Question about Toshiba Satellite A60-S1561 Notebook
Toshibe Sat Pro
Hi, I still have the same problem,
In the Bios, no hhd is shown, but i am unable to select that part ( as you can in a standard desktop bios) to show hdd present.
Any ideas please ?
Many hanks
  • 202 Answers
The hard drive either has a bad connection or it has failed. if it has failed you have to replace it. if you have replaced it is the connector connected and is it oriented right.
Posted on Jul 25, 2009
Hi I have a Acer Travelmate 4050. The MB bios does not pick up the HHD. Wen I startup using my Windows XP cd It does pick up the HHD I can then Format and the installation will copy the files to the...
If the BIOS does not detect the hard disk and Windows XP cannot detect the hard disk to install Windows, then the hard disk is faulty.
To get your Acer working agai, you need to replace this hard disk with a new one.
Apr 21, 2011 | Acer Computers & Internet
Tourque converter not locking up
DESCRIPTION:
The torque converter clutch (TCC) inside the torque converter, also referred to as the "damper clutch" or "lockup clutch", functions to lock the input and output sections of the torque converter together to provide improved fuel economy.
If you are servicing a transaxle with either of the following conditions, follow the repair procedure shown below:
^ Torque converter clutch does not engage when driving at steady speed on the highway. ^ Engine stalls when coming to a stop or when shifting into Drive or Reverse
REPAIR PROCEDURE:
1. Check the ATF level when the engine is idling in "N" according to TSB 01-40-013. Adjust the ATF level as needed.
. Attach the Hi-Scan Pro and check for Diagnostic Trouble Codes (DTC) in both the "ENGINE" and "AUTOMATIC TRANSAXLE" menus. If the DTC shown are found, follow the repair procedure shown. If no DTC are found, go to Step 3.
3. Using the Hi-Scan Pro, select "HYUNDAI VEHICLE DIAGNOSIS", "AUTOMATIC TRANSAXLE" and "CURRENT DATA" menus, then "OIL TEMPERATURE" or "FLUID TEMPERATURE". Confirm the oil temperature readout is correct as shown. If not, replace the oil temperature sensor.dak408_10.jpg
4. Using the Hi-Scan Pro, select: ^ "HYUNDAI VEHICLE DIAGNOSIS" menu ^ "AUTOMATIC TRANSAXLE" menu ^ "CURRENT DATA" menu ^ THROTTLE P. SENSOR, "TCC SOLENOID DUTY", "TCC SLIP" and "OIL TEMPERATURE" ^ F2 - "SCRN". This will isolate the top four data to allow a quicker refresh rate for the data. dak408_18.gif
Check the TCC data under the conditions shown in the table. If the TCC data indicate as shown, the torque converter and damper clutch are operating correctly. If not, go to Step 5.
5. If the TCC data does not indicate as shown or the engine stalls, follow the repair procedure shown.
6. If the engine stalls when shifting into Reverse or Drive, the oil cooler may be restricted. Disconnect the oil cooler hoses to the oil cooler in the radiator. Bypass the oil cooler as shown. It the condition: ^ Does not recur, replace the radiatorRecommend finding a certified Transmission mechanic if you are unable to complete these test using a scanner.
Nov 13, 2010 | 2001 Hyundai Santa Fe
I have a Gateway Laptop, I cant find a model number, but the computer had a virus in which a so call tech removed, now the computer boots the the first screen , at that time you can press f2 and go into...
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thank and regards,
Anil.B.R
Nov 06, 2010 | Gateway M305CRV Notebook
Hi, I own an Acer Aspire M5630 Standard desktop
A branded computer uses Original Equpment Manufacturer (OEM) version of Operating System, hence if you change any hardware it will go to the trial version of OS automatically. Hence, you have to use the full system recovery disk to reinstall the OS.
Thanks and regards,
Anil.B.R
Oct 27, 2010 | Acer Aspire 5610-4648 Notebook
I have built a new computer from scratch and when I did I bought Windows XP Pro 64bit and after I decided I would upgrade my motherboard and when I did I started up the computer again and when it came up I...
Hi 0092352
Check to see if the connection of your hd to the motherboard is correct should be primary no slave
DVD/CD rom should be secondary and no slave.
Boot the bios by pressing del to check if the hd is and dvd is shown.
Hope it helps
thx
Banaple
Sep 02, 2010 | Computers & Internet
Hi IMy seagate barracuda 500gb internal hhd has sector 0 bad.No way with many program to resolve it.I can' format,always say me that there is a bad sector.I used seagate tools,hhd disk repair and othen...
Since the HDD has rejected easy repair by the most appropriate tools, I recommend you recover the data and replace the drive. I've been through this many times for clients.
You did all the right things.
Best Wishes
Aug 04, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Unable to install windows XP on my Notebook
you can't install Windows Xp from witin Windows vista. (not backwards comparable).
restart the computer press F12 when the HP logo comes up. that will bring you into BIOS. select advace>>boot order.
select CD-ROM as first boot. HHD asn second.
exit the BIOS and restart the laptop with CD in the CD drive.
press enter when the system start to install from CD......
and follow the screen (must reformat the HHD).
Jan 27, 2009 | HP Pavilion DV5234US Notebook Laptop
Toshiba Sattelite Pro
r u check settings in bios
for harddrive there its showing or not in bios otherwise first try to configure the harddisk then try for hardware part
Aug 24, 2008 | Toshiba Satellite A60-S1561 Notebook
Duel boot system first xp then vista
Wow....
First I would check the BIOS settings. Make sure that the slave and master jumpers are correct on the drives.
Wouldn't it be easier to make one drive Windows XP on one drive while running Vista on the other?
It would make things easier to troubleshoot.
Jun 12, 2008 | Computers & Internet
Toshiba Satellite A60-S1561 Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
