Question about Casio Cassiopeia E-125 Pocket PC
Anyone experience problems with an overclock E-125?
A while back I overclocked my E-125 to 200 Mhz from 150Mhz. It wasn't 100% stable, but a soft reboot would always get it back in order. It occasionally froze in the cradle, and the IR didn't work, but the speed increase was tremendous for movies (DivX) and NES gaming. Anyway, I decided to clock it down to 180Mhz, and it's been more stable. However, though it recognizes the d-link DWL-650 NIC (wireless) I put in it, and the drivers appeared to have installed, it doesn't work. Anyone else experience problems with an overclocked E-125?
    Master:
  • 551 Answers
There are some overclocking programs available like through www.jimmysoftware.com or even hardware fixes. The one by jimmysoftware is for the iPAQ only. iPAQ Overclocking software I would strongely avoid doing the hardware fix. The overclocking applies only to the processor itself and does not take into account the I/O from the the processor to the various other hadrware components. Some games, video, and apps may perform better but anything hardware related like PC card or CF cards that have a function like modem, networking etc. . . can run into timing related issues and not function. At least the software version can be easily removed. Good luck
Posted on Sep 04, 2005
SOURCE:
How to overlock my e5500 2.80ghz to 4.5ghz???? or the highest overlock that can e5500 dual core
Hi there, your first going to need better cooling for your cpu like a aftermarket cooler and then go into the bios and raise the cpu multiplier and cpu voltage bit by bit
Mar 03, 2011 | Intel Pentium DualCore E5500 28GHz 800MHz...
So if the ms7528 mobo is not sfe to overclock... but i use like AVGA precision to OC my graphics card(9800GT) would that still cause conflicting problems somehow? I'm new to the OC'ing. I Is it safe to...
I have never used this mobo before have others had problems with overclocking? you could try updating the BIOS/Firmware this might solve the problem. You are correct in saying that AVGA will only overclock your GFX card the bast way to overclock is go up a few Mhz at a time and test it when you hit a point were the PC becomes unstable go back a few steps so your not running it on its limit
Hope this helps tom
Jan 17, 2010 | Nvidia Zotac GeForce 9800GT Amp Edition...
How to overclock Intel Pentium Dual Core E2140 1.6 GHz processor
The following link will tell you the very simple way to overclock this processor. Half way down the page you will find the header "OVERCLOCKING"
http://www.value-reviews.com/index.php?page=pentium-dual-core-e2140
"Since the architecture was designed for the 1066 MHz FSB, overclocking is as trivial as setting the FSB to 1066 MHz (266 MHz quad pumped).
...you instantly get a 2132 MHz CPU with little increase in temperature."
Dec 06, 2009 | Intel Computers & Internet
Problem in overclocking my Processor.
1: You problem is your power supply, PSU. When you try to give more power to your CPU by overclocking it, it doesn't have enough wattage, or power, to get the CD drive, or your sound card to work. This is why the CD drive works again when the CPU isn't overclocked. So, in this case, to overclock your CPU, you would have to get more power to your system by getting a more powerful PSU, or one with more wattage. How much you can overclock your processor depends on a variety of different things. Your RAM, PSU, HDD, CD drive, etc. I would not go past about 3.4ghz with your processor, however, a "max overclock" is hard to determine.
2: The maximum temp for your processor is 70C, 158F. I would try to keep your temperatures under 60C to ensure your processor doesn't "die early" on you. The multiplier cannot be changed, only the FSB can be changed. You should be able to create a "profile" in bios and set it to your default so that it loads up automatically when you boot up. Make sure you find a stable configuration before you make a default profile.
Mar 30, 2009 | Intel Computers & Internet
I have an XP with AMD Athlon 2600+2.13 GHx want to overclock
Sounds like you should start bumping your FSB speed up a li'l at a time. You should be able to get near 200 without any special mods. It should at least run well into the 180's. If it won't boot, back it down a few MHz. If it won't start, clear your CMOS, and try again at a lower speed that worked. Then, after you find a stable speed, try playing HL on it for awhile to stress it. If HL is unstable, either back off the FSB some more, or start playing around with bumping up your voltages. There's lots of threads discussing that topic. Remember, don't go for the max right off the bat. Try the 170's first, then the 180's. Once you pass the point where it will boot, you'll have to go back and reset the CMOS and reset all those settings again.
Jan 29, 2009 | AMD Athlon XP 2600+, 2.13 GHz...
