming as well ( that would indicate the drum)
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Black stripe down one side of every fax
On my Brother fax machine, there is a blue plastic cleaning thingy on the toner cartridge used to clean the metalic wire. If you leave it on the wrong side after cleaning, you get a thin black strip down the edge of every page. Slide it over to the other side and problem goes away.
Jul 08, 2008 | Ricoh 3310LE Plain Paper Laser Fax
Black lines going across the pages
1 check the toner cartridge see it has toner rings on it
2 open - remove toner check the bottom for a thin glass strip clean
Jun 12, 2008 | Panasonic KX-FL541 Plain Paper Laser Fax
Black line on faxes
Check carefully the glass, a very small point of ink or anything else can cause the black stripe. usually  it is that the problem. use windex to clean it.
Apr 15, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Right side of faxes (or copies) have 1-1/2" black line
Try changing the Drum Unit again....it cannot be anything else besides a worn out drum cleaning blade.
Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
111 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
