Question about Minolta magicolor 2200 DeskLaser Printer
The top feed on my printer will not close nor can I make copies through the top feed
  • 210 Answers
You so need to be specific about the printer for this one. However, ...
Fully open the top feed unit cover. Examine and/or move around any movable parts. One of these parts is likely in a temporary position intended for clearing paper jams and needs to be returned to the normal position.
Posted on Sep 11, 2009
What is an adf cover
ADF cover refers to the Automatic Document Feeder cover. The ADF feeds your originals to the copy glass. The cover is opened to remove a jammed original. Just make sure the cover is closed.
Feb 20, 2015 | Office Equipment & Supplies
Black vertical line down the middle of my copies? This only happens when using the feeder.
theres a good chance that excess toner or Rubber degredation is what is causing your Black line/band,
The Manual feed tray Uses A feed roller and a Seperation Pad
If toner has spilt on to the top of the manual feed Roller Housing theres a good chance it may be Seeping on to the print paper Via the Feed roller
Instructions:-
open tray One at the front of tray one is a Closed Hatch which can be opened Upwards using the finger release catches on either end. Once lifted upwards the Manual feed roller should be clearly Visible - Rotate the feed roller until you can see the blue lock plate ho;ding the fed roller in place, insert a flat blade screw driver an d twist gently until you hear the lock plate release , remove the feed roller. You should now see the Offending Seperation pad. Cleaning the Seperation pad should be done using a Rubber restoration Liquid and LintFree Cloth. Use the same on the Feed roller . refit roller to tray and close and lock the Blue plate .
close down the Service Hatch and return to machine -
You may need to run several pages through tray one before all tread marks Dissapear
Sep 13, 2013 | HP Color LaserJet 5500 Printer
MACHINE SNATCHES PAPER AT BOTTOM RIGHT CORNER WHEN PRINTING OR COPYING AND DOES NOT FEED
A hard reset of the printer may clear the error. Here is how to perform the hard reset:
1.Shut down the computer.
2.Open the top cover of the printer and remove the print cartridges.
3.Close the top cover of the printer.
4.Press the power button on the printer to turn the printer off.
5.Disconnect the communications, (USB or Parallel), cable from the back of the printer.
6.Disconnect the power cord from the back of the printer for one minute.
7.Reconnect the communications cable to the printer.
8.Reconnect the power cable to the printer.
9.Press the printer power button to turn the printer on.
10.Open the top cover and reinsert the print cartridges.
11.Close the top cover and print the calibration page.
12.Restart the computer.
Let me know if you need more help
Mar 04, 2011 | Canon PIXMA MP190 All-In-One InkJet...
How to clear adf paper jam?
adf is the top part of the printer from where you feed the paper for copying. adf is automatic document feeder. open the top cover and see if there is any paper in it, remove the paper and close it again and it will reset the paper jam.if it doesn't reset then there could be a small piece of paper stuck somewhere.
Jan 06, 2011 | HP LaserJet M1522nf Multifunction Printer...
HOW TO ALIGN SCAN IN A PAPER WHEN COPING
Two ways
1-just lay the paper on top facing up and hit copy and it will feed in to the rollers and print
2-open the scanner, and lay paper face down using the built in marker, "edge", and close lid hit scan
May 17, 2010 | Lexmark X2500 All-In-One Printer
When using top feed I get a line in the copies
Check the small **** glass in the left side of the printer under the top feed for dirt, ink, whatever. Clean it with windex. That should solve your problem. The "whatever" is right in the path of the scanner, and the scanner is seeing that as permanent spot, which ends up as a line on copies.
Apr 21, 2010 | HP LaserJet 3055 All-In-One Printer
Line when we fax or make copies from the top feed
clean the narrow strip of glass to the left of the large glass.
razors
Apr 10, 2009 | Brother MFC-9420CN All-In-One Laser...
Sheet feed won't work
When you reinstall the blue plastic piece underneath, the white plastic sheet that closes over the glass must hang over the blue plastic piece, not tuck under it.
Mar 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
Scanning tray not working
Check that the hinges that are on the ADF (the bit that you can lift to reveal copy glass) are not broken, the left side hinge breaks, causing the ADF switch (also on left) to not close, causing problems like yours.
Oct 03, 2007 | Brother MFC-8440 All-In-One Laser Printer
Minolta magicolor 2200 DeskLaser Printer Logo
50 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
