Question about Saeco Easy Espresso Machine
Saeco Easy hums instead of packs grounds
My Saeco Easy has started really struggling when packing the grounds (should be "thwok, thwok, thwok"). More and more often, I'm getting hums instead of a resounding "thwoks", and I end up with a cup full of slightly tan water and a sludge of water and grounds instead of a tightly packed puck. Something is preventing the smooth operation of the packing mechanism, but I'm hesistant to start pulling things apart. I've removed and thoroughly cleaned the plastic bean/grounds hopper, but that's not doing the trick.
  • VinnieJ Aug 26, 2008
    Where would I find the brewing gears? In the removable plastic hopper assembly, or inside the main machine?
  • 515 Answers
I think the brewing gears has to be replaced.
Posted on Aug 26, 2008
  • Mirko Blas
    Mirko Blas Aug 26, 2008
    you have to open the machine, when you have the back side open you will see a white plastic on the chassis behind the grinder engine. Loosen the screws and you will see two gear wheels, one white and one grey.
    Let me know which one you need and i can give you a spare part number.
    /Mirran
Have miss on #4cyl on 4.6 triton.changed plugs and wires and injector on 99 expedition..still have Miss..any help?
I am gathering it's a newer year.
I'd check the coil pack and see if that's your issue.
Sometimes coil packs can get cracks in them and get moisture inside the packs and ground out causing a issue.
Or just the packs going bad over all.
Not sure but I believe it's around $80 a pack which has 2 plugs on the top for either 1 2 or 3 4. To change them it's really easy just a 3/8 s bolts usually on the top and 4 bolts. Plug and play and make sure the battery is unhooked
Jun 06, 2014 | Cars & Trucks
Lights not working
Check if power pack is humming.
Copy following link for full Malibu troubleshooting resources.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Jul 19, 2012 | Malibu Intermatic Inc. ML300RTW 300-Watt...
Hums but no power to lights
If I understand correctly, you have a Malibu power pack and can not manually turn lights on-off but timer is humming so the timer has power.
1) That eliminates electric circuit as suspect.
2) Try to spark a wire across terminals and see timer has power on terminals.
3) Check that your bulbs are good, because they can all burn out in a hurry if a couple of them suddenly go bad.
4) I have not found repairs and parts for power packs.
After hours of reading manuals, searching Malibu, Intermatic, ebay etc I found nothing.
There are folks who write fixya how they took apart their power pack, but nobody reported fixing a power pack once it goes bad.
5) Best I found are tips for next power pack that might save money:
The reason I add these tips now, is some fella wrote-in to fixya.
He bought 500 Watt power pack to replace 300 Watt > thinking bigger was better.
Power pack burned out. Here's why:
a) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
b) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
c) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
d) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 07, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
Is there a fuse (or similar) INSIDE a Malibu 600 TW (6.0 Amp)?
There is no fuse
There are no replacement parts for Malibu power packs
Malibulights.com has no troubleshooting steps
Here's what I learned:
Power packs are made to last many years 'in ordinary conditions' >> but they do give out.
Malibu power packs stop working and have to be replaced, they can't be fixed.
Power packs frequently stop working when people disconnect all the lights to work on the system, but they leave the power pack plugged in.
Power packs make a humming sound when ON.
Check electricity to unit to see if power pack has electricity.
Check your GFCIs in bathroom and kitchen.
Plug hair dryer into same receptacle to see if there is power.
Lights have to be replaced as soon as they burn out.
With burned out lights, the power pack will overpower and burn out other lights.
Evidently the power pack with no lights can also burn itself out.
When buying a new power pack, match bulb wattage with power pack wattage.
10 - 20 watt bulbs = 200Watt power pack.
15 - 20 watt bulbs = 300Watt power pack.
Oct 22, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
A low humming noise
A low quality power supply pack (brick) to the wall outlet is most likely to be the cause of your problem.
Look for the power supply pinout and test it with a replacement power pack.
Plug the power pack onto the same power strip of the audio source (Example: your tuner) will also help rule out grounding problem.
Turn off any motor operated item (example: heater fan) to rule out noise from other appliance.
Apr 24, 2010 | RCA WHP141 Consumer Headphones
Using filter screen and ground coffee the unit will not make a full cup and sounds like it is struggling.
I know if the coffee is packed to tightly into the My Personal K-cup the Brewers tend to struggle to pump the water through. Could this be your problem?
Apr 09, 2010 | Keurig Platinum B70 Coffee Maker
Can the ml600tw be installed inside the house
I think the reason the power pack is recommended for outdoor only is 1) It hangs on the wall and is not secured from falling down and injuring child 2) power packs have open terminals that might be violation of local electric code. The voltage on power pack terminals is just 12 volts but you don't want child sticking tongue on it 3) Noise: power packs make humming sound.
Open following for Power Pack troubleshoot checklist and warranty information and other tips to keep power pack working longer:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Oct 20, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Saeco Easy
I think I have the solution. The "thwok, thwok, thwok" noise is a solenoid opening and then slamming the trap door that dispenses the coffee. Mine had a similar problem.
Upon removing the top, I found that the solenoid, and further that the mount where it attaches to the plastic frame was broken. Basically, the little plastic fin that should hold the lower flange of the solenoid was sheared off. That left the solenoid free to move, and made it impossible to complete the action to move the dispenser trap door.
It looked like there was no easy way to replace that part of the plastic mount, so I epoxied and zip-tied the solenoid into place. It seemed to do the trick. I doubt it will last forever.
-tony
Oct 06, 2008 | Saeco Easy Espresso Machine
Saeco Easy Coffee Maker
I think I solved this (I had the same problem). Upon removing the top, I found that the solenoid that moves the trap-door for the grounds was loose, and the mount where it attaches to the plastic frame was broken. Basically, the little plastic fin that should hold the lower flange of the solenoid was sheared off. That left the solenoid free to move, and made the action necessary to move the dispenser trap door impossible. Instead of doing it's thwok, thwok thwok, it would just hum.
It looked like there was no easy way to replace that part of the plastic mount, so I have epoxied and zip-tied the solenoid into place. It seemed to fix the problem.
-tony
Jul 26, 2008 | Saeco Easy Espresso Machine
Saeco Easy Espresso Machine Logo
156 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
Mike Cairns
Mike Cairns
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
