Question about Compaq Presario Notebook
Unable to connect to the internet
I am unable to connect to the internet. i have a full wireless connection, i have restore to factory settings, but no connection. we have 2 compaq laptops 1 is working fine the V5214ea is the one we are having problems with.
Drivers de audio compac presario c766LA
Posted on Aug 27, 2008
Half my screen doesnt work on my compaq presario. How can I do a factory restore if I cant see the screen and what option to click
I would definitely not try to do a factory restore without a full screen showing. Are you saying that the external monitor does not work for system restore?
amazon seems to have replacement LCD screens for $51.93
http://www.amazon.com/COMPAQ-PRESARIO-CQ57-229WM-SUBSTITUTE-REPLACEMENT/dp/B005IUFKKW
Sep 25, 2014 | HP Compaq Presario CQ57-229WM Notebook PC
There is an orange "i"
The orange "i" means that the Ethernet cable connection to the modem has been detected.
The light should be blinking green for Internet connectivity.
I advise you to reset the router:
To restore the factory default configuration settings:
1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink .
2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green.
The factory default settings will be restored so that you can access the router from your Web
browser using the factory defaults.
If resetting the router does not correct the issue, you should call your ISP (Internet Provider) and check if they are having a problem.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 23, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Router was working fine, then I upgraded the fw level to .29. When I did that, I could connect my 2 wireless laptop connections, but the 2 desktop pc's will not connect to the internet being wired. I have...
I hope you have a Belkin F5D8233 ver :3000 wireless router and you have upgraded the firmware version: 3.01.29.
It's a known issue with this model , only the wired connection will be not be online. Another information when you connect the computer in the 1st LAN slot you will have internet connection but not with other 3 LAN slot on the router. To fix this please follow these steps,
1. Log into the Belkin router setup page (http://192.168.2.1) in a wired computer .
2. In the left hand side under the heading Utilities? click on save/backup settings
3. When its asking for password to login leave it blank and click on submit.
4. Click on save to save the settings of the router in the Desktop
5. Then again under Utilities? click on restore factory defaults and then click restore defaults button, to restore the settings of your router to factory settings.
6. Then Under Utilities click on restore previous settings and select the file where you saved it and click on restore settings.
Then automatically you will be able to go online both wired and wireless.
I'm sure this would work. If it does work then please rank me and give me a testimonial
Thanks in Advance!
With Regards,
Prema.
Jan 03, 2011 | Computers & Internet
Unable to restore factory settings & unable to connect to PC using DKE-2 cable
the default code for restoring factory settings is 12345. just go to ur settings and try to restore using the said code. id it doesnt work try formatting ur phone by using the code*#7370#. but check for virus b4 tht.
May 21, 2009 | Nokia N95 Cellular Phone
Portable devices recognize router but cannot connect
Try to change the wireless security to WPA-PSK(TKIP) or WEP.
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
From the above configuration, please try to connect your portable device to the wireless settings of your Netgear router.
May 07, 2009 | NetGear WGT624 Wireless Router
Lost wireless system tray
Please run system restore to factory setting. that seem to be the only saviour.
rate this
Apr 13, 2009 | HP Compaq nx6110 Notebook
Internet Connection from desktop
hey laure
you may need to go to control panel, then internet settings, then hit the connection tab, and make sure the 'never dial a connection' button is clicked. then apply and reboot if necessary. don't mess with the router settings and definitely don't restore factory settings, that'll blank out the ip address and other things.
you should be able to access the web, otherwise the ethernet cable fromj your pc to the router is plugged into the wrong port on the back of the router.
good luck
chris from scotland
01776840273
Dec 07, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Unable to get Wireless to turn on
Sandy,
What was the earlier problem?
Do you think it is/was/might be related?
How did you get past the issue? If you formated, you have to go through "Software Setup" find it at Start, All Programs, Software Setup. (tc1000) or if you restored with the factory discs (tc1100) then it should be done. If a tech "restored" your tablet with other than the factory restore discs, then Q menu may be impaired or nonfunctional.
Is the card actually there?
Are the cables connected?
Is the card the original hp card? Some others will not work with the Q Menu.
Go to hp.com, navigate to the tc1100 support page and download all drivers or recent updated drivers.
Install the updates and you should be fixed.
HP will sell you restore discs for $10.72 (thats what I paid last fall) that will install the correct drivers for the unit. Cheap at twice the price. You will need a keyboard (USB generic will work if you don't have the original detachable) and an optical drive (USB CD Drive) basically to do this.
My friendly local tech is at $50 for basic service, and if you can back up to another PC (cat 5 cable connection is fastest) or a card, then a reformat never hurts a thing, kills many troubles too!
Best Luck, Blaino
Apr 23, 2008 | Compaq tc1100 Tablet PC
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Compaq Presario Notebook Logo
179 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
