Magnavox TV: Somehow the record button on the remote will not record VCR. It ejects the tape and does not record. Please help. Thank you.
    Scholar:
  • 62 Answers
Does the record button on the VCR work? If yes, then the problem is most likely related to your remote controller. Do you still have the manual? In the back of the manuals they usually provide programming codes for the remote - you could try reprogramming it or using a different code.
If on the other hand the record button on the vcr doesn't work either and also causes the tape to eject then you know the problem is on the vcr side. Is the tape write-protected, assuming it's a VHS system is the write protect tab on the tape removed?
Posted on Aug 26, 2008
  • 2,326 Answers
Try Using a new VHS tape. If the new tape ejects when press recording, the recording switch inside your VCR could be defective.
Let me know if you require further assistance.
I have a Magnavox Digital Video Disc Recorder & Video Cassette Recorder , Model No. VM426MG9A. I bought the unit in August 2010. When I go to record a program, it seems OK but when it starts...
The recording set-up must have been program to record only in 5 minutes. You could play around with the remote and try to enter the record set-up. The problem with the VCR must be a worn-out belt or a dirty loading mechanism. You could try to replace the belt or clean the surface area where all the mechanism slide together or make contacts and put an small amount of recommended grease or petroleum jelly.
Jan 03, 2011 | Philips Magnavox DVD+R/+RW Recorder/VCR
Stuck VHS Tape in Samsung TV/VCR Combo
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
I am attempting to record from a VCR tape to
I have a Magnavox MWR20V6 and I am attempting to record a Tv show but when I play it back the recording is just black.
Jan 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
VCR WON'T RECORD
you may have the outputs hooked up correctly however you may need to set the inputs to the selected type of cable you are using. S video 1 cable or video input witch is an rca adapter yellow in color. you will find these setting in the "setup section" on the remote set up button will get you there and then input or source.
Dec 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Magnavox TV/VCR COMBO
Im thinking that maybe you a have a timer recording set. The whole unit wont function at all if you turn it on via power button (remote or unit). There should be a button at the top of the remote called 'timer set' pressing this will disable that mode and allow complete use of everything. but make sure u press timer set again when powering down, otherwise simply turning off the machine will leave the timer recording disabled.
Oct 17, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
MAGNAVOX DVD/VCR RECORDER
I have been using my machine with no problems, until recently. The machine will not stay on more than a few minutes when I try to use it, either watch a tape or tape a show. It starts, then just shuts down. When the machine is turned back on it ejects the tape????
Can you help, please.
Thanks
Sharon
Jul 07, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't get movie to play
Are you trying to record on a protected tape? Does it do this on all tapes?...accordianman
Feb 18, 2008 | Emerson EWV403 VHS VCR
Remote Buttons
Press the VCR button first then press open/close
Nov 22, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
