Question about Frigidaire FDE336RE Dryer
MAYTAG NEPTUNE MDE0700AYW
The dryer is very noisy!! There was a long piece of felt twisted all up in the dryer. I'm thinking this is the felt seal. Is this possible to fix yourself? No one in my town wants to touch a front loading dryer :(
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
Is there something else i can use to replace the felt seal without buying a whole new drum on a maytag neptune model MDE9700AYW
On older maytag dryer's the felt seal wasa seperate part and not part of the drum..the problem is i do not know if the drum on the newer and older dryers is the same diameter they look similar in size but if it isn't exactly right may leave a gap where the clothes will get caught in...however the part number for that seperate felt seal is 314820
Gene
Aug 24, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune dryer is making a scratching noise.
If the sound seems to come from the front of the drum it's probably the felt guides. The bottom one will wear first and make a grinding, rattle like sound. You can access it by removing the front panel which includes the door. It fits around the drum at the front. Here's a diagram. Some models have a two piece and some a one piece guide. Part 4 on this diagram is one. It's called a seal here. DIAGRAM
If the sound comes from the rear, there is a nylon bearing and metal socket at the rear center of the drum.
Feb 06, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I Have a stackable unit. The dryer had some piece of metal/wire tear off of it. I think it was/is something that held the felt piece in place. I believe it was attached to the back of the drum. I know I...
Take the dryer apart, first unplug it, see what else is broke? how bad does the belt look, the wheels in back? and the front seal? then
Write down the model number and do a google search for your model Maytag? parts. I like partselect.com or repairclinic. both have diagrams of parts you will see what you all need to order.
Remember once you remove any panel you will be exposed to sharp surfaces.
Please repost if you have more questions.
Dec 30, 2009 | Maytag Washing Machines
Maytag neptune gas dryer front loader 9 years old has begun to squeak what is the most likely cause?
Either one of the rollers or the idler pulley is causing the squeak. Most common to go bad in a maytag dryer is the roller on the right, it sits just above the heating element. You need to take the drum out and spin each of the rollers and the idler pulley to determine which one is the problem, and replace it. good luck. Shane
Oct 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My clothes have brown marks on them that look like burn marks. has this been a problem with maytag neptune dryers? if so, what is going on?
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Noisy maytag neptune electric dryer
you have to remove front panel. pain in **** but its not to bad once you start
Jun 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Feb 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Dryer Mosel #MDE6700AZW
you will need to remove the front panel and the front bulk head. after that you will see that there are clips that need to be pushed down to hold the fabric (felt) down. You need to make sure that the felt isn't torn. If it isn't torn then all you need to do is take a flat head screw driver pry the clips up and put the felt back on and push the clips back down
Dec 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer neptune felt at rear of trum came out
you have to buy a new one if the felt seal is still good use contact cement on the drub and seal to put back on with need any more help let me know
Jan 11, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
57 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
