RCA D52W20 - turns on and off, blue screen, tech said need picture tube
I've had my D52W20 for 4 years now. For the past 3 years or so there's been a SLIGHT delaying powering on. I could instantly hear the audio, but the picture would be about 2-3 seconds late. Never really thought much of it. I recently moved out of town, and while i was getting settled the tv was in the garage of my old house for about 4 months over the summer. When I moved it in a Uhaul (250 miles) and got in the new house a few weeks ago it wouldnt work properly. At first the picture was jus a little "blue". Then the whole screen went blue......and had weird zig-zag lines through it.
I waited a few days and tried it again. This time it was cutting on and off by itself. It would stay on for the about 30 seconds, then turn itself off for 3 seconds.....then turn itself back on! After doing that about 4 times.....it simply would not power on again.
I unplugged it and waiting a few more days. This time the tv stayed on for about 5 hours!!! ......but the it powered back off and followed the same routine.
I had a local tv repair place pick it up. They just called and said it 'seems' like it's the picture tube and it's not worth fixing. They said they finally got it power on, but now they cant get it to power off! and said that the picture is of poor quality.
Before I TOTALLY through away a $2k investment.....is there anything else I can do? were they correct? it's a small town, so i dont have much faith in them. Please tell me what you think the problem is and if it's fixable.
THANKS!
  • frustrated17 Aug 26, 2008
    hello! Thanks for ur prompt response, but could you please provide a bit more info/detail? Is it something that I cld fix on my own? If so, how? Where can i get the parts? Have you heard of a similar problem like this before? Wht odds to you give of one solution versus the other?
  • 8,617 Answers
It very well could be the Blue CRT shorting out. However the not shutting off is not a symptom of the tube being shorted that sounds more like a signal board issue rather than a picture tube, as the signal board can cause all the symptoms you have described.
Posted on Aug 26, 2008
  • Sonny Berry
    Sonny Berry Aug 26, 2008
    I would say the signal board over the CRT as the signal board can exhibit all the different symptoms where as the tube could only exhibit two which would be a blue screen and shutdown. You can get any part needed at the following link and they also offer free support as they are experts with RCA. Heres the link.
    http://servicemanuals.vstore.ca/
We have a 3 year old RCA 52in projection tv, One day it went blurry for just a moment and then went blue. We turned it off, because we didn't want to fry it. And then turned it back on, the picture was...
you eather have a bad solder connection or a part overheating...this unit has a processor that generate error codes that technician with a special computer interface can read....this is where the troubleshooting begins...first thing a tech can do is check make sure all cables are securely plug in
Jun 11, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
JUST LOOKING FOR INSTRUCTIONS ON CHANGING THE LAMP.
the d52w20 rca model rca itc22 chasis is a 3 picture tube television.... it has no bulbs... do you mean to change a picture tube?
Feb 28, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA D52W20 in. Rear Projection HDTV. Just a few minutes ago there was a loud pop while watching tv and then the picture when black. I immediately turned off the television, checked behind it, and...
This TV if the model # is D52W20 ,`Then it is Projection and has 3 Tubes Red / Green / Blue
these tubes Cost over $450.00 each problem will be in the Deflection Board/ it will be the bottom left hand side board that has the FBT flyback Transfomer on it.
Most common repair is 3 capaciotrs on the deflection board CP150 2200uf 16v use 25v, CP114,CP120 220uf 35v replace all 3 caps.
Dec 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA D52W20 turn on with a blue screen and then turns off within 3 sec's. It goes off like someone has switched off the TV. The light blinks and goes off. Can anyone help
Your blue tube has a short. What you are seeing is the TV turning on and the blue tube going to full brightness. It then draws enough current that the television's protect circuits shut it down.
Need the full model number which should include a BYX or just YX followed by a number. Going off the D52W20BYX1 the blue tube would be part number 263049 which https://www.encompassparts.com still has a few for $220 before shipping.
Jun 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca D52W20 blue screen when turned on
Almost certainly the blue picture tube is bad. This is a huge job to replace and quite expensive. Generally it is not worth doing.
Mar 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV-Ready Television?
The blue CRT is shorted out. You will need to replace the Blue CRT. You can get replacement CRts at the following link for your model. http://servicemanuals.vstore.ca/
Jan 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
It does sound like the tube, have the shop use a tube restoration machine to rejuvinate the tube, and replace the eprom to try to correct the no power down situation.
Aug 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52w20 rear projection tv
If you go to this link they have any Picture tube you need for your model and they include instructions on how to remove the old Tube and install the new one. Your model has picture tubes instead of lamps. Leave them an email with your model number and which CRT (picture Tube) youre needing they respond quickly. Heres the link.
Jun 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture Color
http://www.partstore.com/ModelDetai...close=1&exact=1
What do you think "CRT ASSY, Projection: Blue" might be?
CRT ASSY, PROJECTION: BLUE
RCA Part Number: 258486
RCA Model: D52W20
52" CRT BLUE P16LTG00BMB, DELTA 250
They want $183,
Jan 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 Blue Tube doesn't power on
From your description it does sound if the blue crt has failed. But it can be the crt board or a high voltage issue. intermittantly like that could be a connection problem. is there any hissing ..cracking or smells?
Dec 16, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
