Question about Moultrie MFH-DGS-100 Digital Camera
Sd card locked
I always have this message I try different kind of sd card but it does'nt work I try my sd card in my other dgs 100 and it works do yuu have a solution
Don't worry guys if you can change the tire on yout car you can fix the SD CARD LOCKED PROBLEM.
You will need a set of mini phillips screwdrivers (everyone has a set in there box)
Open camera door note the tiny scews I think 4~5 of them also two screws that hold the back-up watch battery. remove all of them.
there are more screw inside just take your time and find them.
Carefully lift out the guts and you will see a set of contacts along the side of the SD CARD SLOT.
You can slide your sd card in and out of the slot and note that the contact point open and close.
the reason your card reads LOCKED is because the contact points are dirty I used fine sandpaper
to clean them up after I done this the camera worked perfectly again. The whole job took all of 15 min to preform.
Posted on Sep 23, 2008
SD card error. how do I fix it. reformatted cards.
Are they all being used on one device? If so try another device? If they do not work on multiple devices we would recommend trying to reformat the cards in a card reader attached to a PC/MAC.
Sep 15, 2014 | Moultrie MFH-DGS-100 Digital Camera
Note if sd card is installed is on the screen wont advance past that DGS 160. I have tried different SD card, hard booted, changed batteries, when I plug into computer interface, it doesn't recognize ...
Do you mean the DGS I-60? What size memory card are you using? The I-60 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Sep 15, 2013 | Moultrie MFH-DGS-200 Digital Camera
SD card Locked
The error code 000060 means SD card locked. The switch on your card may be unattached internally. Try a different card.
May 17, 2010 | Moultrie MFH-DGS-200 Digital Camera
Moultrie MFH-DGS-200 .... says SD Card Locked on
ck postion of switch on side of SD card...should be pushed toward contacts
Oct 23, 2009 | Moultrie MFH-DGS-200 Digital Camera
My camera is saying that the SD card is locked and we have an empty sd card
On the edge of the the SD card there is a small sliding switch that locks the card from erasures, formatting and loading. I may be in the locked position so slide it to the opposite direction then try it again.
Aug 23, 2009 | Moultrie MFH-DGS-100 Digital Camera
Moultrie DGW-100 won't read sd card
check small switch on side of SD card; should be pushed toward contacts.Using the USB cable provided with cam, PC SHOULD RECOGNIZE DEVICE...might have to go thru windows explorer to find it, then use windows media player, or other, to open.
You are running 98 or later, right?
Apr 11, 2009 | Moultrie MFH-DGS-100 Digital Camera
Sd locking
I had this problem also. To solve the problem I blew into the slot where the card goes and it then read the card. If dirt gets into the port it causes the sd card to lock. You may have to use a pressurized can of eletronic spray to clean the port.
It worked for me.
Dec 24, 2008 | Moultrie MFH-DGS-200 Digital Camera
Screen reads SD CARD locked
I have 17 of these cameras and for some reason after a while some of them develop this problem. It is very frustrating but I can usually get them to work by taking disk out, turning on camera, put in auto mode, wait for delay to switch to ready then put card in. I works most of the time and if not turn it off and keep trying. Some kind of glitch in the computer I guess. Hope this helps.
Nov 23, 2008 | Moultrie MFH-DGS-100 Digital Camera
Camera not working
Format the card on a PC. Ensure card is not over 1 gigabyte
Sep 08, 2008 | Moultrie MFH-DGS-100 Digital Camera
Camera will not work with sd card
Had the same problem, blew out the card slot with air and fixed it. Apparently poor contact points with the card.
Oct 07, 2007 | Moultrie MFH-DGS-100V2 Digital Camera
Moultrie MFH-DGS-100 Digital Camera Logo
168 people viewed this question
Top Moultrie Cameras Experts
AZBen
AZBen
Steve
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
