Canon Pixma MP500 All-In-One InkJet Printer Logo
Posted on Jul 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ink cartidge leaking onto feed rollers - Canon Pixma MP500 All-In-One InkJet Printer
Anonymous
Level 2:
Guru:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 52 Answers
  • Posted on Jul 11, 2011
Anonymous
Expert
Level 2:
Guru:
Mentor:
Answers
52
Questions
0
Helped
9619
Points
137
Is this a new ink cartridge? have you tried replacing the inks with a genuine one? because these inks have independent printer heads. if the inks are defective that would be the case for it
Epson Stylus CX4800 prints blank pages
Alex_Garton:
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
1helpful
Black ink leaked on inside of printer.
try to replace the defective cartridge by a new one and see printing test result
Paper feed won't accept photo-quality paper - the paper feed action is not smooth - it will just about take 80gsm paper but not evenly and sometimes it feeds several sheets through at the same time. At the...
The paper pick up fingers and rollers get smooth and polished with use and then slide on the paper. Clean the rollers and pick mechanisms with isopropyl alcohol to rejuvenate them and restore their grip on the paper. Do this as far along the paper path as you can get, using Q Tips where necessary and turn the rollers to clean their whole surfaces.
Please rate this solution.
When I print the image is printed at an angle tipped slightly to the right. It happened after putting in a new ink cartidge and I scanned in the test page. Scews everything printed. HP photosmart C4480
Remove and replace the cartridge again, I wonder if somehow you haven't canted them over somehow? Also check the paper is feeding OK, clean the Rollers, If one roller was just ever so slightly Ahead, from the other one, just a tiny bit, it would ever so slightly "Skew" the page? so check all that out.
1helpful
Why am I getting black lines across cards when printing?
Some ink probably got onto the rollers that feed your paper. What you might have to do is run a few cleaning pages through the machine, this can be done through the menus on the device itself under something like "maintenance". If that didn't help, you can look into the printer and gently clean the feed area with a q-tip and rubbing alcohol where ever you see ink. Also, this can happen if you use aftermarket ink or "refilled" ink, they tend to leak more often.
Still getting message empty cartidge lexmark x2650
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Paper Jam
Open up the doors and blow some compressed air throughout the paper path (where the paper travels up). Make sure to blow air onto the sensors, because paper dust can coat them, causing false jams.
Does the paper get out of the tray at all? There is a feed roller that feeds the paper up into the machine; if you remove the paper tray you can see this roller -- it's big and gray and has grooves across it -- above where the paper sits toward the front of the printer. Blow air onto this roller as well, and if you have either D-ink or a rubber rejuvinator, clean the roller with a lint-free cloth.
Also make sure the paper is snug in the tray and not bent or crooked.
Ink blots deposit onto feed rollers which in turn transfers to all new prints
Most likely you have a leaking print cartridge (toner cartridge). Does it have the same problem if you use the Manual Bypass tray?
It could also be a worn fuser sleeve that is causing the print defect...the fuser would need replaced in that case.
3answers
How to refil ink in hp 2120 cartidge
actually your printer cartridge was cloted or maybe airlocked.
You must use tissue paper and rub it on the nozzle side. Ink may flow out.
sukumar.t.k.
Epson R300 printer leaking blue ink on rollers
Hi , clean both end of roller clean rug or cotton tip , this may happen during cleaning time some ink expose both end of roller sometime in piece of paper .during the cartridge in the middlle pullout the power cord stop cartridge and push cartidge down and lock.
old marine
old marine
ZJ Limited
ZJ Limited
