Question about Netopia 2247NWG-VGx Wireless Router (2247NWGVGX)
Netopia router to strict
When i try 2 play gta4 it says router/nat is 2 strict. it is really anoyin.i looked every were but i cant get help.i hav a eircom router and a ps3.plz dont be 2 high tec im a noob at dis stuf. plz help.thanks
  • zoom41 Nov 12, 2008
    Yes i have the same problem even when i tried a wired connection i got the same old ****...upnp not available nat type 3! this is purely sonys problem and you would think they would have an easy simple soluition for people but no they are to busy making up the next con for suckers like us to spend hard earned money on.
  • freddie24 Dec 10, 2008
    i am having this problem with my xbox live connection. I think i need to enable UPnP. Its also saying that i am on a strict NAT i need to change this to open. How is this done
    Novelist:
  • 143 Answers
You need to open ports on your router so that it will give you proper connection to your ps3. you also need to set static ip address on your ps3.
here are the steps...
- go to a working computer that is wired to the router and open command prompt (for windows, click on start, then run, then type cmd or command, whichever will work, or click here if you are using mac)
- then you will be prompted with a black screen, on the blinking cursor type ipconfig/all
- take note of the subnet mask, default gateway, dns1 and dns2
- now go to your ps3 to set static ip adddress
* go to network settings and click network settings
* go to wireless or wired (whichever connection you are using for your ps3)
* then custom
* enter security settings
* now for your ip info click manual
* where it says ip address enter a static ip address (by default the ip address of your router is 192.168.1.254 so you can use any ip address that is on the same segment and was not being used by your other devices like 192.168.1.5 or 192.168.1.10
* subnet mask is normally 255.255.255.0
* put your default gateway number (the one that you have seen and listed from the command prompt) on the default router field
* enter the dns1 and dns2 also
* click next
* don't enable proxy server
* you can enable upnp if you can also enable it in your router
- now go bak to the computer and open a web browser, on the address bar of your web browser type the default gateway number (usually it's 192.168.1.254)
- you will be prompted with the netopia page, click expert modem on the left hand column, click yes, enter expert mode
- double click the word configure, go down and click on NAT, click static NAT, click the dropdown icon, see if your ip address (static ip address of your ps3) is there, if so click it, click on done, if this works, ignore the paragraph in brackets. (note: if it's asking for the default router ip address, you need to select/enter the default gateway number)
- click define custom service, click o port forwarding, select next , type anything in the service name, something that you will know its related to the ps3
- for global port range, if it's only one port that's being entered, enter the same port in the left and right hand boxes, in every case , enter the lower port in the box below saying base port even if there's only one port, and chage the TCP/UDP settings according to every port.
* here are the ports (note: repeat the same process for each one, after that window, select the static ip address you made in the drop-down list so it gets forwarded only for the ps3)
TCP port 80
TCP port 443
TCP port 5223
UDP port 3478-3479
UDP port 3658-3659
- when your done, click NAT on the left hand side, click the dropdown menu that has age of empires written on it and scroll to the bottom, click on the ports you made with the asterix beside them (*) and click enable , then enter the ps3 ip address in the bar , to enable them just for the ps3
- now click configure on the left and then click connection and tick the box that says upnp (note: you should have, when you click NAT on the left hand column, a static NAT address, enabled, it should be the same ip that you have used on your ps3, 7 ps3 ports, all enabled to the host device of your ps3's ip
- now , enter basic mode, click firewall, and set to low, this isn't dangerous as long as you have a desktop firewall such as windows or mcafee etc...
- save changes, and restart your router
hope this'll help you
ciao!
Posted on Aug 27, 2008
Modern Warfare 2 Open Up NAT
Have a look in the user control panel of the router.
It's probably at 192.168.1.1 or 192.168.1.254.
Admin username and password will be as default unless you changed them.
It's probably to do with your router firewall. Ensure that it's configured to allow traffic to and from your xbox.
Mar 01, 2010 | Netopia (3347NWG-VGX) Wireless Router...
Strict NAT type on xbox live...eircom is provider, there router
Follow this link and it'll tell you exactly what to do if the router your using is an eicom netopia http://xbox360help.blogspot.com/2007/09/xbox-live-eircom-router-netopia.html
I had the same problem when i started 3 years ago. now i recently bought the new wireless adaptor and have one of the new routers from eircom and after 20 minutes during gameplay it disconnects me from xbox live.it is really startin 2 annoy me now. does anyone know what could be causing this to happen??
Jan 12, 2010 | Netopia 2247NWG-VGx Wireless Router...
How do i change my xbox nat settings from strict to open
I have this router and have just enabled the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again. Worked for me!
Dec 30, 2009 | Microsoft Xbox 360 Arcade
Ps3 setting up static nat
are you in ireland and with eircom?
Feb 19, 2009 | Netopia 2247NWG-VGx Wireless Router...
Nat type is strict
Playstation Guides ( PS3 ) to change from NAT3 to NAT2...
Guide1 or Guide2 or Guide3
Feb 02, 2009 | Netopia 2247NWG-VGx Wireless Router...
Router will not allow me to play onling games through xbox 360
If the problem has something to do with NAT firewall in your router, then you may need to open certain application ports for your XBOX in the router. You may check this link from Microsoft http://support.microsoft.com/kb/908874 that talks about NAT firewall and XBOX live.
Hope this helps!
Nov 09, 2008 | Computers & Internet
Opening nat
You just need to enable port forwarding for the ports that the xbox live is using, specifically these ports:
UDP 88
UDP 3074
TCP 3074
You then assign a the static IP you have set on your router, subnet, gateway and dns on your xbox and that should allow your xbox live to work properly with your router.
Aug 21, 2008 | Computers & Internet
N.A.T Settings
So you want the public IP address that your Netopia router is getting to do a 1 to 1 NAT to the private IP address 192.168.1.136? Basically you want to bypass any of the firewall restrictions of the router?
The caveat with this configuration is that if you don't have any other public IP addresses for the actual Netopia router to use then all other devices on your network will now longer be able to access the internet through the router. Only if you have a public IP address that you can assign the router will it be able provide NAT and internet access to the rest of your network.
The 192.168.1.0 network is not routable on the public network. You need your entire network to NAT through your router using a public IP address.
You configuration will work if the Netopia router will allow a 1 to 1 NAT to another node on the network and allow NAT'ing for the rest of your private network concurrently. Of course you need at least (2) public IP addresses in the same subnet as well.
Hope this helps. Let me know if you need better clarification.
MO
May 24, 2008 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Bad connect to xbox live
assign a static ip address in teh x-box in teh range of ur router and login to teh router inter face and put that static ip address which u assigned for ur x-box in DMZ and reboot teh router and x-box that will work
it might be a port blocking or fire wall action so try this
thx rate me solved if its helps
Nov 11, 2007 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
2,466 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
