Question about Microsoft Xbox Console
Unable to load some games
Hi when i got my xbox i changed date and time and after that is not letting me load some games, and i´m not able to get into the dashboard, how can i reload the software or set it back to default settings
  • Anonymous Aug 28, 2008
    the xbox works but i cant start the game
  • 41 Answers
Well seting the time wrong shouldn't effect game play, but leaving a xbox unpluged for 5+ hours will reset the time settings.
As for reloading the software, I can't realt help you.
Posted on Apr 28, 2009
Just go and change your setting dont put a game in then turn on your system and go to settings
Posted on Aug 29, 2008
Cant change date
I haven't played the game, but you should check out the owners manual. It would probably stand there.
Jun 17, 2012 | THQ Biggest Loser Ultimate Workout for...
Cant sign in
Hi loads of people are having the same problem, xbox live are installing their new NXE Summer up date so just bare with them for a couple of hours, after a couple of hours do the following below<br /> <br /> try switching you xbox off and back on and if it still dont connect then your going to have to wait i would try again in an hour or two, usually down time for the servers is a couple of hours while xbox install updates to xbox live, its not a problem your end so dont get changing any settings, the problem is with xbox live so just bare with them and it will sort itself out.<br /> <br /> the last time this happened was about 6months ago and the downtime was just over 4 hours, so bare with them for a bit and it will be sorted.<br /> <br /> you could try logging into the xbox site on the net and not through your xbox and check the xbox chat rooms and you will be able to find out more their.<br /> <br /> let me know if you need further assistance ok<br /> <br /> plz rate this solution as i have a whole page on unrated posts, thanks<br /> <br /> goto www.xbox.com/support and it should tell you whats happening and about any downtime they are having, you need to go to this site from your pc, have a look in the chat rooms this problem is with all xboxes so dont change any settings the problem is their end<br /> <br /> plz rate this solution
Aug 31, 2010 | Microsoft Xbox 360 Arcade
Games will not load on xbox 360
If once you put a game in the disc tray but it is does not load, you still have the dashborad on the screen or its just says "Reading" then "Open tray". You'll need to check first that you didn't set your Xbox 360 to boot to the dashboard.
To check this turn on the Xbox 360 with no discs in the disc tray. Go to the System section then Console Settings then Start up make sure it's set to Disc not Dashborad.
If you select disc the Xbox 360 will play the disc when you turn it on. But if you select dashboard the Xbox 360 will stay on the dashboard when you turn it on.
If you did so and still not loading, try another thing. Make sure this issue isn't with this disc only. Try some other discs and DVDs if you have to make sure is it an issue with this disc specifically and by then you'll need to get another disc or it's the console itself.
You'll need also to make sure that your Xbox 360 is not overheating and it's in a well ventilated place.
Check that the date and time are set correctly. To check this go on the System section then Console Settings then Clock then Date and Time. If it's not set to the correct date and time, set them correctly.
The last step to try is to unplug the Hard Drive and try some discs without the Hard Drive attached just to test is it the Hard Drive or the Xbox 360 itself faulty. If you did so and it worked without the Hard Drive, it would be obvious that it is the Hard Drive's issue.
Take care.
Jul 17, 2010 | Microsoft Xbox 360 Console
Won't read the disc.
You can check the Open Tray error troubleshooting tip i have put on FixYa, check the link here
Happy Gaming, please do take time to rate my solution
Regards
KreativeGeek
http://gamingbox.wordpress.com
Jun 08, 2010 | Microsoft Xbox 360 Console
Wont let me connect to xbox live
Check your firewall on your router. The Xbox Live service uses UDP ports 88 and 3074 as well as TCP port 3074 for its IP networking.
Mar 10, 2010 | Microsoft Xbox Console
Ff 11 game crashes at character login screen just goes black and im unable to do anything but turn the xbox off
for some reason your xbox is taking a long time to connect to the Square Enix servers. I can only suggest you make sure to have your cache cleared for a smooth load. You may have to redownload the game.
Jan 03, 2010 | Square Enix Final Fantasy XI for Xbox 360
Assassin's Creed - loaded played, turned tv off can't see xbox
that is nothing to do with the update iv done one for nearly every other game.
try to manually find the xbox through your tv i have to find it myself all the time. it looks like the auto find on your tv has changed, but it shouldnt be anything to do with the xbox.
May 16, 2009 | Ubi Soft Entertainment Assassin's Creed...
Unable to load saved game
you might have corrupted the game,as in turned it off before is done saving.
Dec 26, 2008 | Vivendi Universal Spyro: A Hero's Tail for...
Xbox 360 unable to get live
i cant find out to put the xbox up to this
Sep 21, 2008 | Microsoft Xbox 360 Console
Xbox (not 360)
that means the xbox360 is downloading something
Dec 28, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
44 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
