I have a laptop that i have only used a few times, and when it boots up it gives you the vista set up screen, with is very simple to complete. When i go to reboot the laptop always after i have completed the full vista installation, there is an error and pc angel kicks in saying that the system needs to do a full factory recovery of the system. It will clear any errors in the registry, even thought there shouldn't be any as theres no programs on the laptop other than the vista program. When the system reboots its self and you go through the vista set up once more, when you reboot again at the end of the set up, the same thing happens. I've tried to do a complete format from within the bios but this pc angel pops up on the boot screen and re-creates the original partition. the only ither idea i can think of is to by a IDE converter cable and extract the hard drive from the laptop and format it from one of my other pc's but this seems very long winded.....is there any easier way of getting rid of pc angel or at least getting the Operating system to work as it should?
    Sergeant:
  • 226 Answers
PC Angel is a program written by another company other then your OEM that built your computer and your OEM and several other OEMs have contracted the PC Angel software program to be their recovery program of choice. The entire recovery process is based on PC Angel in your computer.
Your problem sounds like the installation process is corrupted leading to faulty registry settings that are detected each and every time the computer comes up for reboot. Since the recovery process is based in your recovery partition ( hidden partition ) it would be unwise to attempt a direct fix as chances are, only more corrupton would be created.
However there is one option that could work. Get with your OEM manufacturer and tell them of the problem. Let them know that you have a strong hunch that your recovery partition is corrupted and that you need a recovery DVD provided by them for a very nominal fee, mostly packaging and shipment, maybe not even that.
Once you get the recovery DVDs shipped to you, you can erase and write over the old ( corrupted ) recovery partition with the aid of the new recovery DVDs and this should fix your problem.
How do I know that, because I have personally had to endure it.
PC Angel sucks because it only allows you to make one copy of your recovery partition and if that doesn't get written exactly right to your DVD, you are out of luck regarding a second opportunity. There are tricks around that too, but it requires a very long explanation. Just try to get a DVD copy of your recovery disks from your OEM as that is the best single answer possible.
Posted on Aug 26, 2008
    Sergeant:
    Novelist:
  • 166 Answers
PC Angel will keep coming up when you try and restore the system with the discs you have. Its an integrated solution for PC manufacturers to deploy there systems. The issues you are having usually only come about when you are either trying to install the software on a system it wasnt intended for it does read the hardware and check it the correct computer. or if you have a corrupt disc. Couple of things you can do, firstly you can contact the computer manufacturer support and tell them you are having the issue, or you can delete the disc partition and re-install vista from a different disc. Deleting the partition is easy and just requires software, do a google for free partitioning software and you wil find it. As for getting an IDE converotr, you might find that the laptop if its a new one, has an ATA drive and not an IDE, most of the new laptop have ATA drives installed.
ACER EXTENSA 5420 BIOS Alteration Problem
restar the computer HOLD the key CTRL +F2 and ready.
God bless you
May 22, 2013 | Computers & Internet
Tip
How to Dual Boot Windows 7 with XP or Vista
If you're dying to try out Windows 7 but aren't ready to give up your installation of XP or Vista, let's take a look at how to dual boot Windows 7 with XP or Vista.
Step 0: Download the Windows 7 Beta and Burn It to a DVD
Assuming you've already downloaded a fresh copy of Windows 7, you'll need to burn it to a DVD in order to do a fresh installation. To handle this task, grab a copy of the most popular CD and DVD burning tool ImgBurn, burn the ISO to a DVD, and move right along to step 1.
Step 1: Partition Your Hard Drive
Before you go installing Windows 7, the first thing you need to do is create a new partition on your hard drive to hold the new installation of Windows. Partitioning your hard drive will vary depending on whether you're running XP or Vista—namely because Vista has a partition tool baked in, XP does not.
Partition Your Hard Drive in XP
To partition your hard drive in Windows XP, you'll need to download some sort of third-party partitioning software. There are a lot of options available, but I prefer to stick with the previously mentioned GParted live CD, a free, open source boot CD that can handle all kinds of partitioning duties.
To use it, just download the GParted Live CD, burn it to a CD, then reboot your computer (booting from the disc). You'll boot right into the partitioning tool. HowtoForge's previous guide to modifying partitions with GParted is a great place to start, but it's a fairly basic procedure:
Resize your current OS drive to free up enough space for a Windows 7 partition (the minimum system requirements ask for 16GB).
Create a new partition from the newly freed space.
Apply your changes.
Partition Your Hard Drive in Vista
The folks at Redmond were kind enough to include a disk partitioning tool in Vista if you know where to look. So go to Control Panel -> System and Maintainence (skip this one if you're in Classic view) -> Administrative Tools -> Computer Management. Once you launch the Computer Management tool, click on Disk Management under the Storage heading in the sidebar. It's partitioning time.
Luckily we've already gone down this road before in step-by-step detail, complete with pictures, so check out our previous guide to creating a new partition in Vista. In a nutshell, you'll need to shrink your current OS partition to free up at least 16GB of disk space (per the Windows 7 minimum system requirements), then create a "New Simple Volume" from the free space.
Step 2: Install Windows 7
Now that you've done all the heavy lifting, it's time for the easy part: Installing Windows 7 on your new partition. So insert your Windows 7 disc and reboot your computer (you'll need to have enabled booting from your DVD drive in your system BIOS, but most PCs will have this enabled by default).
