Hitachi DZ-GX20A DVD Camcorder Logo
A
Anonymous Posted on Sep 05, 2005
For still photos, which types of media can I use?
For digital still photos, which types of media can I use and what is the maximum amount of photos that I can store on each?
Anonymous
Level 3:
Master:
  • Master 473 Answers
  • Posted on Sep 05, 2005
Anonymous
Master
Level 3:
Master:
Answers
473
Questions
72
Helped
95425
Points
1373
DVD-RAM 1,998 on a dual sided disc (999 per side) – This number will decrease if movies are recorded on the same disc.
Backlight not working
Go to settings, Brightness and set it to the maximum or the amount you want. If that doesn't solve your problem, send it to Apple.
2helpful
2answers
1helpful
Can i still retrieve deleted pictures from my memory card the problem is i took another photos big mistake i did.is there any options still to retrieve?
Your memory card has a certain amount of space dedicated to storage and you can continuously take pictures for storage. Once that space is used up, new pictures will overwrite anything that is old on the card. Probability of recovering anything deleted highly unlikely.
Feb 17, 2012 • Cameras
When I copy to photo paper it reduces automatically, why
Print on special and custom-sized media
To print on special or custom-sized media (Windows)
1. Load the appropriate media. For more information, see Load media.
2. With a document open, click Print on the File menu, and then click Setup,
Properties, or Preferences.
3. Click the Paper/Features tab.
4. Select the media size from the Size is drop-down list.
To set a custom media size:
a. Click the Custom button.
b. Type a name for the new custom size.
c. In the Width and Height boxes, type the dimensions, and then click Save.
d. Click OK twice to close the properties or preferences dialog box. Open the
dialog box again.
e. Select the new custom size.
5. To select the media type:
a. Click More in the Type is drop-down list.
b. Click the desired media type, and then click OK.
6. Select the media source from the Source is drop-down list.
7. Change any other settings, and then click OK.
8. Print your document.
To print on special or custom-sized media (Mac OS)
2. On the File menu, click Page Setup.
Chapter 2
28 Use the device
3. Verify that the correct printer is selected.
4. Select the media size.
5. To set a custom media size:
a. Click Manage Custom Sizes in the Paper Size pull-down menu.
b. Click New and type a name for the size in the Paper Size Name box.
c. In the Width and Height boxes, type the dimensions and set the margins, if
desired.
d. Click Done or OK, and then click Save.
6. On the File menu, click Page Setup, and then select the new custom size.
7. Click OK.
8. On the File menu, click Print.
9. Open the Paper Handling panel.
10. Under Destination Paper Size, click the Scale to fit paper size button, and then
select the customized paper size.
11. Change any other desired settings, and then click OK or Print.
Print borderless
Borderless printing lets you print to the edges of certain media types and a range of
standard media sizes.
NOTE: Open the file in a software application and assign the image size. Make
sure the size corresponds to the media size on which you are printing the image.
You can also gain access to this feature from the Printing Shortcuts tab. Open
the printer driver, select the Printing Shortcuts tab, and select the printing
shortcut for this print job drop-down list.
NOTE: Borderless printing is not supported on plain media.
To print a borderless document (Windows)
2. Open the file that you want to print.
3. From the application, open the print driver:
a. Click File, and then click Print.
b. Click Properties or Setup.
4. Click the Paper/Quality tab.
5. Select the media size from the Size is drop-down list.
6. Select the Borderless Printing check box.
7. Select the media source from the Source is drop-down list.
8. Select the media type from the Type is drop-down list.
Print borderless 29
9. If you are printing photos, select Best from the Print Quality drop-down list.
Alternatively, select Maximum dpi, which provides up to 4800 x 1200 optimized
dpi* for optimum print quality.
*Up to 4800 x 1200 optimized dpi for color printing and 1200 input dpi. This setting
might temporarily use a large amount of hard disk space (400 MB or more) and will
print more slowly.
10. Change any other print settings, and then click OK.
11. Print the document.
12. If you printed on photo media with a tear-off tab, remove the tab to make the
document completely borderless.
Change settings from an application for current jobs (Windows)
To change the settings
1. Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
(Specific options may vary depending on the application that you are using.)
3. Change the settings that you want, and then click OK, Print, or a similar command.
Change default settings for all future jobs (Windows)
1. Click Start, point to Settings, and then click Printers or Printers and Faxes.
- Or -
Click Start, click Control Panel, and then double-click Printers.
2. Right-click the printer icon, and then click Properties, Document Defaults, or
Printing Preferences.
3. Change the settings that you want, and then click OK.
9. If you are printing photos, select Best from the Quality drop-down list.
dpi*.
print more slowly.
10. Select the media source. If you are printing on thick or photo media, select the
manual feed option.
11. Change any other print settings, and then click Print.
I can not intall my acer 320u scanner in win 7
Scanner seems to be very old - Here are orginal specs - Hope this helps
  • Brand Name: Acer
  • Model: 320U
  • Hardware Platform: PC, Mac
  • Scanner Type: Flatbed scanner
  • Form Factor: Desktop
  • Scanner Interface: USB
  • Media Size Maximum: A4 (8.25 in x 11.7 in)
  • Color Depth: 36-bit color
  • Maximum horizontal resolution: 300
  • Maximum Vertical Resolution: 600
  • Media Type: Plain paper, Bulk objects (such as books)
  • Media Load Type: Manual load
  • Minimum system requirements: Apple MacOS 7.0 or later, Microsoft Windows 95/98
  • Width: 12 inches
  • Depth: 18.1 inches
  • Height: 3.3 inches
  • 0helpful
    What type and what is maximum amount (banks &
    Check out http://www.18004memory.com/
    Just type in the brand and model number of your laptop to find out.
    1helpful
    2answers
    I can't record more then 20 sec video file
    I'm sorry to inform you but after researching your camera only records for 20 seconds. It has nothing to do with your card. Only 20 second blocks of time.
    Movie mode - The total amount of recording time available is shown by the green "00:20" in the lower right hand corner. This is SHQ 640x480 resolution at 30fps, the maximum recording time is 20 seconds. In the lower quality 640x480 @ 15fps or 320x240 size, the recording time is limited only by space on your xD card. The shaking hand icon indicates that we have the image stabilizer turned on.
    Why does my Fun! Digital 320 camera hold more than 18 images?
    The literature packaged with the Polaroid Fun! Digital 320 camera does indicate that the maximum number of images is 18. However, the actual number of images is, in part, dependent on the complexity of the scenes you are trying to capture. Scenes that are complex (contain a high degree of detail) require more space on the camera's memory chip. Photos of less complex scenes (not much detail in the photo) take up a lesser amount of the camera's memory, freeing up space for additional images to be stored.
    Saving photo files
    The building blocks of your image library are the actual file formats in which you save your images. There are two major formats: compressed and uncompressed. • The advantage of uncompressed storage is that you can save a maximum amount of image-forming information for color fidelity and clarity. • Compressed file formats get rid of some information to shrink the file size (thereby increasing a disk's storage capacity). We recommend saving all your work-in-progress images (equivalent to the negatives in film cameras) as TIFF files. This way they will remain at maximum quality, so you can create other versions for printing or e-mailing, and can save them in smaller, compressed files like JPEGs. The advantage is that you'll always be able to recreate an effect or enhancement by starting with the original TIFF file without losing image integrity.
    Top Hitachi Video Cameras Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ZJ Limited
    ZJ Limited
    Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
