thats normal on many laptops... even on my Dell and Lenovo...
the trick is to disable the Trackpad when typing...
1) Click Fn + F3 keys together to disable the trackpad and then type
2) Click Fn + F3 keys together to re enable the trackpad and then type
3) Buy an external Keyboard and Mouse (Wireless one) and use them (I do the same)
4) if you have trackpad drivers & application installed then adjust the sensitivity of trackpad on it
You can delete a blank page in a Word document by deleting the page break at the end of the page. You can also combine two pages by deleting the page break between them.
Make sure you're in normal view (on the View menu, click Normal). If nonprinting characters, such as paragraph markers , are not visible, click Show/Hide on the Standard toolbar, and then do one of the following:
To delete a page manually, select the page break at the end of the page, and then press DELETE.
To delete a blank page at the end of the document, select the page break or any paragraph markers at the end of the document, and then press DELETE.
To delete a page break placed before a specific paragraph, click the paragraph, and then on the Format menu, click Paragraph, click the Line and Page Breaks tab, and then clear the Page break before check box.
Have you found the answer yet? I don't know that particular laptop but if you use the touchpad, it happened to me because even the lightest brush against the surface with a stray finger would make the cursor jump all over and do the same quite annoying thing as you described.
If you don'y use a mouse mat then your sensor (if you use a mouse with a censor) is picking up bumps, or changes in the surface it is moving over and turning it into jumps on your screen and using a mouse mat should solve this. If you use a mouse with a ball the take the ball out and give th rollers inside a good clean.
Go to my computer, right click>properties>hardware tab>device manager, then look down the list for mice and pointing devices, click the '+' sign and right click on your touchpad and select uninstall, do the same on the keyboard line and then restart the pc.
Both touchpad and keyboard will be reinstalled and then ready to use again as it should be back to normal
