Question about Epson Stylus Color 460 InkJet Printer
Printer head clogged
My black printer head is clogged and I have tried many times with the utilities but it's still clogged.
  • Jake McClear Feb 02, 2009
    It still doesn't print.
  • 353 Answers
Assuming that by "I have tried many times with the utilities" you mean you have tried many cleaning cycles, there may be other reasons than clogged nozzles. First ensure there is ink in the ink cartridge. Even though the Status Monitor (SM) may show there is ink, there may not be. The cartridge chip merely counts the number of ink shots the printer uses and reports this to the SM. Thus the ink remaining is merely an estimate and for a number of reasons can be wildly wrong. Change the black cartridge for a new one. If it still doesn't print, report back.
Posted on Feb 01, 2009
  • Gerry Millward
    Gerry Millward Feb 09, 2009
    Hey Jake, I was hoping we could go through a logical process to fix your problem (since there are a number of possibilities), but we must be sure you are starting from a known baseline - hence asking you to confirm that you are using a good cartridge. If you are, the next step would be to take you through a more thorough head cleaning process than the built-in system provides. Let me know if you wish to continue with this.
My brother DCP 165c printer does not print black ink, colored are okey. nothing is seen in LCD about this error
If you do not get an error in the LCD screen, it usually means that your Print head is clogged: try running a couple cleaning cycles using your printer inbuilt utility to try to 'clean' the Print head.
If this does not clear the clog head, try using a new original Brother black cartridge (which contains special solvent to prevent clogging) and repeat the cleaning cycles a couple times again.
If the problem persist, you could try buying a print head cleaning cartridge to 'dissolve the dried up ink' as Brother inkjet inbuilt print head are very difficult to access and clean!
Hope it helps & good luck!
May 01, 2011 | Office Equipment & Supplies
My color cartridge does not utilize its full color spectrum. all my print jobs are green. black and white works fine. I've already changed out the cartridge twice. Please advise! thanks.
You may have a clogged printer head. Try using HP's cleaning utility.
In general, you can access the printer's maintenance option at CONTROL PANEL, PRINTERS AND FAXES.
Right-click the desired printer model, then click PRINTING PREFERENCES.
Look for the MAINTENANCE tab. The options may not be the same, depeding on the brand of the printer. Run the head cleaning utility.
Test printer by printing a test page. Repeat the process if it doesn't give you the correct output.
Also, try to run the ALIGNMENT utility.
Hope this helps you.
Thank you for using fixya and have a nice day ^_^
Please rate my answer.
Apr 02, 2011 | HP DeskJet 940c InkJet Printer
New ink no print
Hi Good day!! Try to do a printer maintenance
Cleaning a Clogged Print Head
1. Press the cleaning button located on the front of the printer. Hold it down for 3 seconds to begin the cleaning cycle.
2. Run a cleaning cycle using your Epson printer utilities program. In Windows, go to "Start," "Printers and Faxes," right-click on your printer and choose "Printing Preferences." Select the "Utility" or "Maintenance" tab, depending on your printer model, and click "Head Cleaning." When the head cleaning cycle is complete, run "Nozzle Check." Repeat the head cleaning and nozzle check one to three times.
3. To access the Epson printer utility in OS X, select the Epson Printer Utility icon in the Applications folder in Macintosh HD. If prompted, select your printer from the Printer List, then click "OK."
Clean the print head manually. Remove the ink cartridges from your printer according to the instructions in your owner's manual. Turn off your printer. Dip a cotton swab in isopropyl alcohol, ammonia or hot water and rub the swab against the print head. Let the printer sit overnight.
Remove the print head according to the instructions in your owner's manual. Soak the print head for at least an hour in a small dish of hot water or isopropyl alcohol.
Preventing Clogged Print Heads
1. Use your printer at least once a week. Regular use will keep dried ink from clogging your print heads. If you have a color inkjet printer, print full color pages in addition to black-and-white documents.
2. Turn your printer off when not in use. This will prevent warm ink from bleeding onto the print head. If you have to store your printer, remove the ink cartridges.
3. Use a cleaning kit regularly. A cleaning kit usually includes a tube of ammonia that you spray on the printer head to clean dry ink.
Thank you for using FixYa
Please accept if my solution helps you
Nov 18, 2010 | Epson Stylus C84 InkJet Printer
My i560 Canon printer prints all colors but not the black ink
after a month of not using the printer, most probably the print head is clogged.. try using the printer utility to clean the print head.. it's under the printer properties.. normally that should resolve the print missing issue...unless your print head is really clogged up...
some would suggest to partial soak the print head onto warm water..but it doesn't work everytime..
May 24, 2010 | Canon BubbleJet i560 InkJet Printer
Does not print
First of all please check the ink level. If it is not finished try followings:
First try to run a cleaning cycle. To do that:
- Load paper in the paper tray. - Access printer utilities. (Right click your printer icon, select printing preferences and click the utility tab to access printer utilities) - Click the nozzle check icon. - Print to check it.
Then click the clean button to clean the print head. - Try it a few times.
İf it doesn't help you can try to run power cleaning cycle. But it uses much ink. There must be enough ink in the cartridge.
Hope this helps.
Apr 24, 2010 | Epson Stylus Pro 4800 InkJet Printer
Black head 100% clogged, 50% Cyan clogged. Mag & Yell good. All new cartridges. Used clean utility 4-5 times. No help
seems like worn print head, if it's not under warranty the cost of a new head can be like buying a new printer.
Oct 30, 2009 | Brother MFC-5440CN All-In-One InkJet...
Inkjet printer
Your inkjets are clogged, use a damp sponge to clean heads (located where the bottom of the cartridge is) put a paper towel underneath the cartridge holder to soak up water, allow to completely dry then run ink test (head cleaner) through printer utility...its worked multiple times for me
Jan 25, 2009 | Epson Stylus C62 InkJet Printer
Streaked printed images on my Pixma iP4500 printer
Sounds to me like your ink cartrage has gone bad.
Dec 29, 2008 | Office Equipment & Supplies
Ink Cartridge Problem?
Seem to be or a cartridge problem or a printer driver.
disconnect printer from computer
cancel documents in queue
reboot & reconnect printer
Oct 14, 2008 | Epson Stylus C86 InkJet Printer
Printer has completely quit printing color with new ink installed
In order to determine whether this is a hardware or software problem there are several steps you can take:
1.Download and install the most recent printer driver from Epson
2. Try printing out the nozzle check pattern using the Maintenance Utility. This bypasses the printer driver and allows the printer to use all cartridges to print out the patterns. This will indicate whether there are clogged heads and whether or not it will print color at all. Gaps in the patterns indicate clogged heads and you need to run the Head Cleaning utility once or several times.
3. If you get color patterns from the nozzle check (whether or not the patterns are full or have parts missing) you need to check to see if the default settings for the printer have been set to "Black Ink Only". Right click on the printer icon and select "Printing Preferences". Click on the "Advanced" button in the lower right corner and after the popup, look on the left side and see it the "Black Ink Only" box is checked. If so, uncheck it and while you are there uncheck the "High Speed" box as well. This way you don't have to deselect it in the printer dialog each time you print, especially if you are looking for a quality print each time.
4. Try the printer on another computer if you get color during the nozzle check to see if the software is corrupt on your computer.
5. If you get no color patterns at all when doing the nozzle check, it would appear that you have a hardware problem within the printer. It would be unlikely that all the colors would fail at the same time due to severe head clogging.
Hope this helps in some way.
Oct 07, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus Color 460 InkJet Printer Logo
205 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
