Printer says I have no paper when, in reality, it's fully loaded. When I hit the print command it makes clicking noises and then the message that there's no paper.
  • 2 more comments
  • pdanloe Aug 26, 2008
    I figured it out myself by hitting "feed switch"
  • pjsarto Sep 11, 2008
    5 year old hp 1300, printer indicates out of paper when tray is full. Manual print button typically will force the printer to print, but not this time. Rebooting doesn't help either.
    Paul
    pjsarto@comcast.net
  • Maref Sep 18, 2008
    My HP 2840 displays message read "Load Paper" though it is fully loaded with paper
  • judy4public Feb 26, 2009
    I have rebooted the computer, the printer and it still tells me that the paper tray is empty when it is fully loaded.
    Sniper:
  • 62 Answers
Need model of machine
Posted on Aug 26, 2008
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
Tray1 Load LTR
Hope this helps. Please check the printer properties before clicking Ok at print menu command. Now check the available paper tray handler. Try bypass, tray1 or MP tray.
Check also the default paper on Printer Menu command by pressing appropriate setup button. You can try also placing the paper on bypass try if available. The load LTR message means the machine waits a short bond paper on MP tray or on bypass tray.
Jun 16, 2010 | Office Equipment & Supplies
Getting message to load tray 1 A4. load with
This problem is commonly found across printers, and is not specific to your printer model.
This problem occurs if:
  • You select the Hold mismatched documents option on the Advanced tab of the Properties windows of the printer.
  • The printer driver user interface (UI) plug-in uses the full UI replacement functionality. This means that printer driver replaces the default Windows printer dialog interface, so Windows fails to find certain registry keys to determine the paper type.
Microsoft has a hotfix for this issue for Vista and Windows Server 2008:
http://support.microsoft.com/kb/971319
If you are seeing this issue on XP, you can do the following:
1. Go to Printers and Faxes from the Start Menu (or type the following command in the Start->Run window: control printers).
2. Right click on the affected printer's icon, and click on Properties.
3. Click on the Advanced tab.
4. Uncheck the option Hold mismatched documents.
5. Some printers have the default paper type as Letter, so please change the printer properties to use A4 as the default
5. Click OK to save the settings change.
6. Wait for 15 seconds, and try to restart your printer job if needed. Usually, Windows will automatically restart the job, once the paper mismatch setting is resolved.
7. Ensure that you make the above printer property settings change on every computer where your printer is installed.
Happy printing!
Jan 21, 2010 | Dell 5110cn Laser Printer
Out of paper issue
Instead of restarting, try this:
1. Start
2. Run
3. Type this in the box: services.msc
4. Hit ENTER
5. Scroll down to PRINT SPOOLER
6. Right-click on it and choose RESTART
this will clear out your print queue without having to restart. Good luck!!
Hi this is the more effective way to refresh the print queue.
Manually Stop and Restart the Spooler Service
1. Click Start, click Run, type command, and then click OK to display the command.com window.
2. Type net stop spooler, then press .
3. Type sc config spooler depend= RPCSS start= Auto, then press . The spaces between = and RPCSS and = and Auto are important. Without these spaces, the command fails.
Type net start spooler, then press
NARENDER KUMAR RANA
narendertacl@gmail.com
narendertacl@yahoo.com
narendertacl@hotmail.com
Nov 15, 2009 | Kodak EasyShare Printer Dock Series 3
Printer is loaded with paper but get message
Although you really haven't given me enough information, I will posit and response for you.
A "Load Paper Error can be caused by the application telling you to change the "TYPE or SIZE" of paper that is in your paper tray.
For example, The application thinks you want the page printed on "Letterhead" paper, but it know that you have plain bond paper installed.
So you are sent a change paper type message.
The fix is to hit go and skip around that error.
The actual fix is to make sure that your printer driver, application and the printer are all set to the same size paper and type paper.
Don
Nov 05, 2009 | HP Hewlett Packard LaserJet P1005 Printer
Error message says"out of paper" when paper tray is fully loaded
check and make sure that the paper is in near the rollers enough that it senses the paper and picks it up. try lightly pushing the paper down toward the rollers as it is suppose to pull one sheet through the feeder. hopefully, you didnt pull too hard on getting the 'jammed' paper out that it may have caused a misalignment in the feeder. try assisting the paper, that usually fixes it. hope this helps!
Aug 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
1315 Printing worries
To resolve the issue Click here and go through the instructions.
If problem persists get back to me with the following information.
  1. How is your printer connected?
  2. What is the OS?
  3. From which application you are trying to print?
May 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
Printer R300
make sure you have the paper where it hits the part that sucks in the page to be printed (you can see the gray stucture by removing the paper and looking into where the paper is put) this might cause your papers, if you have a small amount, to bend to where the dip of the curve is facing the front of the printer. *Also the best way to prevent this is by having a LOT of paper where its fed (if the bending thing doesn't work.* Also the clicking noise is the sucking part not getting a piece of paper. This is because the paper not inserted correctly means that the pronter detects that paper is in the pronter but it can't get it.
Oct 15, 2008 | Epson Stylus Photo R300 InkJet Printer
Tray 1 - load ltr (WHAT DOES THIS MEAN!!!)
Best regards,
Rosener
Feb 08, 2008 | Tally T8006 Laser Printer
134 people viewed this question
jasbo
jasbo