How do I overclock a Celeron 733mHz PGA370?
You can only overclock your computer if it has ATAPI BIOS. So get into BIOS upon bootup and if you have ATAPI then it will say it across the top. It will also have a section for the CPU with the current speed and an option to change it.
Dec 22, 2008 | Intel Celeron, 600 MHz (SL46U) Processor
Asus Maximus Motherboard memory problerm with Corsair Dominator 1 GB DDR2 x 4
Hi XaaX,
Sorry to hear about your troubles. I have built over 100 machines using ASUS MB's and I've never run into a problem like yours. I'd suggest that you check a couple of things: 1) Make sure that all your BIOS/clock settings are correct, not just the memory frequency. As I'm sure you know, you need to check the CPU settings (voltage and clock speed), FSB settings, memory settings, and voltage settings, as you could be overclocked without knowing it. Also on overclocking it is sometimes a bit of luck of the draw, as some CPU's out of the same batch will overclock 20% or more and some will not overclock at all (if you haven't read about how Intel and AMD decide what speed to market the CPU's at as they come off the line, you should; I think you'd enjoy it!). The second thing I'd do is to get memtest (you can Google where to download). Make sure you get the version that runs at the system level, not the version that runs inside Windows. It is free. If you let it run for a couple of hours, it will tell you EXACTLY what, if anything, is wrong with your memory.
In any case, you should be able to run any ASUS board at 100% of factory specs and never have a HW related crash. If you can document your saga to ASUS, I'm pretty sure that they will MRA the board for you, assuming it's still in warranty.
I hope this is helpful. If you think it appropriate, I'd very much appreciate a Fix Ya rating on this solution. Good luck!
Bob
Oct 29, 2008 | Computers & Internet
Overlocked my Intel Pentium 4 3.00 Ghz
You have to go into your bios and see what your front side bus and memmory speeds are. If you overclock you cpu, sometimes you need to underclock your memmory. Say step your memmory down to 333mhz and overclock your front side bus(fsb).
Normally your fsb is 200 and only increase it by mhz. Restart, go into windows. and see if it is stable.
I always use cpu-z and gpu-z to check all of my hardware settings. I use ati tool to overclock my x1950 and it is great. There really isnt any good cpu overclocking tools because its better to do it in the bios.
Do a specific search in google for your processor and overclocking.
Jun 06, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Ntune overclocking freezes my comp.
you machine is not able to handle it dude
Mar 08, 2008 | Computers & Internet
Overclocking
First off... be warned overclocking is not for the faint of heart... now let us begin...
MAKE SURE YOU HAVE ADEQUATE COOLING!!!!
I can't stress this out enough if you plan on overcloking it's worth spending some money on some fan's specifically a CPU fan to make sure it stays cool. A side effect of overclocking is increased heat.
Restart the computer and go into your BIOS. Look for the setting to change the bus speed. Depending on your specific CPU it should be 200 MHz (if it's not don't worry, most computers now are 200 MHz). There should also be an option called the multiplier. This one is usually unavailable. If it is available you have a high-end CPU model that is "unlocked".
THEORY:
The system bus is multiplied by the multiplier and gives you the resulting speed.
200 x 16 = 3200 => 3.2 GHz
IF your multiplier is unlocked you can increase it... it's not then we have to use the system bus.
When you change the system bus it increases the speed of everything in your system... that is the link in between  individual components. But it's a double edge sword... it will cause you system to become unstable more quickly and reduce the maximum overclocking potential.
PRACTICE:
Increase the bus speed 3~5 MHz at a time. Restart the computer boot into the Operating System and run applications you normally would. If nothing crashes, hangs, freezes, locks up... you can reboot the computer and increase the bus speed again. Repeat theses steps until:
a) reach a point where the system becomes unstable
b) you feel like pushing your system more is getting to risky
This is a very basic answer on how to overclock. For more information, guides and other goodies http://www.extremeoverclocking.com/ is a good website for more information and guides.
WARNING: If you push the system to far to fast without doing it gradually you can surpass the computer components limits and cause damage to the computer parts. I am not responsible for any damage that occurs. This is just a guide.
Oct 28, 2007 | Intel Socket 478 CPU COLLING FAN & HEAT...
Open Questions:
Casio Cassiopeia E-125 Pocket PC Logo
100 people viewed this question
Top Casio Computers & Internet Experts
k24674
Joseph Hoffmann
Joaquim Martins
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
