Question about Hitachi DZ-GX20A DVD Camcorder
How long does it take to finalize? Can I finalize on other recorders?
    Master:
  • 473 Answers
The finalizing time depends on the remaining time on the DVD-R disc; Approximately 8 minutes to finalize with 20 minutes recording time on disc Approximately 3 minutes to finalize with 10 minutes recording time on disc Approximately 2 minutes to finalize with no recording time on disc. DVD-R discs recorded on the DVD-Camcorder cannot be finalized on other DVD-R Recorders or PCs.
Posted on Sep 05, 2005
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Need to know how to finalize recorded disc so that it can be played in regular dvd player
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Recorder.
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
Mar 22, 2011 | Philips DVDR75 DVD Recorder
I cannot play burned dvd's from this system in other dvd players becahse I cannot finalize the dvd. How do I finalize?
The recording may have used all the media on the disk because you let it run until it was full.
Now, there is no room to finalize the disk.
Play this back on the machine where it was recorded while recording it to another DVD recorder..
This time, BE THERE to stop the recording.
Set the recorder to a speed that leaves at least 10 minutes extra space for finalization.
Jan 31, 2011 | Pioneer DVR-RT500 DVD Recorder/VCR
DURNING FINALIZE MODE IT STOPPED WITH1:30 LEFT--- THEN I TURNED IT OFF AND TRIED AGAIN TO FINALIZE AND IT CAME UP WITH A READING OF---REPAIR--
That's a normal response to an interrupted Finalization.
http://www.retrevo.com/support/HHB-CDR830-CD-Players-manual/id/3875ci874/t/2/
The recorder was switched off/unplugged after recording without ejecting the disc. The recorder could not write essential recording information onto the disc.
While REPAIR is displayed, the recorder automatically examines the recorded area of the disc and updates the track numbers and recording time data. This process takes about 40 minutes for a fully recorded disc. Finalization or further recording is possible once the REPAIR message disappears.
Jan 23, 2011 | HHB BurnIt CDR830 CD Recorder
Problem with Finalizing Disc
When you insert the disc what does the recorder display after it examines it (Reading TOC)? - CDR, TOC, CDR-W, NO TOC?
It should know the disc is not finalized and let you either record more on it or finalize it.
If not, and you need to recover the 4 tracks try loading the disc on a DVD player. My old Pioneer will read unfinalized CDR-A's so I can digitally copy what's on them back to another CDR-A.
Apr 13, 2010 | Tascam CC-222mkIII CD Player / Recorder
Do I just push finalize to finish the burning of the cd?
after you've finished recording press 'finalize' the recorder will then get ready for finalizing and then a countdown time will appear in the display eg '1:20' once this appears press 'play' and the recorder will start to finalize and the digits will count down to zero, once this has finished, your disc is finalized.
Feb 01, 2010 | Pioneer PD-R555RW CD Recorder
I burn dvd -r and dvd+r and it will not play on it
It is possible that the disks are not finalized. You may need to configure it to auto finalize, which is off by default. It would be impossible to have more than one title on a disk if you always auto finalized. Check your manual, and finalize your disks. Many times marginal disks will play OK in the unit they were recorded on, but not so well in other players. The media (disks) could be the problem as well. On a side note, the DR410 will NOT burn DL (dual layer) disks. I hope this helps and good luck.
Oct 28, 2009 | Toshiba DR410 DVD Recorder
DVD-RW will not finalize after recording
There is no solution for your problem. I thought my 4500 wouldn't finalize also but what is happening is that it didn't record on the disc you used. This is an older model unit and will not record on 16x discs. I believe you are boinked.
Feb 13, 2008 | Sansui VRDVD4005 DVD Player/VCR
Finalizing a recording
After you insert your DVD wait till recordings page comes up then press EDIT key then press left Arrow then Down arrow to FINALIZE..
Jan 19, 2008 | Cyberhome DVD Recorder - DVR1600
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Hitachi DZ-GX20A DVD Camcorder Logo
1,441 people viewed this question
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
