Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner II dishwasher
The locked light remains on. I press Cancel and it does not go off.
Why is the locked light on.
How do you get the locked light off.
We have unplugged the dishwasher for hours and plugged back in and Locked light is still on.
Your help is appreciated.
Ellen Smith
  • Anonymous Sep 08, 2008
    I have the same problem. The controls locked button was turned on and I cannot get it off no matter what I try and the dishwasher will not work. HELP!
I held down the heated dry button & it worked!
Posted on Jan 05, 2009
I held down the HEATED DRY FOR 10 to 15 SECONDS and it went off finally, tried everything, turning the breaker on and off, etc and this works!!!
Posted on Mar 22, 2009
    New Friend:
You have to hold down the button next to the 'locked light' for about 10 seconds... this is how you both lock and unlock the dishwasher
(i have little ones so the lock feature is a must! On my model the lock feature is enabled and disabled by holding down the heated dry button.
Posted on Sep 24, 2014
Don't have a Sani-rinse button. Held down the Air Dry (control lock) button for a while and the lock light went out.
Posted on Oct 31, 2008
My dishwasher was too doing the Locked light on for about the last three weeks...it seems like most people's problem is the "Clean" light on, so I tried their method: try holding the Sani-Rinse button and the Air-Dry button down at the same time (warning, this may kill your thumbs). My light went off, and I was able to start my cycle.
Don't know if it'll continue being nice, but it was a relief not having to call the repairman.
Posted on Sep 14, 2008
I need a quick fix, please tell me the combination of buttons to press to reset
Posted on Nov 08, 2008
Lock light stays on my whirlpool quiet partner II
If pushing and holding the lock button till the light goes out doesn't work, you likely have a problem on the circuit board.
May 24, 2014 | Dishwashers
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Hello, Re: frontloading washer Model C45172 Our washer has been operating withiout hitch since purchase about five years ago, We love it. Today I tried to program it to do an extra rinse after wash...
For the Elite (HE) machines:
Press 'STOP' twice, press 'POWER', choose a wash cycle (such as 'NORMAL'), select wash options (water temp), press 'START' to finish the reset sequence.
Other Kemore electronic washers:
Unplug the machine for a minute, plug it in. Press 'PAUSE/CANCEL' twice.
Good luck from Detroit, MI.
Jun 12, 2011 | Kenmore Washing Machines
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Error Message
Your owner's manual may give a troubleshooting guide for the error code your machine might give you. Is it possible you have locked out the control panel? I "think" the calypso has a control lockout, usually a start button or cancel button. If you press it in for 3-5 seconds, it can lock or unlock panel. If all else fails, try unplugging it and see it it will drain out the water.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Whirlpool GU2400XTP Built-in Dishwasher Logo
899 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
