HAD TV SET UP ON SOUND SURROUND TOOK OFF NOW HAVE NO SOUND ON TV BUT HAVE SOUND FROM TV WHEN DVD PLAYS
I found out how to retrieve plug & play and put TV back to defaults.
Hope this helps others.
KC-Oshawa, Ont.
Posted on Aug 27, 2008
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
Dec 01, 2013 | Panasonic DMP-BDT220 DMP-BDT220
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
Getting tv in surround
you need to plug rca cables into the audio out of your tv providing it has them then go to the setting menu in the tv go into the sound options and turn on surround sound
Jul 01, 2010 | Curtis DVD5091 Theater System
The surround sound only plays on dvd not tv
most tv shows will only be broadcast in 2.0 not 5.1 or higher. if you have a converter box, that may also be the problem.
Apr 13, 2009 | LG LHT854 Theater System
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Umi freeview dvd tv combo to surround sound
I am not familiar with the manufacture and model of your TV set. This does appear to be a compatibility issue between the TV set and its DVD player, and the surround speaker system. The TV set may not be able to directly send the proper information to the speakers. I would consider to call the manufacture support people to have a definate answer.
Jerry G.
Dec 28, 2008 | Philips 17MD250V 17.1 in. LCD TV/DVD Combo
Toshiba TV/VCR/DVD combo MW24F12
You did not say if you have connected the video out on the surround system to the video in on the tv. If not connect it and select that input on the tv.
Aug 27, 2008 | Toshiba SD-V392 DVD Player/VCR
I can not get surround mode on my Marantz 5200 receiver
Check surround mode on the on-screen menu of the amp
Feb 05, 2008 | Marantz SR-5200 Receiver
Audio via hdmi
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
May 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No sound through TV
In case you connect the System to a TV set using the Scart Connector, only the video signal is terminated, Audio is actually not wired inside the SB100 Scart connector.
Sound will only be amplified through the system itself (through the satelites and Sub) it can not be utilized as a stand-alone DVD player.
So after connecting your surround speakers the problem will be solved
Apr 30, 2007 | Sony DAV-SB100 System
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
