Question about HP LaserJet 3330 All-In-One Printer
Help It wont stop making noise it sounds like it is trying to copy but it isnt and wont stop.
This may be your problem, i posted the solution at in a different area a little while back.
good luck
http://www.fixya.com/support/t784374-scanner_error_message_hp_laserjet_3030
its the 3030, but it works for both printers
Posted on Sep 15, 2008
Polo GTI wont start
sounds like the starter isn't engaging-it needs to be replaced or it will destroy your fly wheel if you don't take action-and then you'd have to have it replaced-Denny
Dec 03, 2013 | 2009 Volkswagen GTI
My car makes an explosion sound.. but its performance isnt being affected.. could it be the ******?
The exploding noise need more info.
The grinding when you stop is your brakes, there should be a tab thats suposed to make a squeil sound and the brake worn out has a metal to metal scrape that you should feel isnt right get it replaced asap so its just the brakes and not the rotor or the drum.
Sep 18, 2012 | 2004 Chevrolet Silverado
I have a 1998 gmc Sierra standard 5 speed started running funny then just stopped moving starts good engine runs fine clutch engadges but when in gear now revs up as if it were in neutral Also before...
i think your clutch has worn out ,it needs a new clutch,the water noise is a air lock possibly so try topping the rad up some more and hopefully this will stop the noise but if engine isnt overheating then do not worry about it too much ,
Feb 12, 2011 | 1998 GMC Sierra
My 1990 f150 truck wont start, its making a popping noise
If it sounds like backfiring you may have some spark plug wires mixed up.Also you may want to check the compression in the engine cylinders.
Feb 09, 2010 | 1990 Ford F150
It is not spinning
are you sure the belt didn't break, sounds like the motor is turning though, you'll find out when heating element gets too hot from drum NOT turning and drops out until cool
Sep 24, 2009 | Dryers
Machine wont spin or drain.makes ticking noise when in spin or wash cycle then stops can you help?
if the timer is still running (ie the ticking noise) and it isnt doing any thing you may have a broken coupling - belt or the motor is shot
Aug 23, 2009 | Washing Machines
Audi A4 1998 1.8T
Sounds like a sticky valve or lifter, and the oil just isnt getting up there so quickly
Nov 05, 2008 | 1998 Audi A4
HOW CAN I STOP THE COPIES FROM SHIFTING EVERYTIME?
Wide blank area on Lead Edge, or Misregistration possibly accompanied by noise. The noise may be described as a clicking, buzzing noise while making copies. The noise may stop for short periods while making copies. Cause:
The registration Sol. pawl is not capturing the clutch to keep it from turning. This is caused by the Registration Sol. return spring being out of position, or when installing the Main Drive Assy., the pawl is "trapped" in the actuated position.
Apr 16, 2008 | Xerox WorkCentre XD120F Laser Printer
Samsung washing machine WA71N2
can you hear the pump making any noises,if you can (humming sound)then it may be blocked with lint,coins etc.if the pump isnt making any noises then it may be faulty or a broken wire to the pump or you have a no drain button pressed in . hope this helps
Mar 07, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
HP LaserJet 3330 All-In-One Printer Logo
41 people viewed this question
Ben Johnson
