Question about Dell E177FP LCD Monitor
Monitor will not turn off
I've had this Dell E177FP monitor since November 2006, and it has been OK until lately. The last few weeks, I've had intermittent trouble getting it to turn on and off when pressing the power button....the initial 'casual' pressing of the button would not work, but the second more forceful/intentional pressing would turn the monitor on or off. Yesterday, I had much more difficulty turning the monitor on; I think it took 5 attempts to turn it on. When I tried to turn it off, after the 5th try I had a thought that maybe I should leave it on, that if I did get it to turn off, I would never be able to turn it on again. I suppose I could just leave it on, but won't that result in other problems or damage over the long haul?
Any help you can offer on what to do about this would be greatly appreciated.
  • gandecoe Aug 26, 2008
    Hmm.... not sure what you mean by "main switch". If you look at this graphic, the button furthest to the right is labeled "Power On/Off button with LED indicator" on the "Setting Up Your Monitor" sheet that came with it. There are no other switches; the other buttons are for modifying the display. Are you referring to the switch for the CPU/tower?
    Sergeant:
    Champion:
  • 333 Answers
The power switch on an LCD monitor is only a power saver, it does not switch it off completely. There is no reason why you cannot use the mains switch to turn the monitor on and off - assuming that it was on in the first place!
Most LCD monitors have a 3 year warrantly - at least they do in the UK. Why not contact Dell and get them to replace it for you. You should do this before the 3 years are up.
Cheers
Posted on Aug 26, 2008
  • boff1 Aug 27, 2008
    Yes, you can have a separate lead to the mains not one taken from the PC power supply.
    Cheers
The monitor wont come on.i noticed the power button has been pushed inside the monitor and i need to know if i can disassemble it to get i tout without hurting the monitor
The E177fp and E197fp are identical units other than the size of the display panel. Here is a link to a repair guide for the E177fp that has videos showing how to open the unit. It should help you get your open.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-e177fpf-lcd-monitor-with-power-issues/
Nov 07, 2012 | Dell E197FP 19 inch Flat Panel LCD Monitor
Dell E177FPv, 17" TFT LCD Flat Panel Monitor will
I think you might have the same problem I did with my E178FPb. I made a video on how I fixed it.
Apr 04, 2011 | Dell E177FP LCD Monitor
I have a dell monitor model e177fpv. It is stuck in power save mode. What do I do?
I have worked a great deal with the Dell E177fpv boards and when it is blinking power switch then it's bad. Most the time it's the C204,and C203 compositors that are bad (100uF 10v), and 70% of the time the C159,C154 ( 470 uF 25V are bad as well. now i have replaced them many of time and it had came back to life. i have also found other caps bad on it as well. i know you can order a new board for $39.00 and here is the link. http://www.lcdrepair.us/e177fpv_inverter-power.html
Dec 08, 2009 | Dell E177FP LCD Monitor
Monitor does not want to wake up. Pressing the yellow rest switch the button goes green for less that 3 seconds, then goes yellow.
try unplugging your computer and your monitor for about a minute and turn back on. Then see if it works, Good Luck ;)
Nov 12, 2009 | Dell E177FP LCD Monitor
Auto Adjust in Progress
Disconnect the monitors plug. Unplug the power cord. You may not have to do both, but it reset mine and it works fine now.
Oct 20, 2009 | Dell E177FP LCD Monitor
My dell E196FPF 19'' lcd screen acting strange!
Are You using a extention cord or a ups that is not funtioning properly....?? if yes try connecting the power for the monitor seperately or directly to a plug base...
this mi8 solve ur problem
Apr 10, 2009 | Dell E177FP LCD Monitor
Monitor won't turn on without help.
Do you have a second monitor or can you borrow one to check if the fault lies with the monitor or the PC?
If the monitor is at fault then there is not much you can do yourself. I suggest you contact Dell and get them to replace it under warranty. Most LCD monitors have a 3 year warrantly, at least they do in the UK.
cheers
Aug 04, 2008 | Dell E177FP LCD Monitor
Need to unlock speaker from monitor
The E177FP has only a optional soundbar that can easily be separated. Look here.
Good luck
Mar 29, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell monitor E177FP LCD Monitor
This is normal, typically you must press the power button (on the monitor) to turn it off.
Mar 09, 2008 | Dell E177FP LCD Monitor
Dell E177FP LCD Monitor Logo
149 people viewed this question
Alun Cox
