Question about Cameras
Won't take pictures or recognize memory card - Cameras
  • Cameras Master
  • 1,879 Answers
Wont recognize any kind of memory card ?
any messages from the camera ?
wont take picture because of the card ?
make & model please
Posted on Aug 26, 2008
  • 89 Answers
Make sure the memory card is compatible with the digital camera. you can check the manual or browse the internet for specifications of the camera.
    Master:
  • 848 Answers
What is the make and model no ?
    President:
  • 1,450 Answers
HAVE YOU TRIED TO FORMAT THE MEMORY CARD?
MacBook Air won't recognize Nikon s8200
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
Apr 20, 2013 | Nikon COOLPIX Cameras
Canon power shot sd1000 won't connect to my computer anymore. The computer does not sense that there are pictures on the camera!
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Jan 02, 2013 | Canon PowerShot SD1000 Digital Camera
I insert a 16 gb SD memory card in my NuVue 700 plus photo frame and it is not recognizing it I took the picture with cannon slr camera. What could be the problem?
The NuVue 700 works with SD cards. Your 16GB card is actually an SDHC card and won't work in devices not specifically designed to work with SDHC cards. You need to use SD cards, 2GB and smaller.
Sep 25, 2012 | Cameras
Pictures show up on memory card in camera, but computer won't recognize the card - either inserted directly or by USB
Aug 11, 2012 | Nikon D40 Digital Camera with 18-135mm...
Pc won't recognize my M 350
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 27, 2012 | Cameras
Camera says out of memory won't let me take pictures. i cleared all the pictures out and still cant take pictures. What do you think the problem is?
I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera. 1. Turn camera off 2. Insert memory card 3. Turn camera on 4. When the memory card is inserted in the camera, the [Format card] option appears in the setup menu 5. Choose Format to format the entire card. Don't choose Quick Format 6. Wait until your card is formatted
After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
Sep 01, 2011 | Nikon COOLPIX L5 Digital Camera
I have Lumix dmc tz5. It is not recognizing the card. When I turn it on it says taking pictures with internal. I have reformatted card etc. still won't work properly.
With no card in the camera, go into the menu and find "format" and follow the directions to erase the internal memory. After that, your card should work properly.
Jun 06, 2011 | Panasonic Lumix DMC-FX3 Digital Camera
My computer doesn't recognize the camera. I am trying to transfer some pictures in the internal memory through the usb cable, but the computer doesn't recognize the camera.
Sep 23, 2010 | Kodak EasyShare M1033 - black Digital...
When transfering pictures from camera to PC EasyShare will not transfer some pictures. "picture already exists" in My Collection. These are all new pictures taken with blank memory card. This occurs even...
Scrap the camera! Kodak hasn't and won't address the problem. Most picture download software won't recognize the camera. The only solution is to remove the memory card from the camera, put it in USB adapter and treat it like a flash drive. Cumbersome. Awkward. Stupid. After you scrap the ****, tell your friends so they don't make the mistake of buying a Kodak.
Dec 26, 2009 | Kodak EASYSHARE M1063 Digital Camera
My computer won't recognize my camera (it recognizes other brands, but not canon.) How do I make it recognize it so I can upload my pictures!!!!
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 09, 2009 | Canon PowerShot SD600 Digital Camera
Cameras Logo
48 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
