Question about Toshiba TDP-MT200 Multimedia Projector
Won´t work when upside down..
My MT200 won´t work when upside down. Happened first time 1,5 years ago, and more and more frequently. Now it´s almost all the time.
Not sure if it is related by my MT200 would not power up at all eventually. Check the lamp cover micro switch is being depressed. I posted the comment below somewhere else. I hope this might help.
"I had exactly the same problem with the same projector. I took the whole thing apart last night, including all PCB boards the lot. After a lot of searching I found nothing untoward. Finally after figuring out how to put the thing back togther again, ready to accept defeat I noticed the micro-switch on the lamp replacement cover.
It turns out that the little plastic striker moulded to the lamp replacement cover was deformed/warped (possibly by heat?) and eventually it must have got to the point of not switching the micro-switch into the closed safe position. (I assume it there so that you can not power up the unit whilst the lamp cover is off, which would make sense) With the power effectively on and being very careful, I manually depressed the micro switch (with something plastic) the projector jumped into life! Of course I can not recommend anyone does this as it is probably not safe , but neither is having to pay a shed load for a service just for a **** plastic cover replacement. Long story short it fixed the issue. Hope this helps someone and saves them tearing their unit apart."
Posted on Sep 05, 2008
Laptop screen upside down
Nope. Hold the CTRL key and the ALT key down, and at the SAME time tap on the Up arrow key. That\'s about it
Regards,
joecoolvette
May 07, 2013 | Toshiba Satellite A105 Notebook
Computer won't turn back on after shut down
Pul 1 ram stick at a time and turn on...Are you getting a blue screen?
Nov 20, 2012 | Computers & Internet
Wallpaper won't show up.
try a system restore that will bring the laptop back to an earlier time before this happened, if successful your settings should restored. Why did this happen? bad download, a bad device driver, or program compatibility.
Mar 14, 2012 | ASUS Eee PC 1001PXD-MU17-BK 10.1-Inch...
My nordic track apex 6100 xi all of the sudden won't run...or walk...at all? HELP!
Dear Sir:
This is probably a 1) faulty speed sensor or 2) the speed sensor is not plugged in properly. Its also possibly a 3)faulty motor control board or lower board.4)the drive motor is faulty 5) The drive belt is broken.6) Resent c.breaker 7) Test the power cord. 8) Reset the c. breaker from your home. 9) Do not use extension cord .
Adjust the speed sensor see the diagram, and RUN your software calibration for easy diagnose and troubleshooting. read your user manual.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 11, 2012 | Nordic Track NordicTrack Elite zi...
We have Leviton push button slide dimmers w/the locate lights for power outlets and lights throughout our house. A couple of months ago one stopped working...you push the button to turn it on and it...
Wiring is not best suspect.
If all the Leviton devices were installed same time, they may be failing at same time due to lifespan.
For example, ordinary on-off switch is a mechanical device with mechanical parts, and mechanical switches last many years longer than wiring devices that have electronic parts.
Electronic devices usually have standard 1 year limited warranty.
http://www.leviton.com/OA_HTML/ibeCZzpHome.jsp?minisite=10025&respid=22372
Jun 29, 2011 | Leviton Decora Light Dimmer Switch
Sometimes when I drive my car to run an errand and I go back out to start the car it won't. I replaced the starter 4 yrs ago and the battery last year. The lights come on but when I turn the key I...
Next time this happens. look around on the dash for a light that says SECURITY. If you see this light, then you have isolated your problem. All the info you need on this site. How your GM security systems works, along will a few tricks and options to get around it and get your car starting again. Every time.. http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jun 23, 2011 | 1992 Buick LeSabre
When i push igniter it clicks but burners won't come on and i do not even smell gas , i burped it and turned gas tank upside down once, still won't work, grill is only 5 yrs old.
It sound s like the grill's regulator is locked up from "burping" the tank. Hopefully it's not a permanent lockup. To hopefully solve the problem, follow the steps below:
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Turn the burner(s) ON for 1 Minute, Then turn them OFF.
3. After 5 minutes reconnect the hose to the tank and open the valve VERY, VERY, SLOWLY (Slow
motion, slow).
4. Once the tank valve is fully open light one burner and turn it to HIGH. Did the burner light and
does the flame height look correct? Id so, light the remaining burner the way. Did it light and the
flame height look correct? If so, you solved the problem (with a little help).
If the above didn't solve the problem, the Hose/regulator Assembly needs to be replaced. What happened was this, when you turned the tank upside to "burp" the tank. The OPD Valve shot a hot load of gas to the regulator, when you opened it, as you normally would and permanently locked up the grill's regulator. That "burping" trick used to work with the old style tanks. Won't work with the new ones. You can get a new hose/regulator assembly at any home center or hardware store, that sells grills and accessories. They run about $30.00. Take your old one with you for comparison purposes. Once you install the new one and connect it to the tank. Open the Valve Very, Very Slowly, until it is fully open. Or you may have the same problem again.
Hope this helped to solve the problem. Happy Grilling!!
Jun 19, 2011 | Ducane 30400040 Stainless Steel Grill
The clutch line from the slave to the master clutch cylinder seams to rub on a brace till it started leaking. the first time this happened was a year ago, maby 4 or 5 years after i got the car, and now it...
Haven't heard of a problem there but if you have a problem, once you install the new line, get a length of rubber hose (like fuel line) and split it lengthwise. Put it on the line and clamp it. Put a third clamp exactly where contact causes the damage so the clamp further protects the hose. Do that and you won't have a problem there again.
Apr 21, 2011 | Chevrolet Cavalier Cars & Trucks
Toshiba TDP-MT200 Multimedia Projector Logo
209 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