Once the DVD boots up it's a simple matter of following along with the fairly simple installation wizard. When you're choosing installation type, be sure to select Custom (advanced) and choose the partition you set up above. (Be careful here. Choosing the wrong partition could mean wiping your other Windows installation altogether, so make sure you pick the new partition you just created.)
After you select the partition, go grab yourself a drink and let the installer do its work. Windows will run through some installation bits, restart a few times in the process. Eventually you'll be prompted to set up your account, enter your license key, and set up Windows. Keep your eyes open for fun new Windows 7 features, like your new homegroup (and the accompanying password). When it's finished, you're up and rolling with your new Windows 7 installation.
Congratulations! You should now have a new entry for Windows 7 on your boot screen when you first start up your computer. You've now got all the tools necessary to dual-boot Windows 7 and XP or Vista—or even to triple-boot Windows 7, Vista, and XP.
on Dec 08, 2009 | Computers & Internet
Sir i had bought sony vaio laptop which showing text; boot mgr missing and press ctrl alt del to restart, pls give me a solution
http://cyberst0rm.blogspot.com/2007/04/how-to-fix-bootmgr-is-missing-in.html
I assume you are running vista because bootmgr.exe is used to run vista from startup. "bootmgr" is short for boot manager, and without this, your computer simply doesnt know how to start vista from your hard drive.
To fix it is quite simple. First of all go into your BIOS menu (usually press F2 or DEL when prompted when you turn on your pc). Make sure your cd/dvd drive is set to be your primary boot device. This way you can run your setup disk in the next step.
Insert your Vista install disk and restart your system. Press any key when prompted to begin running the dvd. Wait for it to give you a list of choices. This may take a while as it often stays a blank screen for some time. Choose "repair", and the setup will auto detect your operating system. It will also fix your bootmgr.exe at this point. If it does not, you can go on to the next screen and choose "startup repair".
Aug 20, 2010 | Sony Tablets & eReaders
How to reset laptop vista to factory settings
Try my steps and let me know about it:----------- Hope they will help you:
1. Copy all your files and documents to an external storage device.
2. Shut down the computer.
3. Turn the PC back on and hit the F8 key repeatedly until the Advanced Boot Option Screen appears.
4. Click "Repair Your Computer" if you are not already on it and then press ENTER
5. choose your country and click OK
6. On the "System Recovery Options Screen" click "Restore Application" which is the last option.
7. Follow the on-screen instructions
8. When prompted, click on "Full Factory Recovery"
9. "Next"
10. Click "Yes"
11. you will notice for a while it seems like nothing is happening, give it some time.
12. After some minutes, recovery will complete and you click "Finish"
Sep 19, 2009 | Toshiba Satellite Pro L300-EZ1005X...
Hp Laptop Wont Boot
Hey dear,
Your operating system got crash. Use backup CD.
Turn on yr lappy. manually open the cd rom from right side of leptop. Put CD in. then wait for few seconds. u will see the screen then follow the instruction and re install the entire windows.
Sep 13, 2009 | HP Pavilion dv6000z Notebook
I forgot my password for my laptop dell inspiron 1720
This works with windows XP or Vista-
Windows Vista Repair through DVD Windows Vista comes with a very handy feature from Windows ME days -- System Restore. Vista's System Restore is far more sophisticated than its previous iterations and can be of a real help here. 1. Just pop in the Vista DVD, make sure your BIOS is able to boot (start) from DVD-ROM first.
2. Press any key to boot from DVD when asked.
3. Set the Language to install, Time and currency format and Keyboard or input method
4. Now click Repair your computer, select the operating system that you want to repair, and then click Next.
5. Click System Restore, and then click Next.
6. Click the restore point that was a day before you changed the password, and then click Next.
Doing this will set your computer back in time to the particular date when it was working fine. Don't worry, you won't lose any data -- only that any settings or programs installed after that date will not be accessible anymore. All you've to is re-install and redo any settings that you did.
7. Confirm the disks that you want to restore, and then click Next.
8. Click Finish, and then click Yes when you are prompted.
9. When the System Restore process is complete, hit Restart computer.
10. You can either remove the Windows DVD or just don't hit any key on the keyboard when it asks again to "Press any key." The computer will start much faster if you remove the Vista DVD.
11. After the computer restarts, click Close to confirm that the System Restore process has finished successfully.
12. After you log on with the old password, change the password for the administrator account if you like.
13. This step is most important -- Remember the password this time.
14. Restart the computer to make sure that your new password works fine.
Mar 26, 2009 | Computers & Internet
I have a new Toshiba Satellite A210 with Vista Home edition installed . I downloaded and installed Windows Vista OS patches to bring machine up to date. Now when I boot the machine, the windows shows the...
hi philipQ
Did your laptop come with restore CDs?, if it did, then i suggest you to a complete system restore. and see if the problem is solved.
i am always here
Thanks
RAhUL
Jun 18, 2008 | Toshiba Computers & Internet
Toshiba TE2100 blank laptop screen
Try holding the Fn key down and then press the F5 key a few times, waiting a few seconds each time to give it a time to switch between display modes.
May 29, 2008 | Toshiba Tecra 8100 Notebook
Crashed Widows XP on my sahara laptop
it sounds as if you the system as you say has failed, you can use a friends copy of XP but use your product key number on the underside of your laptop. Secondly, the vista CD may be an upgrade cd but you will probably find that it will do a complete install as they are normally the same cd, just set your cd drive as first boot device and then run the cd,select new installation and not upgrade; i have an upgrade Vista cd but installed a full operating system on another partition, therefore it wasnt an upgrade but it still worked.
Sep 25, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
