My Memorex MT2028D-BLK television, which is one week old, will not turn on. The power light just blinks red, and there is a clicking sound.
  • lcbowman0722 Dec 08, 2008
    I have the same problems. The tv won't turn on and the standby light blinks red
2 Suggested Answers
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
SD Tech
  • 14553 Answers
SOURCE: Television is not turning on
3 blinks is short protection on this model---98% chance one of the two STK-392-110 Convergence chips it uses has shorted.
If you unplug set and look inside you will find two black chips that have that number printed on the front of them in white letters. Right in front of them you will find about a dozen light blue resistors---most are marked 2.2 ohms---look if you get a chance---if even one of those resistors is white in the middle (discolored) you have found your problem.
Both chips and any bad resistors need to be replaced.
The repair involves getting at the parts and replacing them--the chips each are mounted side by side on metal heat sinks with fins--each has 18 pins.
Most shops get 300 or more for this repair but the actual parts cost if you or someone you know can do it is under 30 dollars.
I have START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET. I got a notice from a lady who used them to fix the same set you have---she saved the set and a lot of money.
The instructions tell you everything you will need and how to do the repair----clearly I do not know how much skill you have---it involves soldering etc.
If you want the instructions I will post them here for you to look at and copy/ paste them. Once you read them you should know if you can do the repair------they are my own instructions based on doing this repair hundreds of times.
I will also post a photo here showing what the chips look like.
Repair takes me about 1 hour; if you are doing it for the first time it will take you longer.
I also know the best place to get the chips at reasonable price.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Posted on Jan 01, 2010
Testimonial: "Very Helpful information and willingness to help."
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Will not power up. Red power light only blinks.
If you have sound and no picture, it's time for a new lamp.
In the manual check under LED indication, It explains the blinking lights, unless your outside at night looking up!
May 03, 2010 | Toshiba TZ43V61 43" Rear Projection...
Wd 62327 DLP red 3 blinks 1 steady red light
Call for waranty repair if less than 3 months old.
Jan 08, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Panasonic pt53wx42f
WHEN POWER IS FIRST TURNED ON I HAVE A SOLID RED LIGHT BUT NO PICTURE. THEN YOU HEAR THE TV CLICK OFF. THEN RED LIGHT STARTS TO BLINK IN SET OF (3) TIMES.
Jun 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Cannot see picture....
you probobaly. need a new bulb, my dad had the same problem. he orderd a new bulb off the internet and now it works just fine
Apr 22, 2008 | JVC HD-52Z575 52" HDTV
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
313 people viewed this question
Top Televison & Video Experts
Electro Med Services...
