Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Hitachi 50V 500 LCD Rear Projection TV
I'm seeing a blur in the center of the screen about 1/2 inches in diameter. It appears about where you would see someone speaking and their lips appear blurry. Anybody got an idea what may be happening?
  • 11 Answers
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Posted on Aug 31, 2008
    Problem Solver:
  • 5 Answers
About two years ago, I had a small red blur in the middle of the screen. That red blur is now all over my screen. I called Hitachi and they said that there's nothing they can do about it because it's almost 4 years old and the warranty has expired. I called a repair shop and they said that it may be a light engine problem and it will cost about $1300 to repair. Might as well get a new TV for that. I did some research and found out that this is a common problem and that you need to be persisting when calling Hitachi and speak to a supervisor. The supervisor said that if a repair person confirms that it's a light engine problem, that they will send the part FREE OF CHARGE (just gotta pay for labor). They will only send a replacement once.
Posted on Aug 26, 2008
55 inch hitachi lcd projection tv has yellow and purple blur near the center of the screen
This, sadly is getting to be a very common problem with all Projection LCD TV's
Colored Blotches on an LCD Projection TV are usually caused by defects or marks on filters or lenses on one of the LCD panels themselves which are all located in the light engine (or optical block) First confirm that the lamp or main lens is not discolored by removing the lamp (unplug set and let cool before removing!) and visually inspecting the lamp itself and the lens that it shines onto. The light engine is an expensive part ($600-$1200) to replace and requires major disassembly. Have a tech confirm-Get an estimate -Be sure to vote/rate me if this helped Thanks!
Nov 24, 2009 | Hitachi 55VS69 55" Projection HDTV
From about 4 inches down from the top of the tv and from the center to the left corner is red and green and the corners on the bottom of the tv are also arched but not as bad
this is a vartical non linarity folt .
chech vartical stage capaciter 470umf/63v 4.7um/50v 1000/50v
0.47um/63v Replace and first svr.menu to set vartical linyarity adj.
set V- hight is sum down sum 1" or 2 " after the set vartical linyarity V-line. set up to down and check the pictur. if not then Replce capaciter.
Oct 04, 2009 | Hitachi 51F500 51" Rear Projection...
Optical engine
The best thing to do is to call Hitachi and see if they would be able to help with the cost of the repairs because it will be expensive.
Hope this helps,
Skyassoc
Jul 16, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi lcd rear projection tv
Hi, thats bad news, you need a light engine, very expensive repair,sorry for the bad news,video-tek
Jan 11, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Troubles with phillips projection tv. It is showing about a 6 Inch blurring color at the bottom of the screen and blurred color streaks throughout the screen, what could be the problem?
you need the DPTV305 - Dptv345 Convergence repair kit available at the following link. Its listed under the convergence repair kits category, comes with all parts and step by step instructions with pictures so you can do the repair yourself.
Here is the link.
http://servicemanuals.vstore.ca/
Oct 03, 2008 | Philips Magnavox 51MP392H Rear Projection...
Hitachi Television Yellowing on the screen
Suggest you call Hitachi and complain. There is an issue with all projection LCD tvs (not just Hitachi) was that the light engine assembly did not have enough vents for cooling. This translates in a green or yellow blob that starts small and grows larger because the LCD screen frame starts to deform with the heat. Guess they did not test with young kids in the house and the tv on more than it is off :-). In March I managed to get Hitachi to pay for the part and I paid for the labor to get this fixed (out of warranty). The new light engine supposedly is better at cooling though I do see a faint 1/4 inch band of green at the bottom of the screen. Blackburn Electronics in Anderson IN has fixed many of these in the Indianapolis area.
May 06, 2008 | Hitachi 42V710 42" Rear Projection HDTV
TV wont stay on
Sounds like a short somewhere in there. I see old pre-HD big screen sets going for well under $200 on my local craigslist, so look there for a good replacement, because the repair will cost more.
Or fork over about $500 for a good used HD projection set.
Apr 06, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 60 in. 60V715 Yellow Haze
I would first check and see if any software updates are out on this set, you can call Hitachi, if not that then it could be the engine assemble having problems.
Jan 02, 2008 | Televison & Video
Blue Spot in top center of screen
same problem, guy said i need a COLOR DRIVE!! $1000, trying to find cheaper
Jan 07, 2007 | Hitachi 60V500 60" Rear Projection...
Pink Dot in center of screen.
Well, You have a bad engine, so what other's called lcd projector motor.
This will cost you, the engine states at about $500. I've seen this problem and right after I've change the engine for some
F#$% reson the bulb when, twice on me, that's another $400.
Good Luck
What About Bob
Timmins, Ontario
Home of Shania Twain
Sep 24, 2006 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
265 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
