Question about Blitzz Technology Computers & Internet
Getting kicked off line
Im second computer little box gets real hot and it will not let me stay online
  • 35 Answers
Router should not get hot.Router could be faulty contact provider of router for further assistance.
Posted on Aug 27, 2008
My 06 charger is running hot changed everything to do with the cooling system,except for the fans witch never kicks on when it starts to get hot what to do
yep you need fans to run that's your problem
there should be a switch located in coolant line that turns em on/off
Jun 27, 2012 | 2006 Dodge Charger
Suddenly my ac went stopped blowing cold last night. I have tryed everything. I cleaned the coils. I changed the filter. I changed the capacitor. I had the freon levels checked. I checked the contactor (...
So your lines get cold and hot when the compressor goes off? If your bigger copper line is cold and the smaller one is hot then that is normal. Does it stay on is the question, would like to help but still unclear to me what you're saying
Aug 13, 2011 | Heating & Cooling
No charge happening on my 2007 boulevard c90 seems to be a chronic problem on these bikes looking at a stator rectifier online and is the stator actually on the kick stand side under the second large...
the stator is behind the front cover on KS side, must drain oil and will need new gasket, normally when it burns out it takes the rectifier/regulator with it!!
Recommend Ricks Stators on line this is a better replace ment than OEM, mine has lasted 2 1/2 years so far (this was third replacement) Also recommend relocating the regulator to the bottom front of the battery box (requires fab a plate and extending wires and solder connections) this allows it to get more air and stay cooler I also added additional grounds
Feb 15, 2011 | 2005 Suzuki Boulevard C90
My gas furnace fires but then cuts out. There is a similar post on here about this but my problem is a little diiferent. The unit kicks on, fires then shuts right down. The blower comes on and stays on....
HAD A similiar problem last week with a customer who had just installed a pool and running off of propane tank for gouse as well... he let tank go empty and started having problems ..what we ended up finding is that not only was his regulator on tank bad he needed a additional regulator to regulate the different psi pressure to the appliances... get them to check your regulator out
Jan 24, 2011 | Goodman Heating & Cooling
Runs Hot and Checking Oil
Well ambient temp around you, is it high?
Check your cooling system as it may not have good enough circulation. Beside the little window there is a little line telling you if you are in low, good or high oil level.
Mar 23, 2010 | 2005 Suzuki Boulevard C50
A/c troubles
replace the receiver and the orifice tube blow thru the lines with air while you have it apart
Apr 27, 2009 | Heating & Cooling
I need a picture of the rear air shock compresser shown with the air lines hooked up to it. i put new shocks on ,but they still do not work. an air line was off. but i am not sure where it geta connected.
i think its in the back under a plastic side compartment -its no big deal its just a little 12v air pump for the shocks in back if you wanted to u coul by pass it and get some plastic fittings from pep boys and put air in manualy like u would a tire - i have a 98 transport it has been a real pain with tailghts burning out front turn signals burning out and one day the wife brought it in all jacked up and the pump wouldnt shut off it was a cheap plastic arm under the van broke off the axle nothing but a simple on off swtch i duck taped to the axle -fixed 1 month later the motor blew up started to get hot head gasket or somthing - now im trying to get a 2003 just regular montana on the road everything works runs good but cant get the odometer to stay on im thinking about just lookin around for some "hot" inspection stickers when this goes ill never own another gm van -i think ill go japanese or somthin these things are just plain cheap junk
Apr 13, 2009 | 2003 Pontiac Montana
Beverage Air ST58N Not cooling
Compressor is cycling on the overload protector. Cause could be a bad starting relay but is more than likely the compressor is bad.
Jun 11, 2008 | Carrier ST58N
IRiver Mplayer 2GB: power problem
Sounds like your battery is dead/die'ng, i suggest you goin to the iriver site (i dont know what the site is i got mine from ebay) and getting a new battery, im not sure if they sell it or if you have a warrenty, im use to ipods xDD
May 21, 2008 | iRiver Mplayer MP3 Player
Presario 2200 CPU fan appears to be dodgy
Not really, since the fan is controlled ny a thermal sensor on the Motherboard. You may want to start by having the fan and heatsink assembly replaced.
Jan 10, 2008 | HP Compaq Presario 2200 Notebook
Computers & Internet Logo
29 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
Tre Elkins
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
