It is simple find a clean container.From the tank you will find the fuel valve and the fuel hose connected to your carburator. First close the fuel valve, if it is easier to remove the hose from the carburator, remove it and to put it to your container. Open the valve to drain the gasoline. Otherwise take a rubber hose about half meter of the same size and put one end of the hose to the container, disconnect the fuel hose after the valve and connect the other end of your hose which is in the container. Open the valve to drain the gasoline to the container.
i'm trying to get to the spark plug because i believe it's bad
