Question about Bosch Axxis+ WFR 2460 Front Load Washer
Motor not running.
Our motor in our Bosch wfl 2060 cu is not working. I can order a new motor for $188.00 but I want to make sure the motor is bad first. I tested it outside the machine with 120 volts trying the different terminals on the motor and got no results. With the motor in the machine the only reading I was able to get was with one end of my tester on the ground wire and the other on either one of the brushes I get a reading of around 23 volts. I discovered a penny in front of the pump could that have caused a sensor to go bad? The machine continues to run through the cycle and pump out the water at the proper time but the motor does not respond to agitate or spin the cloths. The armature is dirty from the brushes. The brushes are about 1/4" long and the machine is just 5 years old.
    Problem Solver:
Hello
if your brushes are only 1/4" long, I would replace them. The symptoms sounds like worn brushes.
Posted on Dec 28, 2008
What are WFL 2060 fault codes
Bosch WFF washing machine error codes:
E1
- The door is not closed and cannot therefore lock.
E2 - Washer will not fill with water.
E3 - Washing machine not heating.
E4 - Washing machine won't empty.
E5 - Fault in the motor drive circuit.
E6 - Unexpected heating.
E7 - NTC thermistor open or short circuit.
Please note that the codes for the WFF range of Bosch machines differs from other ranges.
Sep 04, 2014 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Washer, not spinning. Belt looks ok, front filter removed and cleaned. Previous answers say motor brushes, how are these looked at? Access through the back, would prefer not to take...
IF THERE IS BLACK DUST UNDER THE MOTOR IT IS USUALL DEAD. YOU CAN REMOVE MOTOR FROM THE BACK I HAVE DON IT. YOU NEED A METER TO CHECK THE MOTOR. I CAN HELP.
Apr 25, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Motor not turning at all. Water goes in and pumps
Since you say relay sounds are heard, it shows the command is OK. The power to the motor is not reaching. It could be relay contact problem.
If you have a option of only spin, try this option. If it works the motor is OK. Otherwise you have to trace the power line and test it through a electrical line tester.
Apr 01, 2010 | Bosch Axxis WFL 2060 Front Load Washer
The drum stopped turnig and there seewms to be no life in the motor on our BOSCH Maxx WFL 2060 does any one have any idears. Thanks
you need to test the motor to see if voltage is getting to it.. if yes change brushes or motor complete...01179512835
Dec 30, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Lights come on,door locks ,nothing happens on my bosch 2060 uc washer, sweetie says "it was making a funny noise the last time it was working" while it was spinning . thanks!
the engine maybe has no connection or motor is bad thats why wont start up,check if it belt is good ,if need more info let me knw,if my info was of any help to you please comment me ,thank you.
Sep 02, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Is used Bosch Axxis WFL 2060 with door replaced a safe bet
not a bad price (poss a little bit high) but i would want to see it running on a warm wash first.
Mar 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2061 motor starts running and then stops
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace pkurdnirund@hotmail.com , peacepattaya@gmail.com
Nov 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washer carbon brush replacement
Remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws securing motor.
Lever back motor with screwdriver, remove motor..Carbons at opp end to motor pulley, remove and replace same.
Aug 27, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFL 2060 front load
bad belt bad motor bad motor control unit bad ccu or wires un plugged if you can hear the motor rum check belt one time i had a nail jamming the tub through the holes in it like to never found it in that stainless steel tub lol
Dec 28, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
173 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
