Question about Kenmore Elite 45986 Front Load Washer
Foul odor My clothes are coming out smelling very musty. I leave the washer door open when not in use and wipe the rubber ring inside & out after my final load for the day. How do I get rid of this smell? I have the same musty smell in clothing. I run bleach thru the washer every week and try to keep the boot well clean and dry between washes. I also leave the door open when not in use (rarely). I spray the rubber seal with chlorox cleanup to minimize the mold. I recently discovered that the detergent/bleach/fabric softener dispenser that is removeable was loaded with mold in the underside and in the cracks. So much mold present that the fab softener holes were plugged closed. Apparenly, the presence of mold will spread under these favorable conditions. Now, I clean that with bleach regularly and have stopped using fabric softener. All this seems to help with the odor, however, this is way too much work for such an expensive machine! I may try to replace the rubber gasket if this persists.
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%4
Posted on Sep 28, 2010
Smells musty and not washing clothes well
"In washing in the HE washers I think that if you have more than 3 loads a week you should maybe wash your washer at least once a week. I have started wiping the door off and leaving it open between washing and that helps a
lot with the smell.
This is why I think if you could wash the washer once a week it would probably do better. You never had this problem in the old washers." Try this in your washer.
Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Musty smell
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically. My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Aug 11, 2010 | Kenmore Elite 45986 Front Load Washer
I have a musty odor after my clothes are washed. What's the problem. I clean my machine monthly with bleach.
I use 20 mule team borax and leave the door open when not in use and have no more musty smell in washer or clothes.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have an older front loading washer Frigidaire and it's now smelling like mold on all our clothes thought it was me leaving clothes in to long but it's not. model #FWT445GES2 serial #XC74463636 . I have...
No recall, Pour 2 cups of bleach into the washer, Wash on HOT water, long cycle. Then wipe seal with dry cloth. This will eliminate the mold smell... To stop it from coming back ALL front load washer doors MUST be left open to allow the rubber seal to dry, Just like you close your shower curtain so it doesn't get musty smelling... 2 hours is about the dry time... wiping the seal with a cloth usually helps too... All located in your owners manual/
Jul 31, 2009 | Washing Machines
Musty smell in washer and clothes.water remains in rubber gasket
Two thing that you might try: Add two or three cups of bleach and have the machine run a cycle (with no clothes!!!). Second, always leave the door open after use to let it air out. Also, it wouldn't hurt to use straight bleach as a wipe to the entire rubber tub seal.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Water Remaining in Gasket Around Door
normal problem all front loads all brands.. leave door open as much as possible.. to clean fill tub with hot water pour in 2 cups chlorine bleach use rag in solution wipe gasket out as good as possible allow washer to run normal cycle ..do as routine when ever odor is first noticed leaving door open will allow most of water to evaporate
Nov 19, 2008 | Kenmore Elite 45986 Front Load Washer
Foul odor
Run the washer on the hottest setting you have with nothing but a cup of bleach in the tub. Pour the bleach through the dispenser so it cleans the dispenser as well. Run the washer like this and let it complete the cycle. If the smell persists, remove the lower kick panel under the door and check the drain trap on the drain pump for anything that could be caught in the pump and making it smell. This odor can travel back into the the wash tub. If you decide to open the drain pump, however, here\'s a bit of advice. There is some residual water that stays in the drain lines and pump (this is normal). If you remove the drain trap cover, all this water will come gushing out. To avoid this, take the drain hose out of the standpipe and use a wet/dry shop vac to pull this remaining water from the tub and lines. This will save you from a big clean up later. Lastly, you mentioned you\'ve been cleaning the rubber door boot. Are you using 50/50 mix of bleach water in a spray bottle? Are you cleaning the area behind the door boot where it meets the wash tub? I ask this because once mildew sets into the rubber it\'s hard to get rid of it unless you use something with chlorine in it to kill it. Also, articles of clothing get caught in this area and can begin to smell. Not to mention, all the nasty residue left by soap and detergent. If all else fails, and you have tried all the advice, the last thing I have found that works, is to simply replace the entire door boot. Try the cleaning options first, and if you still have problems let me know. I can give you step-by-step advice on how to change the door boot if you wish to pursue it. The cost, by the way, is about $80. I hope this helps you.
Sep 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Smells of mildew and so do clothes
If the odor does not go away, it is probably time to change the rubber door boot, or you have something stuck in the drain. Take a good look at the rubber around the door. If it has mildew spots and/or mold, it generally won't go away. Pull the rubber back a bit and look BEHIND the boot as well. You may have some lost items stuck in the boot causing the odor. Last of all, UNPLUG the washer and remove the lower kick panel under the door by removing the three 7mm screws and check the drain pump for foreign objects. There's only one pump inside the washer so it won't be too hard to find. It is usually white in color and has a screw off access cover. There is a bit of residual water that remains in the wash tub all the time. You will need to drain this first or you will have a mess to clean up. You can use some towels or use a shop vac. If you use towels, lay them down around the drain pump and remove the access cover. If you use a shop vac, pull all the residual water from the wash tub through the drain line. Sometimes this pump will build up with all kinds of scunge from soap residue and/or foreign object getting caught. Clean it out real well and run the washer on a bleach cycle with the hottest water setting you have. Let me know if any of this helps you. If you decide to change to door boot, post a response to this solution and I will give you step-by-step procedures.
Aug 26, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
335 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
